What is "Pickling" of Steel?
Q. I am a student from Strasburg high in Colorado and I was wondering what is pickling steel? I have been looking all over the internet and you are the closest I have gotten.
Luke P [last name deleted for privacy by Editor]
- Strasburg, Colorado, America
A. Hi Luke. If you picture the making of steel, you have a red-hot metal that you are forming, rolling, forging, or whatever. The surface of the hot steel is going to react with the oxygen and water vapor in the air, forming something similar to a very heavy rust. This is called 'scale'. The scale needs to be removed, and 'pickling' is usually the name given to the chemical (acid) removal of scale.
Uses and Composition of Pickling Inhibitor
Q. I want to know the uses and composition of Pickling Inhibitor used in the pre-galvanising process of cold rolled steel.
Ishaq [last name deleted for privacy by Editor]
trading co - Jaipur, India
A. Hello, Ishaq. Hydrochloric acid is used to remove rust and scale from steel. But hydrochloric acid will also attack and dissolve the steel itself. Pickling inhibitors are interfacially active compounds which bind to the steel as monomolecular layers, and shield it, reducing the attack on the steel. This saves steel, and lengthens the life of the acid.
One way of answering your question about their composition is to say they may contain both organic and inorganic ingredients (according to Surtec, they commonly contain alkenes, alcohols, amines, polymerized aromatics, and heteroaromatics), but they are not a generic chemical formulation; they are proprietary products available under such trade names as Rodine, Akzo and Stannine LTP. Rodine alone has about a dozen different formulations for different situations. Good luck.
Regeneration of pickling liquor (HCl)
Q. Hello!
Although I am working in aluminum foundry, I just finished my degree in material science, and I have to make a work about pickling of steel and regeneration of hydrochloric acid. Can somebody help me on telling me where can I find information about this, I found something but is not enough. Also, the uses of the iron oxide that is obtained form the regeneration of pickling liquor.
Thank you in advance.
Carlos E. Ortiz Hernandez
- Ramos Arizpe, Coahuila, Mexico
A. We have been regenerating "all" of our acids and rinses chemically for the last two years. You can see the article that describes this in "Products Finishing" magazine (November 2002) page 82.
David C. French
- Charlotte, North Carolina, US
I do not comprehend why in this day and age companies dump acid because of metals and organics saturation.
1. Put 1% PRO-pHx [acid extender] into the acid tank that you wish to eliminate the disposal of.
2. Filter your acid with any type of filter you chose. Small tanks often use a FloKing style pump with a 20 Micron cartridge to capture the organics and metals.
3. Check your acid strength at least weekly. Add new acid to keep the bath strength at optimum. Add 1% PRO-pHx based on the volume of acid added.
David French [returning]
August 17, 2016
DETERMINATION OF INHIBITOR CONCENTRATION IN PICKLING
Sirs,
We have a pickling plant in our company. We add pickling inhibitor namely Rodine s-57 that prolong the pickling bath life & controls hydrogen embrittlement. Nowadays, we are able to see the hydrogen embrittlement after painting, even after the addition of the pickling inhibitor (hydrogen embrittlement leaves bubbles on the painted surface of the cycle frame). So, kindly tell me how to determine this inhibitor conc. level at any point of time.
P. BHALAJEE
bicycle mfgr. - Chennai, India
Dear Sir,
It is not written in your question what is the acid , and from my best knowledge I think it Hydrochloric Acid.
Anyway it is not possible to analytical test the concentration of Rodine Inhibitors in the bath.
The best way to do it is by accomplishing application test of etch rate of the solution. As role of tomb the etch rate must not exceeds 400 milligram of steel per 24 hours per square decimeter. A good inhibitor most pass this test.
Another way is to compare weight losses of Inhibitor acid solution tested compare to the same concentration acid solution without inhibitor . The weight losses percentage of the inhibited acid solution compared to acidic solution without inhibitor must not exceeds 5% or percentage inhibition of 100-5=95 minimum inhibition percentage.
