HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
Live! From beautiful Pine Beach New Jersey: Welcome to the world's most popular metal finishing website
topic 17147
A good process sequence for Nickel Plate on Zinc Die Cast
We need to Barrel Nickel Plate, on small parts made from Zinc Die Cast. What would be a good complete process sequence?
We used to apply regular Cyanide Copper for one hour and then Nickel Plate for 45 to 60 minutes. Regularly we had problems with blisters. We have received a new project and suggestions in regards of adding a Copper Strike before the regular Copper Bath. Is this a sound recommendation? How would you process this parts? We don't want to add an acid copper to our line after regular Copper.
Thank you for your answer.
Enrique Segovia
- Monterrey, Mexico
First electroplate pure zinc over the die cast in an alkaline formulation, then Copper Cyanide Strike, then any kind of copper electroplate you want to use.
robert probert
Editor's note: Mr. Probert is the author of Aluminum How-To / Aluminio El Como
and co-author of The Sulfamate Nickel How-To Guide
Robert,
Thanks for your input. I have never heard of a pure zinc over the die cast. Is this a strike? What would the formulation be? What is the purpose or benefit of this bath?
Regarding the Copper Cyanide Strike, what are the parameters and formulation? How long do we plate on both baths?
Thanks again for your help,
Adios Amigo,
Enrique.
Enrique Segovia
- Monterrey, Mexico
I disagree with the previous reply. No zinc plating is required!
First you need a very mild alkaline cleaner that will not attack the zinc.
Then you need an acid activator followed by a cyanide copper. No strike copper is required!
After the copper, you need an acid activator followed by the nickel.
Most adhesion problems in plating on zinc die casting are related to the acid activator between the copper and the nickel. Its concentration has to be constantly monitored and when it reaches a certain level of copper impurity, it has to be discharged.
sara michaeli
sara michaeli signature
Sara Michaeli
chemical process supplier
Tel-Aviv, Israel
If you have a question in mind which seems off topic, please Search the Site
ADD a Q, A, or Comment on THIS topic START an UNRELATED topicView CURRENT HOT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2019 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
