Marking system for rings
    Precious metal jewelry is usually marked.
    • "925" or "Sterling" indicates that the ring is made of silver, at least 92.5% pure.
    • "K" indicates the percentage of gold in parts out of 24. "12K" is twelve parts gold out of 24 (50% pure); "14K" is fourteen parts our of 24.
    • "KP", etc. means 'karat plumb' -- jewelers can add a small amount of needed solder without changing the K, but if it's still 14 parts gold including the solder, they can mark it 14KP.
    • "PLAT" or "Pt." or "950" means Platinum of 95.0% purity or better.
    Other marks are usually Hallmarks, but there are tens of thousands, so unless you want to spend hours poring through many books, you may not find them. This forum has had a little success with some of the common ones.
< Prev. page          (You're on the last page of this topic)
Gentle Readers:
This meeting place welcomes Q&As, photos, history, & interesting tidbits  🙂
Please engage with other posters
• When people show interest in each other's situations, the page quickly becomes a fun & informative learning experience for everyone !
• When people show no interest in other people's postings, and just post their own, it often quickly deteriorates into a string of unanswered questions smiley
Q. I have a diamond ring it has .925 on the inside with another symbol beside it. It's a square with lines in it? I'm really confused.
Amanda skinner
- lewistown Pennsylvania
April 3, 2017
A. Hi Amanda. Sterling silver is 92.5% pure silver, i.e., .925. So sterling silver is often engraved with ".925" rather than the word "Sterling".
As I and others have said many times on this thread, it's probably hopeless to expect anyone to know what "a square with lines in it" means because there are tens of thousands, maybe not hundreds of thousands of maker's marks, but if you send a well-focused pictures of the ring and the maker's mark someone may be able to help. Still a jeweler can probably tell you basically what you've got in a flash.
"World Hallmarks
Vol. 2: Asia, Middle East, Africa"
by Whetstone,
Niklewicz, & Matula
hallmarks_world_asia_africa
"Hallmarks of the Southwest"
by Barton Wright
hallmarks_southwest
! The site owner is offering his time and knowledge on simple subjects that can be googled, that's how most of us ended up here, myself included.
***I WANT TO HELP HIM AND ANYONE ELSE WHO LANDS HERE VIA GOOGLE SEARCH***
I was trying to figure out the history of the THAILAND marks in rings and their metal purity. (Still clueless but I'm about to help a lot of you for him).
After reading through the entire thread I wanted to bang my head into a wall for the poor fella surely having "Groundhogs Day" (movie) every time there is a new post.
OK HERE WE GO I JUST SPENT HOURS COLLECTING THIS PLEASE USE IT!
First I want to address the Answer given by Adela Garcia - St.Louis regarding the gold & silver markings:
***DO NOT TRASH YOUR RINGS WITH A "P" FOLLOWING 14K,18K,22K (insert numberK)***
- 14KP stands for "karat plumb" gold---meaning exactly 14K....no more, no less. KP does NOT, I repeat does NOT mean plated or fake.
- Gold stamped with the KP is guaranteed to have a gold purity not less than indicated but could possibly be slightly more pure. So, for example, a bracelet stamped 14KP is guaranteed to contain 58.33% gold or more. Another bracelet stamped 585KP is guaranteed to contain 58.5% pure gold or more. The KP stamp is designed to eliminate the non-standard caratage tolerances that some markets allow for. In the USA, for example, gold can be sold at up to 0.5 carat more than its actual gold content. So, a ring marked 14K can contain just 13.5 carats of gold.
- Things to consider about lack of markings: the piece may have been repaired/resized/worn enough to rub away the hallmark in the case of it being worn down you should be able to see an obvious taper from the sides of the band to the bottom which will be thinner that the rest.
- NOT ALL SILVER RINGS ARE MARKED 925!! Especially with Native American jewelry! It is a dead give away to all Native American jewelry collectors that 925 usually means it is from Mexico, the natives used "Sterling" and early pieces are not marked at all.