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
Can pickling be done in the field?
Q. I work for a general contractor and I am reviewing the specifications for metal fabrications. The specs call out pickling before galvanization. I understand a little that pickling is a trade name for a chemical used to remove rust. How exactly is this process done in the factory? Can pickling be done in the field (i.e. on a job site)?
Sam Johnson
- Cotapaxi, Colorado, USA
A. Hi Sam. "Pickling" is not actually a "trade name" (which I consider to be like a trademark but without discussing the legality of the claim to ownership of the word), it is the name for the generic industrial process of removing mill scale. Often there is a mechanical 'scale breaking' step first, which passes the product through rollers designed to fracture the brittle scale to mechanically flake off what you can, and to offer more surface area for quicker chemical reaction. Then hydrochloric or sulfuric acid dissolves and removes the heavy mill scale before the steel mill ships the material to you.
People adopt shortcuts in their speech, so galvanizers and electroplaters sometimes call the rust removal or activating acid dip before their process "pickling", but it's a semantics issue; it's different and milder than what steel mill personnel would call 'pickling'.
It is possible to do field application of metal cleaning and processing chemicals and there are companies like Astropak and ATP Results who specialize in it. Good luck.
Q. Sir, I am a student carrying out a project work on PERFORMANCE OF VARIOUS PICKLING SOLUTIONS ON RUSTY MILD STEEL. Please assist me with the various types of pickling solutions for removing rust on mild steel including their compositions. I will be grateful.thank you
Chris M.
student - California, USA
A. Phosphoric acid is sold commercially as rust converter on eBay or Amazon [affil links] or naval jelly on eBay or Amazon [affil links] , Chris. This is best for deterring future rust. The more powerful acid for quickly dissolving rust is hydrochloric acid, sold commercially as muriatic acid on eBay or Amazon [affil links] , but this leaves the surface extremely active and prone to flash rusting. Sulfuric acid is also widely used; but at room temperature it is only a mild activator -- it needs to be very hot to actually function for pickling. Good luck.
Pickling of steel wire leaves green film/dust on it
Q. Hello All,
I am in the wire processing industry and I have a query about our pickling cycle. We have a batch pickling cycle in sulfuric acid. Our bath concentrations of sulfuric acid usually range between 12- 18% acid at around 140 - 170 °F (60 - 77 °C). For our Low to Mid carbon content grade steel wire we always notice a green surface that can be easily rubbed off after pickling and rinsing the coil. One can see the bare metal after the green surface is rubbed off.
Bryson Hayes
wire processing intern - Fort Wayne, Indiana, USA
June 12, 2008
A. Sounds like excessive attack of the wire by the acid (instead of just taking off the scale), followed by inadequate rinsing, thus leaving a film of ferrous sulfate on eBay or Amazon [affil links] .
You don't mention an inhibitor, which would minimise attack of the steel itself. Henkel has an inhibitor Rodine 85 which we have found excellent in 8-12% sulfuric running at 70 °C in a new hot-dip galvanizing plant.
I suggest an inhibitor to minimize metal attack, and improved rinsing as an added precaution.
Bill Reynolds
Bill Reynolds [deceased]
Q. I forgot to mention we use an inhibitor made by Crown Technology. It's called ACID AID LG10. Could the green surface just be a product of the Iron Sulfide that hasn't dissolved in the acid tank?
Bryson Hayes [returning]
A. Can't see any way ferrous sulfide could be present. Sulfur in the steel is present as manganese sulfide inclusions which are grey-coloured and microscopically small - there shouldn't be any iron sulfide at all. The sulfuric will generate hydrogen sulfide gas from the small amount of sulfur in the steel, and that gas simply escapes into the air.
