Advertise
Here
Search 🔍
the Site
Chime right in! (no registration req'd)
"No color after plating"
I would like to find out are there any mistake with my setup , I had made up a 10 litre (concentrated) h2so4 bath adding 75 grms of sodium dichromate into it , plating my stainless steel (304) panel size 3 by 5 inch , heating the solution up to 75 degree c , using lead as cathode . plate it for about 30 mins at 5 to 7 v but there is not any colour effect , instead the surface of my panel became like tarnish and had flow marks which I do not know what is that ... Can any one please advise me what should I do ..?
Roy Choon
plating shop - China
Sorry, I've never heard of such a process. Where did you hear of it, and what did you expect it to do? Like what color were you expecting, for example, please? Thanks!
The solution is a mixture of sulphuric acid n sodium diachromate or sulphuric acid n chromic acid.
Roy Choon
Plating - China
I need advise how could I get colour on stainless steel , I need some colouring on stainless steel(304) panels size 3 by 5 inches , reading some articles from here eg. letter No.35735 and 33236 , I actually try out the method at letter No.36330 posted by me . I am expecting blue or black colour on SS(304)panels ....
Roy Choon
plating - China
Fishlock in his book on metal colouring gives somewhat different formula than Dettner/Elzes Handbook:
sulphuric acid 250 ml/lit water
sodium dichromate 60 gr/lit
70-95 C,anodic current 0,6 A/sq.ft
Colour sequence: brown, blue bronze, reddish brown, deep purple to green (45 minutes time). Lead anode. Only for 18/8 steel.
Hope it helps!
- Zagreb, Croatia
Q, A, or Comment on THIS thread SEARCH for Threads about ... My Topic Not Found: Start NEW Thread
Consult'g, Train'g
About/Contact    -    Privacy Policy    -    ©1995-2021 finishing.com, Pine Beach, New Jersey, USA