- I own a warriors cuff from 1910 with no purity mark or maker mark ... why? Native jewelry was traditionally made for the tribe only and the symbols were meant to protect the person wearing it. Later when the railroad was built they started making items for the white people, this helped them and didn't discredit their true pieces because the pieces sold in railroad shops were mass produced.
- Two other marks on Native Jewelry are
"German Silver" -- this is not silver, it is actually several metals mixed together and then plated and
"COIN SILVER" -- coin silver is circa 1900 and it 90% silver.
- "SS" (Sterling) can be confusing because it's also used for stainless steel.
- "STG" (Sterling)
- "Stg. Sil." (Sterling)
- Other silver marks: keep in mind as previously mentioned these are XXX/1000 : 925/1000 = 92.5% pure... here we go:
- 800
- 830
- 835
- 900
- 950
- 999
- 999.9
The United States does not use hallmarks. However, many countries with far greater histories of silver-smithing employ, or did employ at one time, a complex hallmarking system. There are a number of excellent guides available on the internet that can assist you in identifying a particular hallmark. Go here: 925-1000.com
Ok this is wearing me out, but I'm pushing on. I think I will leave this as a silver post and do a gold later.
Silver Plated jewelry often does not have any mark on it anywhere that would indicate it was silver plated. Occasionally you will, however, see the following marks:
"SP" - meaning Silver Plate
"Plate" - more common on flatware and table pieces
"EP" - meaning electroplated
"Quadruple Plate" - allegedly meaning the piece went through electrolysis four times
"EPNS" - meaning electroplated nickel silver
"S80" - this is a mark that appears on a lot of Chinese silver colored jewelry that is often also marked 925. This is not silver jewelry. It is merely plated with "925" Sterling Silver. 'S80 Silver' is apparently a plating compound in many emerging market countries.
Oh my goodness I'm wiped out ...
This is where I copied most of the info from (minus the native). There are more examples and Honestly.... I'm too tired to detail it out.
I hope I have helped at least one of you.
Go here: http://blog.hunterridgejewelry.com/2014/06/27/the-difference-between-silver-sterling-silver-900-silver-800-silver-alpaca-nickel-silver-and-silver-plated-jewelry/
Katie Taylor
May 24, 2017
- OKC, Oklahoma USA
thumbs up sign  Thanks very much, Katie, your help is greatly appreciated!
The only thing in your posting which I think might be not quite accurate is "Quadruple Plate". While I originally believed that it meant the same thing as you did, here is a posting by a very knowledgeable reader, copied from thread 44569 claiming it refers to silver plating 4 times thicker/heavier than some minimum:
A. Quadruple plate contained 8 tr.oz. of silver plate per gross (144 pieces) of teaspoons. The plating was about 1.2 mils thick (.0012"). In 1975, quadruple plate was still being produced, mainly for places like hotel restaurants.
Chris Owen
- Nevada, Missouri, USA
29370-16
A. Hello- I came across this information/resource on eBay ⇨
originally shared by aumiagoldandsilverjewelry. I hope the information contained here helps to answer some of your questions.
Elizabeth Mongillo
- Berlin, Connecticut
July 17, 2017
Ed. note: Although the link that Elizabeth offered broke over time, thankfully Internet Archive preserved a copy! -- so we revised the link, so clicking the graphic will still take you to the article :-)
These days information often appears on the internet, then simply disappears forever. If that is a concern to you please consider a donation to The Internet Archive.
Q. I have a gold ring with initials and A 15 at the bottom inside the ring has inside is stamped with M.JAK do you know what this means?
Connie Curtis
- Valley Springs California usa
September 23, 2017
Q. Does anyone know who the maker of this mark is? A/M
sandra salvador
- Gadsden, Alabama USA
October 5, 2017
29370-17
Q. I have this lovely ladies ring - with black elongated stone and it is marked inside S.U.K. no other markings on it at all - it seems to be silver maybe Mexican or ??? it has a lovely design on the outer part and a super nice setting.
Just looked closer and there is a small stamp but blacked over hard to read near the S.U.K. marking it looks like a number possibly 925?