Given that you use an inhibitor, and assuming that it works OK (I don't know it, so can have no opinion on its effectiveness), there will be little or no reaction on the surface of the steel as you come out of the pickle, so we're left just with a rinsing problem. Can't see your contaminant as being anything other than ferrous sulfate on eBay or Amazon [affil links] on the surface - problem is where does it come from? If you use a tank for rinsing, is the acid concentration in your rinse a bit high? Whether you use a tank or a spray rinse, if you leave some acid on the steel after the rinse then the inhibitor concentration in that residual acid will be too low to prevent reaction between the acid and steel, and you could form ferrous sulfate on eBay or Amazon [affil links] while the steel is drying.
Lots of suppositions and possibilities, I know, but maybe some help in deciding where to run specific tests.
Bill Reynolds
A. Sir,
I prefer Rodine 95 for sulfuric acid. The concentration is normally between about 1 part per 10,000 to 3 parts per 10,000 of mixed acid. Additionally you need a simple inhibitor test to know what is in solution. This test appears in an article of mine, now published in the journal, Metal Finishing.
Dr. Thomas H. Cook
Environmentally friendly pickling
Q. Is there an easy environmentally friendly way to remove pickling from steel to achieve a shiny surface?
Chi
Chi Leary
Artist - C Spgs., Colorado, USA
August 3, 2008
A. Hi, Chi. Pickling is the removal of scale. It's a process, it's not a surface coating, so I don't know what you mean by "remove pickling" -- maybe "remove scale"?
You can get to raw steel via mechanical methods like sandblasting or polishing if you want to avoid acids. But steel is a reactive surface; you can get it shiny momentarily but it is going to rust fairly quickly if not protected. Good luck.
Best sulfuric acid concentration?
Q. Dear Sir, I am wanting to use H2SO4 as pickling solution for mild steel, what is the best concentration of H2SO4?
Ahmed Y Musa
- Malaysia
September 14, 2008
A. Hi, Ahmed. The sulfuric acid needs to be heated, of course, so the first question back to you is what temperature are you trying to operate this pickling process at? Some people believe the best economy is achieved by pickling at a relatively high concentration and as the metal builds up, dilute it. It is claimed that the reduction in dissolved metal by dilution overcomes the dilution effect of the acid, so some aggressiveness is restored simply by adding water. Hopefully we can steer you to appropriate books about pickling if you can tell us a little more about your situation.
Q. Thanks a lot for quick reply, what I tried to do is to use a novel inhibitor in pickling process. Different temperatures and different inhibitor concentrations will be carried out in the test. I choose H2SO4 because it's very common in industry. If I use high concentration of H2SO4 then the more O2 dissolved, while low concentration means little effect of H2SO4 in pickling process, Please advice which concentration of H2SO4 I should use? Regards,
Ahmed Y Musa [returning] [returning]
National University of Malaysia - Bangi, Malaysia
A. Hi. I have heard that everything from 5 percent to 40 percent has been used. But most typical would probably be about 25 percent. Again, some people start out at higher concentration, then add water to get additional life.
Pickling vs. passivation
Q. What is the difference between passivation and pickling of steel?
Jerry Jenkins
Aerospace - Ogden, Utah, USA
November 6, 2008
A. Hi, Jerry. The page explains what pickling is, so I won't repeat that part. Passivation is never to my knowledge employed on steel --but you may be thinking of stainless steel? In that case passivation is the removal via acid of any remnants of plain steel that may have contaminated the stainless surface during fabrication operations. Passivation also supposedly chromium enriches the surface of the stainless. The purpose is to prevent rusting and improve corrosion resistance. It's most commonly done by immersion in nitric acid or citric acid .
Dimension reduction from pickling
Q. Hi. When hot rolled steel is pickled to remove rust, how much of the surface is removed? Is it a measurable amount or even noticeable? Many thanks
Albert Weatherill
Surveyor - Hull, Yorkshire, UK
January 16, 2009
A. Hi, Albert. Again we have semantics issues that may lead to misunderstanding. The steel mill removes the scale before they stock or ship the steel to you. So the user is not involved with scale removal, and some will say the user is not involved with pickling.
