Recovery of fine floating gold
thumbs up sign So this is super awesome. I've been experimenting with the process and I think I've done it for micro fine gold. Listen carefully: wet your target dirt; next put in pan once nice and wet. Go ahead n fill it up with water about 3/4 of the way of your pan right. Shake up to disturb water -- basically going brown. Pour off "lightly", not too lightly, but don't go to bottom of pan, just go easy till you get to that point using plastic/glass container.
Wait 2 days-ish for the poured off water to settle all the way clear. Lightly pour that off; put in heat to wick the moisture faster. I literally used my oven on warm but crack it and the windows -- never know what's in your sulfides (better to be safe than sorry). Okay, when it dries, scrape bottom and go easy when you melt. I make mud pies because all I have is a hand torch lol. So take that roasted material, throw it back in your pan and check it out.
I'm pretty sure I actually just discovered a 100% safe method with no chemicals, only water. Call me crazy, lol, do it; took me 6 years to tinker around to see this and, wow, results are just wooowww.
Skye Lewis
- Rock Springs, Wyoming
March 29, 2023
Ed. note: We assume that by "my oven" Skye means her dedicated gold roasting oven. Never put chemical processing stuff in a kitchen oven!
RECOMMENDED BOOKS ON GOLD RECOVERY
refining_clark2014
"Gold Refining" by Donald Clark (2014)
refining_gee
"Recovering Precious Metals" by George E. Gee (2002)
refining_ammen
"Recovery And Refining Of Precious Metals" by C.W. Ammen (1984)
refining_hoke
"Refining Precious Metal Wastes" by C. M. Hoke (1982)
refining_gajda
"Gold Refining" by George Gajda (1977)
Q. Love this ... I wanna try.
I got confused after step of waiting for water to go clear. I bake it ok warm but ... THEN what?! Use a hand torch to cook gold out? I am really hopeful your steps will work and just need the specifics.
VaTeach Beacher
- Virginia Beach, Virginia
Q. This is very similar to how I've been attempting to recover micro fine gold, very cool! I see this post is almost a year old, Have you made any more headway in improving the process?
GD Applonie
- Washoe valley, Nevada
January 26, 2024
Gold Prospecting Equipment
gold_prospecting_equipment
Q. I am from the North East, in Lynn, Massachusetts and it seems I have only ever heard of Gold Prospectors like some weird mythology that Massachusetts has NO GOLD and I am not sure if this state wasn't prospected by many people because the place was already settled by territorial people who weren't going to let other people come in and prospect their territory. And those who did notoriously said there was ZERO GOLD and I think that's been ran with ...
THE OLD TIMERS WEREN'T LOOKING FOR FLOUR GOLD AND MICROFINE AS WELL AS GOLD MIXED WITH sulphateS. I THINK THEY ONLY SERIOUSLY PROSPECTED LODE GOLD NUGGETS RIGHT OFF THE VEIN NO HASSLE.
ANYWAYS I DID MY HOMEWORK AND FOUND OUT MY AREA MAY BE UNIQUE AS MY CITY, I FOUND OUT, IS RIGHT ON TOP OF A NOW EXTINCT VOLCANIC COMPLEX AS WELL AS WE REPRESENT THE LINE THE GLACIAL BARRIER.
I AM FAIRLY SURE I HAVE FOUND MULTIPLE DIFFERENT TYPES OF GOLD DEPOSITS a placer deposit which happens to be in my back yard --UNBELIEVABLE! And I believe I found, while crawling in the dark in the rain with a flashlight, a dissemination of gold or maybe its pyrite running through the barrier of the pegmatitic granite, and blue quartzite also running through and hiding in the biotite mica of some porphyry granite. It is in veinlets of the pegmatitic granite
I really need help figuring out what I have really found. Like I said, I am new to this but fell in love with Gold and Rocks in the process I have all the time in the world to make this my life's work doing this. I want to learn and ultimately think I may have tripped on the proverbial 35 pd gold nugget...
Oh the placer in my back yard which has stringer quartz veins running through rock seems to have an astonishing amount of flour gold ;at least it sure does look like it to me. Someone please help I will take photos of some things and post them, thanks.