Frank Deturse
- Toronto ontario Canada
October 17, 2017
Q. Hello, I have a ring that is marked on the inside as follows; C (circled as if the copyright c) then separately another c that is circled but larger than the 1st, like an initial then a w also circled as if an initial and then 900 pt. The ring is is wide band, the body of which is open cut work 5 petal flowers with stones (diamonds) it was left to me by me aunt, what do I have? Any idea? comments, thoughts are most appreciated. Maria
Maria Goncalves
- Somerset County, New Jersey U.S.A.
October 18, 2017
A. Frank: your ring is probably sterling silver.
A. Maria: your ring is probably platinum.
Neil Bell
Albuquerque, New Mexico
October 18, 2017
"Hallmarks and Date Letters on
Silver, Gold and platinum"
by Eric Bruton
hallmarks_bruton_AgAuPt
affil link)
Q. I have a gold ring with inside markings that I can't make out other then a circle with a capital A inside the circle.
Can anyone help me with this ring.
Kathi Spears
- Pocahontas, Arkansas, USA
October 18, 2017
Q. I have a silver ring that is stamped 18K GE A with circle around it what does it mean?
Misty Sleep
- Topeka, Kansas,usa
October 28, 2017
Q. I have a ring with 18KGE and a capital A with a circle around it. I was curious as to what the letters meaning was -- if it was the company trademark or something else possibly.
sally bejuil
- jonesborough , Tennessee
February 3, 2023
A. Hi. I'd guess that GE means gold electroplate. With only 26 letters in the alphabet but probably at least 26,000 trademarks & hallmarks, I'm not sure that a capital A with a circle will be exclusive to one company, but maybe. I think well focused photos might help decide whether you're all looking at the same hallmark.
"All About Antique Silver with International Hallmarks"
by Diana Sanders Cinamon
hallmarks_cinamon_antique_silver
Q. I have a ring that I purchased in an auction. It's stamped with "14k rt". What does the rt stand for?
Jackie Colonna
- Carlsbad, California USA
October 18, 2017
Q. What does the TM refer to? its engraved just before the 925
thx
Sameer Agherdien
aquarist - Port Elizabeth, south Africa
October 20, 2017
Q. What does CR1K© mean on the inside of my 10k gold ring? It has several small diamond and a moderate size ruby.
Andi Breedlove
- Hazlehurst, Georgia USA
October 25, 2017
Q. My ring has 925 on the inside however, I can't tell what the symbol is behind it. Can you please help me?
29370-18a   29370-18b
Stefanie Turner
- Rome, Georgia United States
October 26, 2017
Q. I have a white gold ring that has no gems just a band, but it also says 155 on it. Can you please tell me what that means?
skye singleton
- Sedro Woolley, Washington, USA
October 30, 2017
Q. Hi I have a gold ring that says ADI 995 china CZ on it. What does this mean?
Tyler Reaves
- Tucson, Arizona USA
October 31, 2017
Q. I just bought a ring from the $2 box at local 2nd hand store. I don't normally but it caught my eye on my way to a warm coat and so pretty and shiny. Anyway when I got home I noticed that there is a mark on outside of the band it is a bit warn but I think it's a 91, 61, or even a gl but the last mark looks like it could be a 5,2,s. Oh I don't know,I think I am more curious as to why a mark would be on the outside.. I am sorry to bother you over probably nothing, but if you have any ideas I would love to hear them. Thank you
Debby Healey
Care for elderly with Alzhiemers - Chesterland, Ohio, U.S.A.
November 1, 2017
Q. I have bought a white gold diamond ring, markings
Are 375 on one side then 10k on the other, there is no diamond stamp , there is a 417TGGC stamped on it.
Have no idea of the meanings
Juliana chappell
- Hilperton wiltshire England
November 4, 2017
Q. I have set of earrings that are stamped 925 along with the letters sold. we all know what 925 stands for, but what about the SLD?
James Coffman
- Topeka, Kansas,united states
November 7, 2017
29370-20
Q. I have a silver ring & it looks like rope & it is "twisted" in 3 different ways. Can anyone please tell me what it stands for? I have a photo. .
Thank you!
Linda C.
