Gun bluing and black oxide Q&A, Problems & Solutions
Q. I have been asked by several customers to look into installing a black oxide coating system to coat their parts. Information gathered so far tells me the 8# per gallon of caustic [caustic soda beads in bulk on Amazon [affil link] at 295 °F is a caustic blackening. Is this black oxiding or must I look into a furnace system which uses steam at 900-1100 °F? This process is described as black oxiding in sources.
Dave P. [last name deleted for privacy by Editor]
A. One of the most common "black oxide" process found in metal finishing operations is much like the hot caustic solution you described. Commercially available processes contain more than just caustic soda, i.e.: oxidizers and activators are also incorporated. They typically operate at 280 - 295 °F.
The action of the solution actually forms an iron oxide which is black in appearance. A well operated "hot oxide" will produce a beautiful black finish. To achieve a level of corrosion resistance, a rust preventative oil is applied after the black oxide coating has been applied ( and the part is thoroughly rinsed).
There are also room temperature black finishes for steel.
Trust this helps.
Ken Lemke
Ken Lemke
Burlington, Ontario, Canada
"Firearm Blueing & Browning"
by R. H. Angier
angier_firearmbluing
A. Steam at 900-1100 °F? 600 °C?
Is this a boiler operating under pressure (like those old steam locomotives)? Or is this a steam superheater? Native black coatings on Iron are Ferric Oxide (Fe2O3) or Magnetite (Fe3O4). Neither of which will long withstand high temp steam. Automotive parts often use a Iron Silicate, great for dry heat, but that too will decompose in high temp steam. For STP (standard temperature and pressure) boilers it is important to avoid all alkaline boiler conditions (we already assume no air/oxygen so stainless steel is out) and usually Permanganate, or other Oxidizing Anion, is added to prevent Rust pit formation. Permanganate will leave a black coating of Manganese Dioxide on the Iron which is protective and adheres relatively well. In ship boilers and chemical plants it is more usual to use Copper-Nickel ("German Silver") or similar alloys (Cu-Al-Mn) for boiler tubes as they are more stable to high temperature steam.
Stephen Jacks
- Mount Vernon, Washington, USA
July 24, 2011
Q. I also need help with black oxiding. I wish to black oxide a restored classic rifle. Many years ago I used this process to good effect. While I still have potassium nitrate, caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] , etc. I cannot find my notes with the correct formula, can anyone give me the proportions to obtain the correct super saturated solution. many thanks. Maurice
MAURICE S. [last name deleted for privacy by Editor]
Q. It seems to me this black oxide process is very interesting and has good commercial value. Is there any resource for a person like me to just read and learn about the technique? I do not intend to pry on any one's secret technology, just want to read something which is declassified.
Any info will help.
Thanks a bunch,
From the painted dessert of Arizona!
Gautam B. [last name deleted for privacy by Editor]
- Arizona
Ed. note: We now have a FAQ on Black Oxide on line, Gautam. There is a good chapter on Black Oxide in the Metal Finishing Guidebook.
RFQ: I spend a lot of money annually outsourcing for black oxide finishing on low carbon steels. I wish to invest on a system that would allow us to do it internally. Could some one please assist us. What equipment is required, sources for chemicals, specs. Thanks
Michael W. [last name deleted for privacy by Editor]
- Windsor, Ontario
Usually available on eBay; sometimes on AbeBooks or Amazon
(affil links) mfg_online
A. Hi Michael. There is a chapter on black oxiding in the Metal Finishing Guidebook ⇨
If you're unfamiliar with the process but think you might want to install the capacity to perform it in-house, you could retain a consultant to simultaneously design it and educate you. Or if you'd rather start the sequence by talking to salespeople, there are several suppliers including EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser], and Birchwood Technologies [a finishing.com supporting advertiser] who can get you up to speed. Good luck.
Q. I want to know the whole chemistry of the blackening process of iron. I am also interested in knowing the different methods of blackening of iron. How is the blackening film adherent to the parent metal?
rajesh s. [last name deleted for privacy by Editor]
- India
A. Hi, Rajesh. The blackened surface is very thin and is just an oxide coating (sort of a black rust), so adhesion is quite good. Other black coatings include cold blackening (based on selenium deposits), black chrome plating, black zinc (zinc plating followed by black chromating), black nickel plating, and salt bath nitriding. Good luck.