But during shipping, and during storage before and after shipping, rust will start to build up on the steel and you wish to remove this. Generally an acid dip to remove rust will involve the use of inhibitors to limit the attack on steel, and timing the immersion proportionally to the amount of rust. I can't give you a dimension of how much steel is removed, but it isn't much -- plating shops do rust removal from fasteners before plating them, and it rarely causes any dimensional problems even on fine-threaded small diameter fasteners.
Q. I am in the rollforming industry although we typically rollform painted or galvanized steel coil sometimes we roll uncoated steel. When we rollform uncoated steel the progressive bending process produces a fine dust we call mill scale. Does that mean all the mill scale is not completely removed during the Hydrochloric acid removal process or should I seek a new supplier?
Gary Jensen
buyer - Liberty Lake, Washington
November 10, 2010
Q. We want to reduce the iron content in the HCl acid used as a pickling solution in galvanizing plant.Since our sludge generation is more, by neutralising pickling waste with lime solution in Effluent Treatment Plant. Is there any simple / cost effective method available TO REDUCE THE IRON CONTENT IN THE HCl ACID by adding any chemical to precipitate / to settling down.
K . LENIN nadar
engineer - galvanizing - Madhya Pradesh - INDIA
December 10, 2009
thumbs up signFolks! Although it's human nature for more people to ask for help that to offer it, this is a public forum where people help each other out; it's not a place where I try to pose as an expert on every situation. I've been the sole responder on 9 questions on this page. If you found this page, you know at least something about the subject -- please try to help the other people out. Thanks!
thumbs up sign Ah, but Ted, you are responding so well to the questions. What more could I add? You are indeed a good expert!
A. The only comment I would add is around the topic of acid types & concentrations. HCl/muriatic or H2SO4 could both be used to pickle carbon/mild steel. The concentration ranges are usually kept low (mostly for fuming and health reasons), possibly between 5 - 25% (wt/vol).
As metals build (and discolor the solution), the reaction rate will begin to slow. Raising the temperature for any of these acids will increase the reaction rate (think basic chemistry). These parameters, plus the time in solution, can yield a good, clean, and bright surface. If the parameters are out of control, you might get a non-uniform appearance, etching, or even a dark/smut layer that is unappealing.
Asking for a specific concentration range, temperature, etc., is only helpful if you supply the type of steel (and shape/form) and more info. You might be better off to try a few conditions in a lab first.
Amanda Glass
- Springboro, Ohio, USA
thumbs up signThanks for the help, Amanda! Regards,
Q. We have thick walled MS pipes (ID 4, 6, 8 inch & length 20 ft) which have mill scale that must be removed. I would like to know what would be the best concentration of either H2SO4 or HCl (whichever is the best suitable for the application) to get the job done with minimum fumes (even after using the pickling inhibitors & wetting agents). Thanks.
Sachin Kanse
- Belgaum, Karnataka, India
July 16, 2011
Tip: Readers want to learn from your situation;
so some readers skip abstract questions.
Q. Does anyone know how large the market for pickling might be for the US?
Doug Vail
Student - Atlanta, Georgia
August 10, 2011
A. Hi Doug.
Do you understand exactly what you are looking for? Do you mean in steel mills only, or do you also mean at galvanizing shops and plating shops; how about for field application of pickling solutions to tanks, boilers, and piping in-situ? Pickling paste for weld areas? Are you including pickling of stainless steels, titanium, refractory metals, cast iron and aluminum castings, or just steel? Do you expect it to be expressed in gallons of HCl & H2SO4, or dollars spent in purchases of pickling solutions, or in square feet of product, or in man-hours expended?
I'm not trying to give you a hard time, Doug, just emphasizing a lesson for students that if you don't understand the teacher's question perfectly & exactly, you must ask your teacher to clarify it ... posting it and hoping that people's answers will clarify the question virtually never works, it only embroils you in Chinese Whispers. Good luck!