Michael R [last name deleted]
New Prospector - Lynn, Massachusetts
September 3, 2023
Q. I am retired and am a recreational prospector with a small (3 in.) suction dredge and a creek with a little gold worth messing with. Some of the gold is so fine it is floater and I figure there is maybe an economical way to capture this like a revolving screen barrel with an electrolysis setup of some kind to attract the fine gold and maybe adhere to the screen. If this is possible and economically feasible I would sure like to know...
Dan L [last name deleted for privacy due to age of posting]
- Menard, Texas
"Gold Mining in the 21st Century: The Complete Book of Modern Gold Mining Procedures"
by Dave McCracken
gold_mining_modern
A. Dan:
I have done quite a bit of dredging with a 3 inch in the past also. I've never run into floating gold, but have run into flour gold. The stuff that is so fine you cannot pick it up or even see it but it is there. It is definitely worth recovering. But ... you will have to use mercury to extract it. My father in law had a 12 inch dredge that he would take his black sand and put it in a cement mixer with a quart of mercury. Mix all night, get the mercury/gold amalgam out and retort it down. This is an especially cautious area as the mercury will put off fumes and vapors that can really mess you up. On a small scale you can pan your black sand down to a hand full and add about a dime size amount of mercury in the pan. You will soon see it take on a gold color as you continue panning. Once you'er sure you have all the gold recovered, remove the mercury and put it in a small crucible. OUTSIDE and with a fan blowing the fumes away from you burn off the mercury from the gold. You will have to use a oxy-acetylene torch to do this. You will be left with a button of gold. My father in law used to pour the molten gold into a big container of water and would pull out a beautiful drawn out nugget that he would make into jewelry and sell. As I said before. This is not to play with and realize the hazards of mercury. You may want to just use the mercury to extract the gold and then let someone that is experienced in extracting it do that part of it. Good luck, keep your feet dry and don't let anyone throw a piece of shiny scrap brass in your sluice box! (not that I have done that to others) ;) Tom
Tom Haltmeyer
- Peoria, Arizona
A. One response was to burn off the mercury. This true but very dangerous as the fumes are deadly. They can cause loss of teeth, gum bleeding, hair and extremely intense headaches. If burning off mercury, place the amalgam on a shovel, cut a large potato in half length wise, gouge out a small area in the potatoes center. Place the potato over the material to be heated. Heat until all mercury is gone.
Place the potato in a small container of extremely cold water and most of the mercury will resolidify and come out of the potato for reuse. I used this method at Lake Isabell California back in the 70's when sluicing.
Best of Luck.
John Pavelka
- San Antonio, Texas
thumbs down signFor God's sake DO NOT use mercury to extract your gold. If you are lucky enough to not breathe any of the vapors, you are still dumping it to the atmosphere and your neighbors downwind will be breathing it. To use mercury nowadays in mining is highly irresponsible. Here is what you do:
Dissolve the fine gold into a chlorine bleach ⇦ in bulk on eBay or Amazon [affil link] solution or into a solution of aqua regia and be sure to use eye on eBay or Amazon [affil link] , hand on eBay or Amazon [affil link] and lung protection ⇦[this on eBay or Amazon [affil link] and do it outdoors. Then raise the pH with lye on bakieBay or Amazon [affil link] (sodium hydroxide) and the metals will precipitate out of solution as hydroxides. These metal salts can then be placed in a covered crucible in a furnace and burned down to the metallic metal which will hopefully be mostly gold.
I would post some links here on the exact procedures, but links are not allowed. You can also trap the dissolved gold on activated charcoal and then burn off the charcoal.
Jeff Sargent
March 3, 2008
- San Marcos, Texas
Ed. note: Thanks Jeff. Links are not 'disallowed' but they are discouraged because nearly every link breaks in short order, whereas our goal since 1989 has been to build *permanent* technical pages which will prove useful & informative for years to come. Worse, hackers buy up old links and put malware on them, counting on readers to trust the link because the link came from a legitimate sites like ours -- leaving us playing whack-a-mole for endless hours constantly re-checking 250,000 postings going back decades. If you do offer a link, please summarize what it says and give the title of the article so we can keep finding it again when it breaks -- which they virtually all do very quickly. Thanks!