Q. I'm wondering whether or not black oxidizing changes the coefficient of friction of a part? I'm looking into a coating that I could use on my inner Fork Tubes (motorcycle suspension) that would have a black/grey color and would either keep the coefficient of friction I have now or improve it. I looked at TiN and saw the coefficient of friction improves significantly, but was wondering if there was another material with a black color that does the same? Thanks.
Nic Burke
Hobbyist - Federal Way, Washington
A. Hi, Nic. The blackened surface is very thin and probably not wear resistant enough for such an application. Black chromium plating or salt bath nitriding could probably satisfy your needs. Good luck.
No! No! No!
Not for Food Service!
Teflon/ Moly Oven Cure Firearm Finish
brownellsTeflonOvencureLiquid
A. Nic, Dupont makes a product that is similar to Cookware coating. You paint this stuff on and bake it in an oven at about 400 Deg. If you go to their website you can find all the info you want.
Tim Wyatt
- Port Richey, Florida
Ed. note: Tim is probably correct, but readers must not make the mistake of thinking that "similar to Cookware coating" means safe to eat off of. No!
Q. I am working with a corrosion resist manufacturing product company. I would like to know detail process of blackening. I want to know what is the process, which raw materials are used, and on which parts it can be applicable.
Sujit Patil
plating shop employee - sangli, maharastra, India
March 2, 2009
A. You need a gunsmith. I happen to be a gunsmith of 25 years. I guess you are lucky I stumbled here by mistake. The simple formula is as follows. 1 gallon of water, 2 pounds of sodium nitrate ⇦ on Amazon [affil link] (or common sodium nitrate fertilizer), 5 pounds of sodium hydroxide (common lye). Operating temperature between 280 deg and 310 deg Fahrenheit. Solution MUST be boiling! Too hot and not boiling, add water or parts will rust (red oxide). Too cold or too cold and boiling, no reaction (no black oxide). Boil off water until temperature comes up. Over 301^310 deg Fahrenheit will burn the salts and kill the solution. Chemicals have to be added periodically to replace carry out. Solution dies after a certain amount of contaminants have been carried In. Certain chemicals like aluminum will KILL THE BATH IMMEDIATELY! Rod
rod henrickson
Rod Henrickson
gunsmith - Edmonton, Alberta, Canada
A. To further my last post there was a typo. Over 301 °F will burn the salts and kill the solution. It should read that exceeding temperatures of 310 °F will kill the solution. In truth it is about 330 degrees but the solution at the bottom of the tank is often much hotter than the solution at whatever depth the thermometer happens to be sitting at. It is wise never to exceed 310 degrees just to be on the safe side.
In the firearms industry it costs about $100 to $200 just to mix a new batch of chemicals. That is only about 10 or 20 gallons. I would imagine tanks large enough to blue oilfield or automotive components would have to be much larger. Enough said, DON'T overheat the solution. Bath time is not the critical thing in caustic bluing. Temperature is! If the temperature is correct for the type of steel that you are bluing the parts can be fully blued in 3 minutes or less. Remember that the solution must be boiling or red oxide will form. Don't ask me why I'm not a chemist but after doing it for 25 years I know for a fact that it is no old wives tale. The amount of water regulates the temperature of the solution not the heat source. Too hot, add water. Too cold, boil off some water. Watch the temperature and keep the solution at a rolling boil.
Plain old leaded, cold roll steel will turn dark black blue at around 280 degrees. Chrome molybdenum steel will turn deep blue at 300 degrees. Nickel steel will turn a slightly lighter shade of blue at 305 to 315 degrees. Chrome vanadium steel will turn a deep orchid purple at 300 to 315 degrees. The amount of rust prevention is dependent on the type of finish the part has, careful maintenance, i.e., keeping oil on the blued surface and the steel type. The higher the polish on the part the more resistance it will have to rust. The oil used should be non detergent. WD-40 ⇦ on eBay or Amazon [affil link] and other detergent oils will strip the blue over time. Blued chrome vanadium is the toughest. Nickel steel the next. Chrome molybdenum and lastly cold roll steel.