- Tennessee - USA
November 13, 2017
A. Looks like octopus tentacles.
Jill N Landry
- Lafayette
January 17, 2024
Q. I have a ring that is an antique and it has a stamp on it that I am unable to find online what it means. Maybe someone can help me out and better explain the meaning. Possibly maybe the maker stamp? It has a 14k stamp on it as well. Please help. Thank you!
SN RLL
Nicole quintero
- Torrance california
November 13, 2017
29370-19
Q. Hello! I have a hallmark stamp on my engagement ring that looks like a beaver tail with 14k and D050 on the other side.
Christy Parks
- Wilkes Barre, Pennsylvania, USA
November 15, 2017
Q. Hi, I have a set of engagement ring and band no Stamped it's a yellow ring but I'm confused of checking what metal it is? It was acid tested from 10k,14k,18k and no reaction then I used acid for 22k and it was fade after few seconds. I want to make sure what it is so I pour the whole 14k acid in a plastic cup and left the ring inside whole night and it turned in to a light yellow color in the morning (no green) what metal is this?and additional when I rubbed into a stone it's a white color metal
one day I cleaned it with a metal cleaning solution and it turned back to a deep shiny yellow color
Can you pls tell me if this metal is gold or not? Thank you
Adore Meyers
- Maryland
November 16, 2017
Q. White 14k ring with diamonds. Band inside says EDS-7 and 1 with a . then a line under it, followed by 30. What does it mean??
Joan Dawson
- Pittsburgh pa USA
November 17, 2017
Q. hi?. so I have this ring with little diamonds around a big one on the center and is marked 585 and 14k on the inside.. is it really a white gold or a fake one?
Just katez
- NCR,Region 3,Philippines
November 18, 2017
Q. I have a 10k ring with the letters AU what does that mean I can't find any info anywhere??
Paula Chambers
BUYER - Mt. Grove Missouri USA
November 21, 2017
29370-22
Q. I have silver earrings with AU and a c circled backwards. Does anyone know what it means or a book or site that reference these?
nissa_rader
Nissa Rader
- Parkersburg, West Virginia USA
March 27, 2018
wikipedia
Copyleft
A. Hi Nissa. The "copyleft" symbol is interesting. On the one hand Wikipedia says it has no legal meaning; but it says it means you are free to copy the design in your own works, but if you do copy it, you can't copyright them.
As for books or sites with hallmarks, many suggestions have already been offered on this thread; repeating stuff on a thread that's already way too-long thread would hinder people more than help them. Please review their suggestions and share your thoughts. And share the Jameson please. Thanks.
March 2018
Comment:
Thank you to all whom have had answered some of these questions. I have read quite a few. And it baffles me to see how many people ask the same questions over and over; not only do a lot of initials and letters mean makers marks but they could also mean somebody's initials that it was bought for :-)
Tim Clark
- Lawrenceville Georgia USA
14K A & P
Q. My grandmother had a ruby and diamond bracelet. It had matching earrings & a ring. The bracelet is stamped 14K and I believe A & P. What designer or design company is this?
29370-23b
29370-23a
Rebecca Gruberger
- New York
November 17, 2019
Q. MY WIFE WAS GIVEN HER GREAT GREAT GRANDMOTHER'S WEDDING BAND. ON THE INSIDE ARE THESE MARKINGS: AN H, THEN A CROWN, THEN 18M. DO YOU KNOW WHAT THESE MEAN?
29370-24
Jeff chandler
- LINCOLNTON North Carolina
February 12, 2021
Q. I HAVE A RING WITH JA 18K/SS ON IT. WHAT DOES THAT MEAN.
I ALSO HAVE ONE WITH JA SS10K ON IT WHAT DOES THAT MEAN.
Emmett Alden Presley
- Jonesboro, Arkansas
April 9, 2021
A. Hi Emmett
I don't think it's legal everywhere to put a karat mark like "18k" on a ring that has been simply electroplated with gold because it's a bit deceptive, implying that there is intrinsic value where there is none, but pending more info my wild guess is that it's a stainless steel ring with gold electroplating. Or perhaps it's a quite old ring of sterling silver and gold. I'd make the same assumption for the other, although I suppose either or both could have areas of gold and areas of stainless steel or sterling silver.