Q. I do have a question about the potential downsides of pickling. We've recently changed our suppliers of P&O A1011 hot rolled steel that we use exclusively for manufacturing purposes. However in doing so we've run into a problem in which the surface inclusions (craters) of the steel seem to resist the painting process we use, which has never been a problem in the past. We've had substantial rejection of product due to the steel rusting underneath the paint. Would it be a waste of time to investigate the possibility of the pickling process of this new manufacturer somehow chemically attacking our paint? Thanks for any help.
Kevin Salenski
- Sacramento, California, USA
January 10, 2012
A. Hi Kevin. I find that unlikely. However, I think it is very possible that your in-house pretreatment system is not able to deal with steel which has been less adequately prepared at the mill. For example, if you are using only a 3-stage iron phosphate before painting, it is possible that the process was adequate for the previously supplied steel but not the presently supplied steel.
Q. Hello, my question is if I'm pickling STEEL with a cathodic process with H2SO4 70% - 80% to high temperature like (80 °C) (30 - 60 seconds) is it possible to change physical properties of material, basically TENACITY? Thank you!
Carolina A
- Colombia
January 18, 2012
A. Hi, Carolina.
Unfortunately, the word "tenacity" did not translate well, so I'm not quite understanding your question. Might you mean "ductility"? Pickling is basically a surface phenomena which should not have too much effect on the underlying steel, with one exception that I can think of: Pickling, especially cathodic pickling, will introduce lots of hydrogen, and can cause hydrogen embrittlement of high strength steels -- even catastrophic hydrogen embrittlement.
Q. Hi, I am currently doing project of scale flakes on hot rolled coils. The scale normal appeared after some few days after temper mill or when the coils are store at the stockyard. Does the chemistry have an influence in the formation of this scale flake?
Godfrey Matshili
- South Africa
February 15, 2012
Q. Related topic, but a unique situation.
We use ~35% HCl heated to 135 °F with Enthone Actane 32 Inhibitor to remove a burn mark left after heat sealing a glass to to a Nickel/Iron alloy wire (electronic device)
We typically need 45-60 min with agitation to achieve a bright finish on the base metal. We keep the pickle for about 10 days and then decant and refresh, trying to keep some metal ions in solution rather than start from scratch. Recently we have had poor removal rates. We possibly have seen some re-rusting, which I am trying to sort out (maybe rinse water too acidic). Looking to evaluate the HCl concentration of the pickle. It starts at about 1.16 s.g. cold. Can't use this method after the dissolution of metals, right? Also, I have read that titrating for acid concentration is not so simple due to the ferric chloride on eBay or Amazon [affil links] . Would an ISE be the right tool for quick and accurate monitoring? Etch rate test maybe? This process is used prior to Tin plating.
Thanks for your thoughts.
Mike Russo
- Lake Mills, Wisconsin, USA
May 17, 2012
Q. Dear Sir,
We have steel pickling plant using HCl. We have water carry-over problem on both edges of the sheet. We have replaced squeeze rolls many times but failed to remove water contents. Please guide me how can I resolve this problem (the hardness of squeeze roll rubber is between 65 to 70 shore).
Zafar Majeed
- Karachi, Pakistan
August 11, 2012
12028
A. Dear Forum persons, regarding the post asking for help in removing water from the plate after pickling with HCl, we got some problems with this and was solved by reducing the concentration of HCl to 35% and adding some small amount (less then 1% volume of the tank) of a product that the market here calls "Lauril" its kind of a chemical used in soap and shampoo making. it helps in flowing the water but it was in our small metal shaping shop. really don't know if it will help in a steel mill.
Congratulations! for me this one is the best resources in finishing on the web !
Regards from Brazil!
Celio Santos
Arte Na Lata - Aruja, São Paulo, Brazil
Q. HI. I AM TRYING TO FIND OUT WHAT HRPA STANDS FOR. I KNOW HRPO IS HOT ROLLED PICKLED AND OIL BUT I DON'T SEEM TO FIND WHAT KIND OF FINISH IS HRPA.
