A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4876
Chromate Conversion of Aluminum Casting Alloys
(2000)
I am trying to establish if there is any limitation associated with chromate conversion of aluminum casting alloys such as 355 or 356. Thanks, Gary
Gary Wonacott
composites - San Diego, California
(2000)
355 - 1.3 copper, 5 Si, 0.5 Mg. 356 - 7 Si,0.3 Mg. These alloying constituents create difficulty in chromating, and may reduce the protection, and affect the appearance of the chromate. Proper cleaning and pretreatment can improve the effect of a final chromate conversion coating. See www.finishing.com/chemicals/ for chemicals, and the Testing/ directory if you have some parts you want to test.
tom pullizzi monitor
Tom Pullizzi
Falls Township,
   Pennsylvania
simultaneous (2000)
Degease using non-etch alkali cleaner. Warm phosphoric acid based etch cleaners may be used with care, possibly fluoride accelerated. Hexavalent chromate processes are the only ones that will give satisfactory performance bare or painted.
Use high pointage chrome content and maximise coating weight without getting loose coatings. Aim for a rich golden yellow colour. Do not use hot water rinsing and keep dry-off below 100 deg C Roger
Roger Bridger
- Croydon UK
(2000)
The only limitation I know of surface wise is the limitation on corrosion resistance associated with castings, its around 1/4 to 1/6 the corrosion resistance associated with wrought material. Other than that, there's no downfalls per se with chromating casting material, it does provide increased resistance, but to what extent is questionable.
Matthew Stiltner
plating company - Toledo, Ohio
(2000)
Casting aluminium is a problematic becouse of the hig silicone content in the alloy . Special treatment for removing the silicone obstcle with properietry formulation can remove the obstcle , in my career I developed and sold product for that problem.
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Comment to THIS thread START a NEW threadView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