A. To Jeff,
The amount a mercury vapors that would be diluted in the air for said downwind neighbors is far less of an impact than the very harmful gasses given off with chlorine and lye. Not to mention that unless your neighbor is in a close proximity, most of the mercury will fall out of the air due to it molecular weight. The chemicals that most people use in their homes have far worse repercussions "According to California".
www.prospectorsparadise.com/html/mercury.html
Kelly Trumble
Ed. note: As we we just finished warning readers, DON'T FOLLOW OLD LINKS! Thankfully, Internet Archive preserved a copy of what used to be there  🙂
These days information often appears on the internet, then simply disappears forever. If that concerns you please consider a donation to The Internet Archive and their effort to keep available anything that was available.
A. Take a potato, cut it in half. Dig out a dime-size hole in one half of the spud, put your dime-size blob of mercury in the hollow in the spud. Wrap spud in tinfoil. Bake spud under coals, downwind (just in case).
Open spud, collect gold. Put baked spud in your gold pan and pan out the mercury.
Do not eat the spud !
Chuck Carlson
- Boise, Idaho
March 11, 2009
A. Don't use a torch to burn off your mercury, use a retort they are simple to build and you only need something like 400 degrees. a retort is really a small still, the mercury will "boil" off then condense back and land it a bucket of water as clean mercury to be used again. Do the research, I tire of people harping about using mercury, and then suggest using wicked acids instead.
Harry Orr
- Quartzsite, Arizona
April 15, 2011
A. Hi Harry,
Although some acids are indeed "wicked", the difference is that lead and mercury are biocumulative. If acid didn't hurt you on day 1 OR day 2 OR ... day 365, then it didn't hurt you. For mercury, it's day 1 PLUS day 2 PLUS ... day 365.
A. Dan L -- you are looking for a fine gold recovery system ?
Buy you a 8 inch piece sch. 40 pvc pipe and a glue-on cap. Drill the cap and screw a water valve into it, this is so that a hose pipe can screw onto the valve. Buy some ribbed rubber matting to bed the full half 8 inch pipe. from the cap move down about 12 inches and cut the pipe in half long ways. Find a tripod , like the one's used in surveying, drill a hole for, and install, a carriage bolt in the pipe in the middle. use a wing nut to mount the pipe to the tripod. You can adjust the tripod to most any height or angle. You can run a hose pipe from the dredge to the pipe and the valve will adjust your flow. If you adjust the angle right you WILL recover all gold no matter how small. The 8 inch pipe gives you a good wide bed for gold to hangup. One person can run the pipe while the dredge is being used. You will love this fine gold recovery system. This is all I ever use with my 3 inch dredge.
Wallace Smith
- Cleveland, South Carolina
April 7, 2008
Q. I would like to know how long the 8" p.v.c. pipe should be to recover the fine gold you talked about.
Hank Langford
- Whitney, Texas
Q. Wallace,
I sure would like a much more detailed description of the 8 inch pipe fine gold recovery devise.
Bruce L
Bruce Leep
- Bozeman, Montana
April 24, 2009
A. Another method using mercury is to let the mercury pick up the fine gold in your pan, then pour the nickel size drop of mercury amalgam into a small depression created in an old t-shirt. Squeeze the mercury amalgam through the t-shirt and collect your now cleaned mercury in a glass or pyrex container. Cut the dirty brown spot out of the t-shirt as this is now your fine flour gold adhering to the cotton t-shirt material. You can burn out the t-shirt
material to make your gold button or even use nitric acid solution to dissolve the cotton material and leave outside in well vented area to evaporate, leaving just the fine gold.
Bruce Evans
- El Paso, Texas
July 25, 2009
A. It was funny that I found what you wrote because I was looking for a solution to the exact same problem. I have an almost dry well on my property that I use for irrigation when watering by hand. 2 days ago I discovered black sand and fine gold in the bottom of the bucket it is so fine some of it floats. Being completely new to the subject I called a local gold mine and the man there told me there are plenty of different equipment out there but he recommended to let it dry and use series of different fine meshes to screen it through; he also said it was very time consuming but usually worth it.