You're probably not going to get anywhere without more effort, including pics of the rings and pics of the engravings, because googling those letters leads to all sorts of different rings ... but if you want to try it from the other direction, google 'John Atencio' and see if rings and maker's marks from that maker look like yours.
Q. I have a ring yellow gold but doesn't have a k stamp. It does have a JA stamped. WhT does this mean?
M shields
- Bristol ct
March 19, 2023
Q. I received a ring with a stamp on the inside that says: "10K (has a star next to it) HDO". Along the other side of the band on the inside too, it has the word "master". I am Wondering what this means? I have tried searching it and looking up the stamp, but cannot find anything about it. Please help!
Carlye Kiedrowski
- Woodbridge Virginia
May 16, 2021
A. Hi Carlye. 10K stands for 10K gold, which is 10/24 pure gold and 14/24 other metals like copper and silver. If you received the ring from your grandmother, it's 10K gold; if you received it mail-order from China it might be 10K gold or it may just be facetious markings. Buy precious metals only from a person or store you trust :-)
As for the star, "HDO", and "master", yes, there are so many tens of thousands of general markings that it may well be hopeless.
May 2021
Q. My mom gave me an old silver alexandrite ring and it has E6 stamped inside the band. What does E6 mean? There are no other markings inside the ring. I believe it is sterling silver.
Amy Bruce
- Dixon, Kentucky
July 6, 2021
A. Welcome Amy. Welcome no. 503 :-)
July 2021
Q. Square box with a slash though it diagonal from top right corner to the bottom left corner after 10 k on a ring what does it mean?
Steve dickson
- Lawrenceburg Tennessee
July 7, 2021
A. Welcome no. 504, I wish here was something we could do for you but there probably isn't. Sorry.
July 2021
Q. I purchased a white gold ring with markings FR 14KT on one side and Naplan, I think on the other. I figure Naplan is the maker, but find nothing on this, but vintage ring maybe. Thought maybe you might be able to help. Thank you in advance! I broke a prong on one of the outside corners and I'm going to take it for repair. But, should I find another from the same time frame to try and match the stones?
Candice Gateley
none - Oklahoma city, Oklahoma
August 31, 2021
Q. Found my grandmother's ring. It has 3 prongs and three stones the color of diamonds. The inside has an M. Is that just the size? I would appreciate any help you can give me, as my dad passed away and I found it in his possessions.
S Siverling
- Minot North Dakota
September 30, 2021
Q. I had a 10k gold band that was my great aunt's. It was also stamped (deep) with a star, nothing else. I researched that Star but only kept coming up with a jeweler ID mark. Never found that. I would love to know what that star was.
Carrie Pillow
Retired - Evington Virginia
September 23, 2021
Q. My name is Carrie. I was recently given a ring that's been in my family for years. I was told it's a black onyx 10k yellow gold ring. It has a stamp in it that I can't find anywhere.
29370-25
I just want to know who made this ring or what it's worth so I can insure it.
Carrie Carter
- Indianapolis, Indiana
September 28, 2021
Q. I just received an engagement ring. What does the marking SK9LGD mean on the inside of the ring?
Gloria Ree
Hobbyists - Lancaster Texas
November 12, 2021
Q. I have a diamond heart Solitaire, silver colored band with A inside the band. I can't find anything to identify what this means. Can you help?
B Gibson
- Independence, Missouri
January 4, 2022
Q. I have a ring with 10KEJ stamped inside. What does the EJ stand for?
Lyn Boston
- Lebanon, Tennessee
February 3, 2022
Q. I have a gold men's wedding ring that is stamped J14KS.
Lori Hubbard
- Lodi, Wisconsin
January 22, 2022
Q. Hi
I'm in the UK and have a diamond ring which has D5.05ct and Pt950 stamped on the inside of the band. Stone measures 11 mm across and approx. 6.5mm high.
