Summary for blued vs painted Discussion
blued vs painted is the key question in this antique typewriter thread. Alex T. asks how to tell whether a black matte finish on some parts is blued or simply painted. The thread’s quickstart note explains that bluing, or black oxiding, is a very thin finish created in a hot caustic nitrate/nitrite bath; matte parts often look black, while polished parts can come out navy blue. It also notes that cold bluing is less durable and less corrosion resistant. In the only direct answer, Goran Budija advises testing the finish with solvents such as acetone, white spirit, or paint stripper: if the coating dissolves, it is paint; if it resists most solvents, it is more likely a patina or blued finish. The advice is practical but cautious, since the thread does not provide a definitive non-destructive identification method.
“Bluing” (also called “black oxiding”) is a process where parts are immersed in a very hot (230+ °F) solution, heavy in caustic soda and nitrates and/or nitrites to build a stable black rust on them. If the parts are rather matte to start with, they’ll usually look black; if the parts are highly polished, they usually come out with a jeweled navy blue look.
Although bluing is not very corrosion resistant except when waxed or oiled, it is attractive, and the coating is very very thin, almost never affecting any clearances or tolerances.
“Cold bluing” / “room temperature blackening” is a process which simulates hot black oxiding, but is not as corrosion resistant, thin, or free from smut.
Q. I’m restoring an antique typewriter. Some of the parts have a black matte finish. How can I tell whether they are blued or just painted?
Alex T.
Hobbyist – Hartford, CT
September 15, 2025
This is a meeting place for camaraderie & sharing, not a free consultancy. So some readers don’t engage with anonymous posters.
A. Try solvents like acetone or white spirit or paint stripper on it; if it can be dissolved then it is paint, patinas are resistant to most solvents.Hope it helps and good luck!
– Cerovski vrh Coatia
September 23, 2025