Marshall Wells
- Statesville, North Carolina
A. I know that either hard water or soft water will make gold more apt to float. (I think it's the hard water)
I found this while trying to find a solution to the same "flour gold" problem.
I saw a old timer on the GPAA tv show saying dish soap would make the surface tension break and cause the floating gold to sink : )
It wouldn't be a good idea out in a stream with a dredge, but he was running his operation at home reusing his water and bringing his material home to separate the gold
Jimmy Allen
- Lake Isabella, California
A. The gold floats because of the surface tension of the water. In a small recirculating operation you can use Jet Dry [Jet Dry on eBay or Amazon [affil link] or dish soap to break the surface tension and the gold will not float anymore. With a dredge, as long as you don't bring the gold to the surface, it shouldn't float. Maybe a deflector to keep it down in the sluice might help. Good luck
Joe Moniz
- OAK CREEK, COLORADO
Bluebowl Concentrator
blue_bowl
A. I don't know if this will help your situation, but there is a product on the market for retrieving fine gold from black sand. It is called Blue Bowl Concentrator ⇨
It's made by: Pioneer Mining Supplies, Auburn, Ca
Paul J. LaMott
- Lindale, Texas
Q. I am new to gold panning and I'm trying to learn the best way to remove the gold from my black sand.
The bad news: I live in Arkansas and I'm learning that we don't have any real good (profitable) gold here. (or that's just what people are telling me.)
The good news: I do live near the Arkansas river and have found a HUGE deposit of black sand. At first I thought someone dumped out a truckload of charcoal, but it's black sand. I panned the stuff and I'm getting about 4 specks of gold per 1 cup of sand . A speck being about the size of a period. (.). Is that considered good or am I just wasting my time ? If I am on to something , what would be the best way do recover the gold? ⇦ Answer?
Lloyd Clifton
hobbyist - Lavaca, Arkansas, USA
Q. On the floating gold problem, I prospect in the Llano Uplift region of Texas and recover quite a bit of floating gold from yellow clay deposits. This stuff is visible and even if you break the surface tension, it is still so light that it stays on the surface of the dirt in the pan or sluice.
Is there an electrostatic or chemical process, besides mercury, that can be used to attract and hold this stuff?
Jim Alford
- Ingram, Texas
A. I've been getting into flour gold and found that vinegar ⇦ in bulk on eBay or Amazon [affil link] works well to make the gold drop over a short time frame.
Henry Williamson
- Beech Island, South Carolina
A. Classification is the key no matter what type of recovery system you use.
David Dodge
- Buena Vista, Colorado
A. I agree with the person that suggested separation. Get a button up shirt that you no longer wear, use a 5 gallon bucket and cover the opening with the shirt and tie the shirt around the edge creating what looks like a drum. Now put your fist into the shirt slowly to create a funnel inside the bucket. Make sure the t-shirt will not cave in or you will lose all the gold and have to start over. Make sure you drill holes in the sides of the bucket so that the water will drain out when it starts to fill up. You have just create a big sieve. Stir up the floating gold and pour it into the sieve. When you are done just bunch it up and dry it. Save it until you are ready to process it into a nugget. Do not attempt to refine the gold unless you have experience, I've done it with proper supervision and coaching. What you have in the t-shirt is a mixture of all kinds of material not just gold, do not go and burn it without the proper setup. Make sure you check the drainage water from the sieve to make sure there are no holes and the shirt is catching what your going for. Have fun. Use a battery operated water pump so that you can just stir the gold up and take down a beer while everything is running. lol Good luck
Andy T. [last name deleted for privacy by Editor]
- Cedar Park, Texas
A. Use a large coffee filter or you can buy large sheets of material that they use for tea bags on the net.
That will filter the floaters out of your water and also using a fine miners moss or outdoor carpet in your box will pick up most of the fine dust.