Make sure all parts are completely cleaned and degreased before putting them into the tanks. Certain chemicals will kill the bath as well as some metals. An ounce of aluminum will kill 10 gallons of solution. As well as heavily chlorinated water. If you find your baths dying try using lake or river water. Although it will not really harm the bath avoid lead or parts that have been soft soldered together. The bath loves to eat lead.
This solution will not blue stainless steel. It will with the addition of certain chemicals, one of which happens to be sodium cyanide. I know how to make a stainless bath but I will never do it and I won't give you the formula, so don't ask! Besides it is against the law to possess sodium cyanide outside of a laboratory in Canada and I imagine it is in the USA as well. If it is not, it should be. If you must turn stainless steel black have it black chromed, Teflon or powder coated. There are a dozen outlets in every city that offer this. --Rod
rod henrickson
Rod Henrickson
A. Just an FYI, there are lots of companies around the country that are set up to do the work for you. Cost is very reasonable. For instance we charge a $10 minimum for the first 10 pounds, and 22 cents a pound there after. Don't be surprised if they charge a set rate for fire arms. Stainless is also done here. The mixture is commercially produced, so no need to handle cyanide or any other dangerous chemicals.
If you have any reservations about the safety of the process, take it to the professionals. Black oxide chemical mixtures will eat right through your cloths and skin in a matter of seconds. Trust me, 40 years of it and I've had my fairHi Sanjeev share of burns.
Michael Spencer
- Dayton, Ohio
October 14, 2009
Q. Hello everyone.
I am a manufacturer of polished stainless steel (304). Can anyone tell me if it's possible to give a black finish to this material without losing the bright appearance.
Best regards
Carlos Costa
- Portugal
October 28, 2009
A. Hi, Carlos. A bright polished part should stay polished in the black oxide process. Other bright finishing options include titanium coating it, black chrome plating it, or doing a special stainless steel anodizing process.
A. Dear Carlos,
Black chromium plating can give you black surface and more or less, brightness would remain.
But in some cases, chromium plated is forbidden, and you need to do by some different way.
Black Ruthenium plating may help you if the cost is still in your budget.
Hope this can help.
Best Regards,
Anh Duc
- Ho Chi Minh City, Vietnam
January 6, 2010
Q. Rust Preventive oil and wax has been recommended to protect black oxidised part from corrosion. Can anyone know how to apply the oil / wax just after black oxidizing when there is black oxidizing solution or droplets present on the metal surface?
Mabel Davidson
- Jamshedpur
November 10, 2009
A. Mabel Davidson
For production work the best is to have 2 boil out tanks. One pure water which you allow the parts to boil in for 15 or 20 minutes to remove trapped salt and the second is a boiling tank with water soluble oil and water displacement oil. The water soluble oil will get into the nooks and cranny's and the displacement oil which will float on top will leave a film of oil on the parts when they are drawn out of the solution. The same procedure is used for wax's. If you are just doing a few items water displacement oil can be sprayed on after the parts have been taken out of the boil out tanks.
rod henrickson
Rod Henrickson
February 21, 2012
Q. Hi. I have just read the first few messages and am looking for help in blacking particular types of parts. I work with steel on a regular basis and am having problems with the black oxide process. It seems as though my tank only wants to blacken smaller type parts but I need it to work on much larger parts. Also I've noticed that GPS (ground and polished steel) does not take as well as cold rolled steel. My temp does not exceed 295° F and does not drop below 291° F. The parts that sit on the bottom of the basket do not want to blacken. What do I need to do?
Shane Brumlow
- Bartow, Georgia, U.S.A.
November 30, 2011
A. Hi, Shane.
I guess reading just "the first few messages" didn't cut it :-)
Please carefully read Rod Henrickson's message about boiling. You must have your solution boiling; therefore you use concentration to control your temperature, not heat input. After you are adjusted so the solution boils at your 291 to 295 °F, and it isn't possible to make it hotter via more heat input, then you are operating in the mode that Rod suggests. What is your heating mechanism -- gas burners below the tank? Good luck.
