A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 10703
Electropolishing of nitinol wire
I am encountering a surface defect related problem in some nitinol wire that I have been able to plate with first a gold strike and then platinum. I believe the plating is not the source of the problem.
I would like to try electropolishing to remove the burrs and scratches and sharp points from the wires cut end. What I need are the current/voltage settings and the bath solutions make up. I hope that this is an easy enough process to add because this is something that will have to be done in house. I have a voltage and current controllable power supply and can make up most solutions here.
Any help with this would be greatly appreciated.
Larry Jansen
iSense co. - Portland, Oregon
Monel can be electropolished with phosphoric-sulfuric-hydrochloric type bath, US Patent 2,440,715, Battelle Development Corporation.
Nichrome can be electropolished in methyl alcohol-nitric as given in Durney's Electroplating Engineering Handbook. A literature review may turn up more.
tom pullizzi monitor
Tom Pullizzi
Falls Township,
   Pennsylvania
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