I use to just tie a black bandana to the top of a bucket and pour my recirculated water through it at the end of the day and it worked pretty well.
John Dennett
- Weatherford, Texas
Q. I found this site while looking for a safer method of recovering gold from my fines I've collected as a weekend prospector. I was hoping to find some method, such as electrolysis that did not use toxic, dangerous chemicals such as Aqua Regia or Cyanide.
I read through quite a few pages on thread 18889 which is dedicated to recovering gold from Electronics but mostly it seems to involve dissolving the gold in chemicals. Has anyone out there used or heard of using electrolysis to treat their fines?
Rob Feeny
- Kelowna, BC, Canada
April 6, 2008
Ed. note: Thread 200/33 focuses mostly on that subject.
A. I recently learned of a fella in Colorado who has discovered a safe way of gold recovery and they have been working on refining the process since April 2008. Search "Amalgamite". Very interesting. I have yet to try it. Came by here in search of what electronic parts might be worthy of salvage. Thank you.
Charlie Little
- Mansfield, Arkansas
Ed. note: While recovery of gold from electronics might have some things in common with fine floating gold, several issues are different -- please see thread 188/89 or search the site for a dozen more.
thumbs down sign I haven't seen anything here that will collect enough gold to cover the head of a pin.
Float gold cannot be recovered by any of the above. If you want to recover float gold you need very fine mesh bags (can be found on the Internet under water filtering). You pump water thru the bags for several hours. Not all water will have gold. Only the top 2 to 3 inches and must be below a waterfall or behind a dredge.
Raymond Looper
- Fallon, Nevada
August 12, 2009
Shaklee "Basic H"
shaklee_basic_H
A. Floating gold can be settled by breaking the surface tension with a surfactant "jet dry" [Jet Dry on eBay or Amazon [affil link] comes to mind. Back in my youth we used to play with a Shaklee product called "Basic H"
... it was a wetting agent that would make water wetter and break surface tension. Most of the agents I can think of would work if you could drop small amounts in your sluice box as you run.
Good luck and hope you always see color in your pan!
Marty Burgess
- Las Vegas, Nevada
August 24, 2009
A. I've been working with some flour gold and have found a good way to get it out of sand. It's called a door mat.Yes I said a door-mat! The mat I use has a fine texture on it kind of like miniature creek beds. run it the same way as you would run your regular sluice. Carefully control the water flow and down angle. If you want large gold think big! But if you want to get the small gold out think small.
rou1 - Rob Lewis
prospector - Whitehorse, Yukon, Canada
July 11, 2010
Q. Would you mind explaining the door mat a little further? Do you place the sand on the mat, then wash the sand off and the small flour gold goes through? Then how do you get it out of the water?
Mary Wilson
- Seattle, Washington
August 31, 2010
A. The gold don't go through the mat it sits on top. Gold is flat; black sand is round. This is why the sand runs off and the gold sits down on the mat
... however some gold flakes/the larger flatter ones might get washed down no matter what you do.
Just set your water flow and angle. Keep testing small amounts till you can see the gold settling and the sand running away. I usually run sand with a table spoon, spooning it onto the mat but like I said it's a slow process.
rou1 - Rob Lewis
September 1, 2010
Q. Great thread! I am a new prospector and have a claim on the Yuba North Fork. I have been diligently going to my claim and digging sample test holes to find out where the gold is on about a fifty yards of 1/2 mile of river...sometimes while panning, I am noticing lots of floating gold but it is really small and fine. I have heard that dry gold can float. Will the mat or is the mat what I should use at the river. When I pick up a pan of gold there are hundreds of small fine floating flakes with many sitting on the sides of the pan. When I walk through the claim or am digging out a test hole, I look down and see hundreds at my feet and all over the rocks. I know gold is the heaviest mineral I will find and that there is a mineral called pyrite or fools gold but is the stuff sitting on the edge of my pan gold? is it able to be recovered? I have yet to find anything much bigger that a 30-60 mesh piece of gold. Can anyone help me please? I really want to locate the gold on my claim. I have read several books by McCraken and others on how and where to find gold but I keep coming up with pretty much nothing. I have 3-5 specks besides the 30-60 mesh piece of gold and a flattened out fishing weight. I am not ungrateful but wanting to do better. Thanks for any responses from real miners.