A. Shane Brumlow
You are having heating issues. Large parts can take forever to warm up to the temperature of the bath. Contrary to what people think the bottom of the tank is actually the coldest area of the tank depending on your heating system. The tank works like a coffee percolator. Water on the bottom boils and shoots up to the top and often flows back down the sides to the bottom as it cools. It can some times do the opposite and boil up the sides leaving a cool spot of returning solution in the center. Make sure your tanks are at a rolling boil so you get good circulation of solution. KEEP PARTS ABOUT 1 INCH OFF THE BOTTOM. With large parts you can pre-heat them over a soft flame to about 250 before immersion and it will save you some tank time. Also, you may have to take your tanks over 300° F to get large parts to blue as the part never does get to bath temperature.
rod henrickson
Rod Henrickson
I have manufactured a part of machine (collet) of material EN-19 grade which has been black-oxide used for core cutting machine. For some reasons I had to rework on its part welded with S.S material. I performed the black-oxide process again on it but the welded s.s part remains colorless without showing black finish on it.
Please give me a good suggestion.
Thanks & Regards,
Amit Nikam
- Pune, Maharashtra, India
December 1, 2011
A. Hi, Amit.
Ron Henrickson suggests above that cyanide is needed to blacken stainless steel. I am not sure if this is the case, but proprietary blackening solutions for stainless steel are available from the major process suppliers, and you could inquire of them whether they contain cyanide. Good luck.
Amit Nikam
There are baths made for stainless steel that might solve your problem. I believe they are non-cyanide or low cyanide and while certain precautions must be taken they are relatively safe to use. I have used some of them in the past and while they are fussy they do work. If no one here sells salts for stainless I believe the stuff I used to use was DU-LITE. It's a USA company but I believe they ship world wide.
rod henrickson
Rod Henrickson
I am wondering the way to thicken the black oxide layer for steel, normally, I can have 0.5 micro after treatment, under not high temperature and certain pressure. I am wondering if there any possibility to increase the thickness to 1 micro, by which process? the temperature is limited because I don't want to change the microstructure of the steel, it is pearlite, and I need to keep the strength at 1000 mpa.
Thank you very much for this.
Chu Zhang
- Sweden
January 24, 2012
A. Chu Zhang
Bluing is not a plating. It actually changes the iron to Fe3O4. The process will only change iron which is exposed to the chemical bath. Once the exposed iron is converted to Fe3O4 the chemical change stops. There is no real way to increase the depth of the layer. You can leave the parts in the bath for an exaggerated length of time to make sure all exposed iron has been converted but you eventually reach a point of diminishing returns where you are simply doing no good.
rod henrickson
Rod Henrickson
1. I black-oxide bicycle parts. I changed over from H2SO4 to HCl a couple of days back and seem to be getting better results at pickling. Is HCl better suited for pickling?
2. How can I prevent red oxide deposits forming on the top layer? I read about rectifiers and inhibitors being helpful in this case? What are these and how I can I use them?
Jas
Jasmeet Bhogal
- Ldh, Pjb, India
February 17, 2012
A. Hi Jasmeet.
1. At room temperature HCl will be a much more powerful pickling acid than H2SO4. The latter must be heated to near boiling to be a powerful pickling acid.
2. I am not familiar with a black oxide finish having red rust built in such that it needs rectifiers or inhibitors. I think you may not be doing it right and should very carefully consider the advice from Rod and others about the need for the solution to be both boiling and at the right temperature. Good luck.
thumbs up sign 1. Well, I have got better results with HCl. One because I don't require a heater anymore. Lesser fumes (I am not sure why, because I read that H2SO4 will give lesser fumes than HCl. But I have got opposite results). And no crystallization of iron as it used to happen with H2SO4.
Q. 2. Now the only problem I am left with is deposition of salt on the top surface of the items. I am still searching for chemicals which will act as rectifiers or inhibitors. Any help on this is much appreciated.
Jasmeet Bhogal [returning]
- Ldh, Pjb, India
Q. Hi, I'm James -- what is the best way to clean the material after blackening process.
I used to rinse in water and clean it with wood rust. This process takes a long time, is there any better way to overcome it. Please help me
Thank You
James
INDIA
James R. [last name deleted for privacy by Editor]
- Guindy, Tamil Nadu, INDIA
February 29, 2012
A. Hi, James.
I'm not quite sure what you mean by "clean after blackening". The parts need to be rinsed and then oiled or waxed. A "clean", i.e., oil-free black oxide coating will flash rust almost immediately. It is the oil or wax, not the black oxide, that provides any corrosion resistance.