29370-26a   29370-26b   29370-26c   29370-26d   29370-26e
It has no Jeweller's Marks or Maker's Stamp ... does this mean its been made abroad? It's been in my family for years.
Many Thanks.
Mrs McG [surname deleted for privacy by Editor]
- Haddington U.K.
April 10, 2022
A. Hi Mrs. McG. I deleted your name & town because to my untrained eye I see no reason to not believe that it's a platinum ring with a real 5+ ct diamond, worth certainly in the high 5 figures, and maybe in 6 figures for all I know.
I'd suggest getting it appraised immediately. Or maybe take it to Christie's or Southbys. Maybe it'll pay off your mortgage, plus fund a trip around the world :-)
Q. Only letters for hallmark, test shows to possibly be palladium. Same hallmark on both rings. Would like to know more. Thank you.
29370-27c 29370-27a 29370-27b
Jennifer Hernandez
Just a granddaughter trying to know more about my grandmother 's jewelry - Houston Texas
May 11, 2022
A. Hi Jennifer. The hallmark appears to be Thomas McGrath of Providence RI. My guess is they are silver, not palladium, and neither worthless nor very valuable. You can search eBay , ETSY, and the like for similar jewelry, or ask a jeweler or pay-service for an appraisal if not satisfied with my guess, which is based on little except a 10-minute google :-)
May 2022
Q. My name is Matt and I am trying to identify this ring I got from my grandmothers estate before I propose to my girlfriend. It is a 10k rose gold engagement ring with a Chanel logo underneath the main stone on the inside, slanted figure 8 stamp inside of square, with two breaks in the stamping almost appearing like L7 on the inside of the band.
29370-28c   29370-28d   29370-28a   29370-28b
The side view of the ring shows a crown with a pink diamond in the center. The Ariel view displays a larger oval diamond inside of the diamond halo the top of the band on both sides splits and reconnects three times on each side for six total openings. The top on each side holds pink oval diamonds and the diamond halo surround them as well as the middle opening.
Matthew Sosa
- Toledo Ohio
May 11, 2022
Q. I bought a small bag of jewelry at an estate sale. The ring pictured was in the bag. The marking inside the ring is P OK. Do you know what this means?
gold & diamond ring
Angela Grubbs
- Macon Georgia
May 17, 2022
Q. What does a P * M on either white gold looking or silver looking ring mean?
Pamela Myers
- Kansas city, Missouri
July 1, 2022
A. Hi. Maybe whoever gifted it to you had your initials engraved in it? :-)
Please send a pic of what you are describing because if it is a maker's mark there are tens of thousands and a graphic will offer at least an improved chance of help. Thanks.
Q. My wife has her grandmother's ring. It is stamped OKFC and wants to know what it means.
Tjomsland Johnson
July 12, 2022
A. Hi Tjomsland. When google fails to find any info on something, as in this case, it's usually because not enough info has been offered. Please send a pic of the ring and its stamping to mooney@finishing.com for posting here.
I have a ring with the letters AD on the band. I can't find anything with those letters. It also had 14k inscribed but I know what that means. Photo is attached, thank you!
29370-34b   29370-34a
Amanda Lynn
- Ketchikan, Alaska
April 25, 2023
A. Hello Amanda,
I don't get on this site as much as I want but I'll answer your question and hopefully you'll see it. The AD on the inside of the ring most likely stands for American Diamond. These stones are lab made and not real diamonds. The 14k means the white gold is 14/24ths purity, which is 58% gold. If this was bought for you as a gift, I hope I'm not getting them in trouble. You do have gold there and a great looking ring however.
Mark L Baker
- WINSTON SALEM, NC USA
May 12, 2023
Q. I have a ring with a small circle on each side of the letter L
29370-35a
What does this mean, could you tell me please.
Cindy Covey
- Sanford, North Carolina
June 15, 2023
Ed. note: What is that whitish spot to the right of the hallmark? If it a chip in a plating on the ring, then we'd at least know that it's a plated ring, not fine gold jewelry.
Q. I have this exact ring and came onto this site for some answers ... what this symbol means?
Sonya Carter
- Eugene, Oregon
September 17, 2023
Q. I have the same exact ring and was wondering if you guys have found anything out about it? If you have would you please let us know?