Rich Mariani
- Vacaville, California United States of America
September 16, 2010
A. The best deal to recover find gold is to reduce the depth of your flow and make it free of turbulence. Any riffles or obstructions must completely be covered by water. There is a formulaic way to figure out exactly how many gallons to pump to do this, but suffice to say with a 6 inch wide sluice running 1 inch deep, at a 5.5 degree angle you need 40 GPM feed water. Amazingly, if this sluice would clean immediately it would handle 5.3 thousand lbs of fines per hour, and twice that in gravels, at least. Of course it is unlikely that a sluice fed this much dirt would clean it in the same time. You need fast moving water to clean a sluice quickly, at least 4-6 fps. A 1.25 in. deep sluice at 10 inches wide at a 10 degree slope would attain 3.5 fps, but it needs 132 gallons of water per min to attain that flow speed. At that speed you would need lots of sluice length and nomad carpeting to recover fine gold. (15 feet?) You need to screen out everything over 14 mesh in sands to ensure good recovery. While you see lots of sexy ads on youtube etc, what they don't tell you is that river water running through the sluice is hundreds of gallons per minute. (300 GPM or more for a 3 inch depth of ten inches wide at 7 degrees - 6 inches in 4 feet.) Just because you see some fine gold after clean up tells you nothing about what you missed. Just because the first 1/3 of these sluices recovers 90% of the gold in the sluice tells you nothing about what 100% was in the original dirt. It merely says that the back 2/3s recovered 10% of what it got, (this was fine gold) -and- if it recovered gold right up to the end, that was where it was losing fines. Getting less and less does not imply there was less and less. Just that was the efficiency of the sluice.
The best kind of sluice for fine gold would use semi circle indentations in the sluice bottom, rather than riffles, as this has less turbulence and obstruction to flow. (Gemini table is an example. Riffles should be no more than 3/4 the height of water flow depth. You should not see white water or frothing in the flow. No chemical or flocculants should be added to a sluice, because a sluice needs surface tension to clean properly. If gold floats on ST, then it is more or less lost. The volume of even acres of this type of gold is so minuscule that it is well worth ignoring. It is seen in many placer or gold productive areas, especially where the water has tannic acid s in it, or pine oils. It would be very tricky to add just the right amount of detergent not to defeat your sluice and to recover significant quantities of gold. You could experiment with Loc from Amway [Loc on eBay or Amazon [affil link] , but be careful as it is very powerful as surface tension remover and may actually hinder gold recovery if too much is added. What will adhere to a pin will remove all the ST from one liter of water.
It is possible to recover very fine gold with what is called an undercurrent sluice. All the undercurrent does is provide slits in a false bottom running lengthwise with the sluice current. The slits themselves are much less in area than the screen bars of the undercurrent itself. Sort of like a sieve bend. The descending water into the slits of the sieve takes mostly just extreme heavies and has a tendency to reject the lights. If the sieve areas are made just right for the flow, the concentrate so collected will be fairly high grade. It helps to narrow the sluice by about half at the point where the bar-screen false bottom is set, so that the feed naturally stratifies and the bottom becomes a heavy layer, which is scavenged by the undercurrent. A flat bar width of 3/16 inch with a slit of 14 to 18 gauge would be workable. Make the bars about 12 to 18 inches long. Several of these in an 8 foot run should do the work you need.
I have several other designs I have tried on ultra fine gold (20 to 50 microns or 8 ten thousands of an inch to 24 ten thousandths of an inch. Throughput is ultra quick and all you get is gold. Good for cleaning Black sands. I am a little bit coy about design details.
E. Charters
mining - toronto, ontario, canada
January 13, 2011
Ed. note: Few of us can share all of what we know; most of us can share some of what we know. Thanks for sharing what you could, E.
It's probably not something we'd buy, but along the lines of a scratch-off lottery ticket ...