A. To James R,
The only way to get residual salts off parts is to boil them in water for about 20 minutes and then oil or wax the parts. If there are no nooks and cranny's for the salt to hide in you can short cut this by dipping and rinsing in boiling water. The solutions that would kill the salts instantly like acids also remove the bluing so there is no quick chemical way to deal with carried over salts. You just have to charge for the time in the boil out or you will get salt bleeding later on.
rod henrickson
Rod Henrickson
How does heat treatment affect black oxidizing? My heat treated parts take lesser time to blacken than softer (Un-heat-treated) parts.
The tank I use for blackening is made of stainless steel and it has a mild steel jacket around it and a mild steel stand at the bottom of the SS tank. I have read that the tank should be made out of MS. Is it absolutely necessary to have MS tank?
Jasmeet Bhogal
- Ldh, Pjb, India
March 5, 2012
Q. When specifying black oxide for minimal corrosion prevention, is the after finish (oil or wax) permanent? In other words, will the part be oily or waxy to the touch and will the oil or wax wear off over time? I need long term protection and only do this one time.
Jim Buckley
- Cleveland, Ohio, USA
April 4, 2012
A. Hi Jim.
Black oxide is the finish on most rifle barrels, and must be treated "lovingly" like gun enthusiasts treat their firearms, and be carefully maintained. It doesn't sound like the right finish for your needs. You may need black chrome, black nickel, or black zinc plating, or salt bath nitriding. Good luck.
Q. Hi can anyone tell me about black oxide, its treatment process, chemicals required, how to make its mix, concentration of the chemical, its tanks or bath?
Sanjeev Gupta
- Kanpur, Uttar Pradesh and INDIA
May 19, 2012
A. Hi Sanjeev. We've referred you to our FAQ and the Metal Finishing Guidebook for introductory info, and black oxiding has already been the topic of the previous 30+ postings. Please try you best to phrase your questions in terms of what has already been said, and thus continue to build upon what is here, rather than asking that we start over :-)
Thanks for your understanding.
Q. We are Black Oxiding gun magazines for a customer. The process is stamping the part, heat treating, tumbling and then Black Oxide. We are having issues with uneven plating on the magazine. Most of the part looks deep black and then you get a area of the part that has a lighter streak. This is a good amount of volume so we would like to get this correct. I have asked some people about this. Some say it would be the tumbling and others say it could be the heat treat....Is there anything that I can do on our end?
Paul N.
- Waterbury, Connecticut, USA
September 18, 2012
A. The problem is common with stamped parts. Bending and stretching the steel causes different hardness and a difference in the actual surface polish of the metal and this is what is giving you the uneven color. You can anneal the material after stamping or try burnishing the parts in a revolving drum with small ceramic pyramids or steel balls.
There are a couple cheap tests you could preform just to test this theory. I would first try bead blasting the part with small steel balls to even the surface hardness and try bluing it. This failing heat one of the parts to a dull red with an even flame then remove and let it cool slowly and evenly in air and test blue.
I have had trouble bluing some Remington magazines after polishing and have resorted to these tricks. I suspect Remington beats this problem by blueing their magazines with a potassium bath which operates at 800-900 degrees although I have never asked.
rod henrickson
Rod Henrickson
Q. Which: Potassium Nitrate or Sodium Nitrate, with the Sodium Hydroxide and why?
Terrence G Rust
Fire Arm refinishing - East London South Africa - East London South Africa
February 5, 2013
A. It really does not matter whether you use sodium nitrate ⇦ on Amazon [affil link] , potassium nitrate or ammonium nitrate. All that you are after is the niters. Sodium nitrate is always easier to get because of legal issues. Potassium nitrate can be converted to gunpowder quite simply and it can also be converted to Trinitrotoluene with less than high school chemistry. Ammonium nitrate can be combined with hydrocarbons to form an explosive called Anfo. Because of that and 911 there have been restrictions put on these two chemicals as of late.
rod henrickson
Rod Henrickson
Q. Respected sir,
I started my own blackodizing plant but after blackodizing material gets red somewhere so give me some advice please.
Abhijeet Kulkarni
- Aurangabad, Maharashtra, India
August 26, 2013
A. Hi Abhijeet. In any process, you have a dozen or more parameters which must be right to get the right result, so it's rarely a question of "if the parts are red, the problem is surely this ..."