Star Stogsdill
- Alton Montana
October 11, 2023
Ed. note: You sent us a followup claiming a pic was attached, but forgot to attach it :-)
Q. Have you gotten an answer yet??
Jeremy Johnson
- Eugene Oregon
December 29, 2023
A. Hi folks.
That "L with a dot on each side" is a hallmark but there are tens of thousands of hallmarks. None of you have yet offered any info to narrow things down :-(
For example: no one indicated their ring's age (passed down by great-grandma, or bought recently from a jewelry chain?), any geographical hints (bought in USA, Europe, Asia, Caribbean), whether their ring has any other markings (sterling, 995, 14k, or none), whether the stones are jewels or glass, what the ring is made of, whether it was cheap or expensive. Your fellow enthusiasts might enjoy helping track it down for you if they are offered some hints -- but not if their research effort is limited to leafing through tens of thousands of hallmarks from every age, type, material, and geographical origin. Heck, even Google Lens gave up on me without finding it :-)
Please tell us something else about your rings besides the L with dots.
Tip: Readers want to learn from your situation;
so some readers skip abstract questions.
Q. Did you ever figure anything out about it?
Shawna White
- Trezevant, Tennessee
January 18, 2024
Ed. note: If you can supply no other info but that mark, apparently you'll have to resign yourself to looking through tens of thousands of hallmarks; as we noted, Google Lens cried uncle :-)
Q. I have a ring that is old and has 83D stamped on the inside. I think it is blue topaz but not sure. Does anyone know what 83D means? Thank you.
29370-36
Susan Schmitz
- Washougal, Washington
October 10, 2023
Q. I have a men's ring, silver in color; on the inside it has a diamond shape with no numbers on either side. Can someone help me interpret that hallmark please? Thank you.
Jerry Vasquez
- Fresno California
October 16, 2023
Q. Hi! I have come across this piece. I am not very familiar with 10k gold, here is mostly 14 and 18k. I have done my research but I can't find much info.
gold bead bracelet
Does anybody know if the mark in the picture represents genuine 10k or S10 k whatever that could be?
It would be highly misleading if it wasn't but that would not be the first time.
Alex Metal [fictitious]
- EU
December 20, 2023
Tip: This forum was established to build camaraderie among enthusiasts through sharing tips, opinions, pics & personality.
The curator & some readers who publicly share their info will be less likely to engage with those who don't.
Q. I have a ring that was given to my grandmother by my grandfather many years ago. White gold with a small flower with a small diamond in it. It looks like some of the mark has been rubbed off due to being worn, but I do see what looks like "-M" (minus symbol and M). Hoping to get an idea of what the mark may be. Thank you.
gold 'flower' ring b   gold 'flower' ring a
D Spin [fictitious]
- Jacksonville Florida
January 21, 2024
A. Hello,
The letters on the inside the ring are usually a maker's mark. Being the first letter is almost worn off so it's hard to identify. The second letter M is most likely the manufacturer of the ring. For example T-M would be Tupper - McMillan. I've also seen the letter Z which could stand for Zircon (not to be confused with cubic zirconia) thus identifying the stone.
Mark L BAKER
- Cazenovia, New York USA
January 26, 2024
Q. I was wondering what a 'W arrow up S 14k p' means on my ring?
Ruth Janego
- Seffner Florida
July 5, 2024
A. Hi Ruth
14k p should mean 14 karat plumb: 14/24 gold by weight even after allowing for any solder.
The thing is, there's a big difference between an abbreviation like '14k p' and a hallmark like 'w arrow up s' because an abbreviation like "14k p" stands for something, it has an agreed-upon meaning in the industry, so you can reasonably expect that people with a bit of jewelry knowledge can tell you what it means. But 'W arrow up S' is a hallmark or trademark, of which there are thousands upon thousands -- probably tens of thousands. You'd need to consult hallmark books rather than expecting that a reader will come along who will have tens of thousands of hallmarks committed to memory :-) Luck & Regards,