Gold Concentrate "Paydirt"
gold_paydirt
Q. I am from Louisiana and buy my material from Tom and Perry Massie; they advertise up to a quarter of an ounce per two pound bag of gold and I believe them to be honest.
I watched a "Gold Fever" show and Tom mentioned that most of the time a bag would contain a "penny weigh" of gold minimum, so far from two bags I have recovered 1/2 gram or .321 "penny weigh", the first bag I wet panned and watched a lot of floating gold flakes return to mother nature. I took a different route with the second bag, I thoroughly dried the material and in small increments recovered the heavy gold pieces. This brings me to my question, how do I tell the gold flakes from iron pyrite? ⇦ Answer?
Stan Paulk
greenhorn prospector - Deville, Louisiana, U.S.A.
December 2, 2011
Q. Hi. My father gave me 20 grams of rock that seem to contain gold. So I crushed as much of it up as I could and panned it. When the dust mixed with water it floated and clumped up. I have several pieces that are chunks and they're silver in color and some gold color mixed. What type of rock or metal am I dealing with? ⇦ Answer?
Ben Willey
- Union, Maine, USA
December 7, 2011
Q. What chemical is used to drop the mud from the water at the end of my dredge?
Mike Wood
- Seward, Alaska
April 11, 2012
A. I read that they use a flotation plant that uses a reagent that promotes flotation. Air is pumped through a conditioning tank and the gold and silver bubbles up and it is run through a carbon filter then processed.
Randy Bislow
- Franklin, Nebraska, USA
August 5, 2013
Q. I found a small river running through a piece of land (deposit of silver ore plus fine gold) it was spilled by silver mining company. Has stopped operating more than 15 years already. I am interested to retrieve the fine gold. Already have permission. I am new. How can I capture the gold? ⇦ Answer?
Liew Yiung
- Kuching, Malaysia
May 31, 2012
Q. I have found a mixture of floating gold and mica. I took it to a local jewelry store; he told me it was part gold and part mica. He told me to separate the two to get me a fire brick, drill a hole in it, pour a little bit of mixture in the hole and heat it up with a torch. He said the two would go different directions and separate. I was wondering if anybody else has heard this?
wesley mullinax
- polkville North Carolina
February 6, 2013
Q. I went on a trip to California, I stopped on the area known as Patrick Creek and was collecting white rocks, on 2 different occasions a man collecting water for the fires told me this was bedrock. As I started digging it was loaded with black sand and Quartz.I took a bucket and shovel and filled them with this black sand. I ended up after stopping there twice with a huge bin of black sand and rocks
while panning through I notice lots of gold looking flakes all over the top but also some white shiny stuff and some rust colored stuff what appears to be copper. Is any of this worth anything and should I separate it into the particular colors red, white and gold? I might sound silly but I'm new at this and need some advice.
ABBY YOUNG
- Eugene, Oregon U.S.A.
September 4, 2015
A. I mine for flour gold in Juneau, Alaska. We use Gold Hog yukon mats, Dawn dish liquid, and a 3" hydroforce nozzle. We pump well above 20,000 gallons per hour. We have 2- 12' sluicing setups and we often combine units for a 19' machine. No matter how finely tuned your setup is, chances are you will not catch all of the fine gold. Any way you can cut down on bubbles in the system, and cause the gold to fall out of solution will help. We mine almost exclusively the super fine gold, so catching as much as possible is obviously our objective. We have added everything from thick bristley mats turned upside down, to rocks in the header box, and miners moss barriers. We move an average of 10- 12 yards per 6 hr shift, as we are only allotted a small window of work time, due to the tide.
James Hevenor
- Juneau, Alaska ,USA
January 4, 2017
! Hi I see you have a topic on recovering of fine floating gold. I would like to be able to post on this Forum. My hobby for the last 50 years has been Hydro-Metallurgy. I have several proprietary processes, I wish to get in touch with the persons that are posting.
Johan L
gold reclamation - California, USA
December 2, 2017
thumbs up sign  Hi Johan. Feel free to publicly share what you consider non-proprietary.