LUIS MONTESDEOCA
IMPORT/EXPORT - laredo, Texas
November 7, 2012
A. Hi, Luis. It could be anything -- including a simple typo. Slang and acronyms are not specifications, and if they don't have a general meaning that is instantly and widely understood, thus saving us time, then they have no meaning at all. If a couple of minutes of googling gets you nowhere (and it got me nowhere), the acronym is meaningless and must be spelled out. Good luck.
A. Luis, I can't swear to it but likely HRPA = Hot Rolled Pickled Aluminum Killed.
Kevin Carroll
- Long Beach, California
I learnt that chelating agents like EDTA and oxalic acid are able to dissolve iron (III) oxide. Using this concept, I intentionally create a dark layer of oxide scale on the surface of a low alloy steel specimen by cooking it in an oven at 650 °F for 2 hours. Thereafter, I carried out several pickling tests by dipping the scaled surface with aqueous solutions of EDTA and also with aqueous solutions of oxalic acid, but the iron oxide scale still remained and do not seem to be dissolved in the same way as when dipped by a hydrochloric acid solution.
I had tried several concentrations of oxalic acid and EDTA until the saturation point, but to no avail. Do I need to modify the test such as by heating up the aqueous solution or by adding some form of catalyst which may help to lower down the activation energy before the iron oxide can be dissolved?
Many Thanks for your advice.
Lim Ronnie
Q. I wanted to know the composition of waste pickle solution. Is it mostly comprised of Fe2+ or Fe3+?
Prabath Gunasekara
- Colombo, Sapugaskanda, Sri Lanka
November 23, 2012
A. Iron dissolves as Fe 2+, but can be slowly oxidized by atmospheric oxygen to Fe 3+. However, as long as the bath is still being used for pickling, any Fe 3+ will be converted back to Fe 2+ in a reaction that dissolves more iron.
Lyle Kirman
Q. Dear sir,
I am doing a project to find out the retention time for pickling with HCl. I am considering concentration, weight and section in this.
Do I have to consider any other parameters?
Is there any instrument or method to find out surface cleanliness?
Is there any instrument or method to find out quantity of rust on a material?
Is there any projects , paper or any kind of literature about retention time for pickling which would help?
Please help.
Thanks in advance.
Sharath Bhat
- Jaipur, Rajasthan, India
December 11, 2012
Q. Suppose 23t (avg.) hot rolled coils are pickled in a push pull type continuous pickling line. The coils are mainly for auto industries. When should the acid be changed for good surface finish and better quality? I want to know what should be the frequency to change or top up acid or fresh addition of acid should take place in the acid tank of pickling line. e.g. after 8 coils or 10 coils or 12 coils, etc. Is there any thumb rule? Please help me.
Siddhartha Mukherjee
- Kolkata, West Bengal, India
January 19, 2013
Q. I want to know when should we change the pickling liquor? Is there any clear way to check the quality of pickling liquor?
Anuj Roperia
student - Chandigarh, India
January 22, 2013
A. Hi Anuj. I could say "don't ever change your pickling liquor". But then you would say "but it gradually loses effectiveness". Then I could say "okay, then change it when it loses too much effectiveness". Then you would say "how much loss of effectiveness is too much?" Then I could say "how much is too much for you?" ...
There are books that try to help you answer the question. It's a difficult question! Short of ordering an automated acid management system or studying books about the topic, I think the only other answer is that you have to start acquiring data comparing pickling time to rejects to costs of regeneration or replacement of acid and adopt a hypothesis and strategy, and refine it over time. Sorry that there is probably no quick answer.
in MS pickling process, will we have any change in the hardness of the surface?
DIPAK PRAJAPATI
- Ahmedabad, Gujarat, India
January 20, 2013
A. Hi Dipak. To my knowledge mild steel is not hardened or hardenable, and hardened steel is not pickled nor called MS, so I don't quite understand. Certainly, the mill scale and garbage on an non-pickled surface would lead to unreliable hardness readings. But please try your best to explain your situation more explicitly rather than posing your question in the abstract, with the countless "ifs ands & buts" that result :-)
Q. In mild steel pickling, we use hot rolled coil. I want to know is there any change of hardness of coil before & after pickling?