Still, few people understand the lesson that Rod Henrickson gives above (I know I didn't get it at first), so it is important to take the time to carefully study it ... The solution must be both boiling AND at the right temperature, which in turn indicates that it's at the right concentration as well as the right temperature. Good luck.
A. Does the red rub off? If so, there is colloidal iron frozen on the surface. If not, there are several reasons the parts can turn red. What is the alloy?
Steve Loudermilk
- Prairie Grove, Arkansas, USA
September 13, 2013
Q. I would like to ask the causes of rust after metal blackening.
Grace J.
- Cebu, Phils.
September 20, 2013
A. Hi Grace,
Poor rinsing, leaving the parts wet, not using any sealers, not using any supplementary finishes, humid conditions, poor storage conditions...
More detail needed before anyone can give you a sensible answer.
Brian Terry
Q. We regularly do blackodising on Mild Steel and High Tensile Steel Nuts and bolt. We use a ratio of mixing chemicals to prepare bath as follows:
(1) Caustic Soda ⇦liquid caustic soda in bulk on Amazon [affil link] 80%
(2) Sodium Nitrite ⇦ on Amazon [affil link] 10% &
(3) Sodium Nitrate ⇦ on Amazon [affil link] 10%.
WE ARE NOT ABLE TO ACHIEVE A CONSISTENT RESULT. Sometimes the fasteners are getting red rust like colour.
A) Is there a online chemical test where we can know the balance of the bath?
B)Can anyone specifically tell me what are the functions of all the above chemicals?
C) why are the nut bolts getting red in colour?
Any serious reply will be of great help to us.
Chintan
Chintan Mehta
- Bhavnagar, Gujarat, India
April 25, 2014
A. Hi Chintin. As you see, we appended your inquiry to a thread where experts like Rod Henrickson have explained the process in excellent detail. I urge you to carefully study his comments as my guess is that operational details rather than the precise ratio of chemicals is the origin of your inconsistencies. Good luck.
Black oxide boils at 260 ° no matter what we do
Q. Hi -
I was reading this thread, it's pretty interesting. We're having an issue with one of our blackening tanks: it won't get to 305 degrees, no matter how we adjust the solution; it's boiling around 260, tops. Does the water get deionized over time or something? There are also a few inches of sludge/slurry at the bottom that I'm going to have cleaned today but obviously want to know what the issue is. It's gas-fired and I don't think lack of BTU's is the issue.
Peter Brown
- Middletown Connecticut USA
June 2, 2014
A. Peter,
Maybe you already tried these ideas: 1. Removing the sludge may fix the problem. 2. Check heat exchanger and burner for leaks. Also check flume if appropriate. Gas absorbing into the solution can reduce b.p. 3. I assume you already checked your temperature measuring device and location so you might try adding a little urea or similar additive to see if it helps but that is a more risky option.
blake kneedler
Blake Kneedler
Boiling point is directly related to the concentration of dissolved chemicals.
If you cannot raise the boiling temperature above 260, then:
- Your temperature measurement is inaccurate, or
- You do not have enough heat input, possibly because of a layer of sludge or undersize burner(s), or
- Your temperature/water feed controller is inaccurate, or
- Your chemical concentrations are low, or
- You are using an improper mixture of home brew.
Since the first sentence above is accepted fact, check the above suggested 5 possible faults.
What blackening process do OEMs use
Q. Being heavily involved in vintage auto restoration, can anyone tell me the specific type blackening used by OEM suppliers for automotive bolts and parts? Thanks.
orrin tucker
- YOUNGSTOWN OHIO
December 16, 2015
A. Hi Orrin. The hot black oxide process first described by Ken Lemke and Rod Henrickson is surely what OEMs specify for general "blackened" parts. But there are probably occasions where more corrosion resistance is required, in which case zinc plating with black chromate is specified.
Q. My parts are not full blackened. There are spots on the surface. Guide me please.
Osama Farooq
- rawalpindi Pakistan
February 27, 2017
? Hi Hi Osama,
Please post what kind of parts you are blackening, what they are made of, what your sequence of operation is, and the parameters of your black oxide tank (temperature, boiling?, time, concentrations, etc.) People can't tell you what you might be doing wrong until you tell them what you are doing. Thanks!