Sorry, we don't facilitate private hookups. There are at least a hundred readers for every poster, and it's rude to draw them here in search of answers and then cut them out. Taking threads private is like inviting people for cocktails, then telling them to scram, they didn't make the cut for a dinner invitation :-)
We'd greatly appreciate any public help you wish to offer. And you're certainly welcome to do paid advertising here for whatever you wish to sell as well. But we've all seen many forums ruined by spam, and we're already fighting well over 1000 spams a day, with spambots making it worse every day. So our policy is no commercial benefit except from clearly labeled paid advertising; anything else makes the forum a total spam magnet;
Apologies and Regards,
"Demand Curve for Internet Advertising: Infinite demand at zero cost, zero demand at infinitesimal cost"
-- Thomas J Pullizzi, 1995.
Q. Sir I'm alpesh from india. I have my own farm of black sand which contains gold in powder form. When I washed it on carpet my carpet turned into gold colour. I tried to separate it but I didn't get success. Please help me to get result because it is in powder form. ⇦ Answer?
Alpesh damor
- Bhloda, gujarat, India
September 23, 2018
Q. I found my dog chewing on stone used to build my fireplace in my home and when I looked at the fire place it was shining where the dog chewed. I ran my fingers over the rock and gold dust appeared on my hands.
Is this possible? I live in Washington state so the stone could be local or somewhere near. What I have read is that this can be possible. Flour gold or fine dust gold.
How do I verify that the stone may have gold in it? I am not equipped with any equipment or knowledge to do what I have read others post as far as testing or "harvesting". I am not a prospector, but know stranger things have happened.
Is this common? Is it worth pursuing? Is there a laboratory that will test the material?
Melissa Sullivan
- Richland, Washington, USA
February 2, 2019
A. Hello Melissa, Sounds like your dog has the Midas touch! Not to burst your bubble but you could have iron pyrite there, aka fools gold. Iron pyrite is magnetic, as gold is not. If you have enough surface area you can test it with a magnet. Another simple test is to rub the area in question well. Iron pyrite has an odor of sulfur, or rotten eggs, gold does not have a distinctive odor. It is possible to find gold in rock, not very common in fireplace stone however. Is it worth pursuing? I would hate to see you ruin your fireplace for such a small amount of gold. Let us know what your findings are. One more thing, that's one tough dog you have there!
Mark Baker
Electronic Plating - Phoenix, Arizona USA
A. Could be schist, in which case the dust is mica. Could contain pyrite (an iron compound known as Fools Gold), or Galena (a lead compound- but it's more silvery). No point in pursuing it- Even if it WERE gold, the cost of recovery (dismantle, break up rock, smelt, rebuild fireplace) far outweighs any tiny amount of gold you might find. It's about $40/gram, how much does a new fireplace cost? Pics of the stone would help narrow down the possibilities. I'd be more concerned with your dog needing to break that habit before he ruins his teeth- Mine was a rock chewer too and I'm not looking forward to his dental bills when the damage starts turning into cavities.
If you've actually got gold in your fireplace, I'd say it's more valuable as a conversation piece :)
rachel_mackintosh
Rachel Mackintosh
Q. I need some help. I'm located in Michigan and I'm pretty sure I found a fossil type gold deposit in a flood plain; lots of different types of ore, oxidized metals, some copper, some silver metals, and lots of fine gold dust. It's very concentrated on a high bank that has been deposited in floods for a long time. It's thick clay with large layers of river gravel. The gravels all seem to be ores and lots of fossils, covered in fine powder, as well as chunks of the powdered metals layered down in streaks and layers throughout the clay.
I can't seem to collect any of the super fine powder, or pointers on collecting this stuff. So if I could email some photos?
To help confirm if the deposit is rich I have melted some of the powder but can't get it hot enough to separate the silvery metals from the gold. Very new to all this. Thanks in advance to anyone who could help.
Chad Truran
- Taylor Michigan u.s.a
March 15, 2020
Ed. note: Please <send pics for posting>
A. Hi Chad,
Can you try polyelectrolyte to settle fine gold powder?
bhupesh mulik
CAC admixtures - MUMBAI, India