In our process, when sheet is passed through concentrated HCl tank, it shines; but after passing through water tank, sheet is yellowish. How can we handle this problem?
DIPAK PRAJAPATI [returning]
- ahmedabad,gujarat, India
January 26, 2013
A. Hi Dipak. I already tried to answer your first question, and I'm still not quite understanding. Why don't you simply measure the hardness before and after pickling and you'll know the answer for your situation for sure rather than asking for continuing guessing. Further we still haven't been told "why" you ask this question, which limits people's ability to read between the lines to help you out.
I suspect that your pickling acid leads to very rapid flash rusting, accounting for the yellowish appearance. I believe you should have inhibitors in the pickling acid, and then almost instantly get the steel to an alkaline state. Good luck!
Q. Thanks for your answers. It is refreshing to find real answers, so many sites just have half baked opinions.
I have a small project, steel weldments about 1 ft x 1 ft x 2 in, 20 pieces. Thin material is 0.065 in. These will be used in a wet environment, so I want to pickle before applying a good coating.
I plan to dip in HCl solution, followed with a tri-sodium phosphate neutralizing dip. Are there any readily available inhibitors available to protect the steel? Do I need to use inhibitor? Any suggestions would be useful.
Thanks for your help. I am no chemist, but an established Mechanical Engineer, so if you ever need anything in that arena please ask.
Fred Rosse
steam engineering - Princeton, New Jersey, USA
May 11, 2013
A. Thanks Fred. You are sort of on the right track but not precisely. If you were doing this commercially, you would want to apply an iron phosphate or zinc phosphate coating before painting. It is the phosphating, not the acid dip portion of it, that affords the corrosion protection.
For a simple small-volume one-time operation, I'd use the tri-sodium phosphate first, as a cleaning solution. If you can scrub with a tampico brush rather than just dipping, that would be better. Then rinse and apply a consumerized iron phosphate coating like Ospho [adv: Ospho on eBay or Amazon [affil links] .
Q. After pickling mild carbon steel, it has a red tint to it. It doesn't affect any further processing operations, but some customers don't like the fact that it looks different. Any idea what could be causing it?
We use HCl pickling solutions as well as H2SO4. It happens more on the HCl line. We try to re-clean and it usually helps but would want to eliminate this problem. On rare occasions if HCl doesn't clean it the sulfuric would do it.
Also one grade in particular (52100) almost all of the time turns out to have a greenish surface.
Jake Zervas
- Chicago Illinois
May 15, 2013
Q. I am an Electrical Engineer at a Steel Mill and I was given a project pertaining to pickling with HCl. What are the causes of flash rust/stain directly after the strip exits the acid tanks.
John Dockson
- Joliet, Illinois, United States
July 2, 2013
A. Jake, John,
The discoloration (red spots) appear because the HCl is an active etcher (etching goes in active phase). That is why not only oxides are removed from the surface, but the iron from the steel is impacted, and the red iron oxides are formed. It is not good for the steel part, because besides local formation of the rust, hydrogen (from the reaction) penetrates inside the steel surface, and cause local weak points for the metal strength.
"Passive" etching means that only oxides on the surface are impacted, and the actual metal does not react to the etching solution. And the hardness is not changed.
Contact us for suggestions on how to clean/etch carbon steel.
anna_berkovich
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
russamer labs banner
A. Hi John. Flash rusting is the natural state of affairs . . .
First, the acid and rinse water has iron dissolved in it which cannot remain dissolved as the solution evaporates, but must become rust. Second, the surface is extremely active, in acid condition, and activated by corrosive chlorides. As a minimum you must immediately rinse well and get the material into rust preservative or, at the least, into an alkaline condition. Good luck.
(You're on the 1st page of this topic)       Next page >