Q. Process sequence is as follows:
1. degreasing
2. pickling
3. blackening
4. chromic acid dipping
5. oiling
I am using 650 g/L of sodium hydroxide and 400 g/l of sodium nitrite ⇦ on Amazon [affil link] . My solution starts to boil at about 140 °C. I have heard that black oxidation solution starts rising when it boils, but in my case only bubbles are formed on the surface of the solution.
The time I am giving to the parts is about 1 hour. I have tried doing it on quite a few types of steels but no success.
Osama Farooq [returning]
March 4, 2017
A. Hi again. All I know if what I read in the textbooks and forums ... but are you sure you're using sodium nitrite, no sodium nitrate? Rod Henrickson says he uses only sodium nitrate (2 pounds/ gallon = 240 g/l), and some textbooks suggest a mix of nitrite and nitrate, but I'm not aware of using sodium nitrite without sodium nitrate, as it sounds to me like you might not have sufficient oxidation power.
I don't understand what you mean when you say that you're supposed to see "black oxidation solution starts rising" but it's not happening -- but the solution must be boiling.
The process should only take a few minutes, not an hour.
! I have got to the root of the problem actually I was giving way more time to the parts after pickling. It resulted in the oxidation of the surface of the parts hence they were not being properly black oxidised.
Sodium nitrite ⇦ on Amazon [affil link] can be used as I am using it and it has also passed the oxalic acid spot test.
- rawalpindi, Pakistan
March 7, 2017
thumbs up sign Thanks for the feedback, Osama. Good to know that sodium nitrite can work with sodium nitrite.
A. Osama, delete the chromic acid it will destroy the black oxide finish immediately, If you must pickle the metal use the following in this order:
degrease with hot caustic solution
rinse
Pickle with acid (light sandblasting will produce the same effect and a lot safer) Pickle if you must, then rinse with Boiling water then into the bluing solution; when the black oxide finish is a good deep color remove into a hot water rinse then into a hot soluble oil bath, be careful of soluble oil concentrations to avoid fire.
The old masters used a 300 grit finish and then blued the part, some applications call for use of a buffing wheel and abrasive wax; care and skill is needed with these devices they will hollow around screw holes.
Chromic acid will dissolve finish and I think should be avoided at all costs.
Read Rod Henrickson's comments -- he is 100% correct in all that he has said. If You read and digest his comments there is little else to know in the short term.
You do not often get such detailed information offered freely!
Vaughn Gunthorpe
- Plainland Qld Australia
A. This is in reply to Vaughn's comment the other day:
If following the MIL-SPEC, a chromic acid dip will not destroy the black oxide finish. It calls for a final rinse that is 8 oz per 100 gallons of water. Even though the pH is quite low, the concentration is too weak to attack the finish. Minimum of 30 seconds at elevated temperatures will help corrosion resistance, not destroy it.
Jameson Grout
- Indian Orchard, Massachusetts
thumbs up sign  Thanks Jameson. MIL-DTL-13924 [⇦ this spec on DLA] says you are correct.
Q. Sometimes we use glycerol to remove high iron content from the bath. Are there any alternatives?
Phahad hashim
- Dubai, UAE
June 18, 2017
Q. My situation: I don't know how to prepare for blacking can you explain the blacking process and chemical ratio?
Manoj Kumar Vn
Shop employee - Bangalore, Karnataka, India
July 25, 2018
A. Hi Manoj. We added your inquiry to a thread that answers your question. Feel free to add any followups or requests for clarification on anything you didn't follow. Good luck.
Q. Good day!
I read and followed the instructions I learned on this thread but I always have a problem with a certain gun barrel. They call it "military barrel". When I blue it, it turns red. I don't know what kind of steel they use so I don't know how to adjust my mixture. I use caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] and sodium nitrate ⇦ on Amazon [affil link] . Temp is between 280 °F to 290 °F. I think I need to make it up until 300 °F to see if it will turn black.
Hope someone could help me or maybe give me advise. Thank you and more power.
Inocencio Abril Mayo III, Asst. Gunsmith
Gunshop - Al Araqi, Ad Dhahirah, Oman
February 17, 2020
birchwoodYouTubeBlackOxide
