pub  Where the
Q&As since 1989
How to Antique or Blacken Gold rings & jewelry
Blackening gold jewelry with paint or black nickel plating
Q. Hello, although I assumed that the problem I have is one that has been solved a long time ago, it has been a great struggle for me to find the solution. I need to place a black finish on selected areas of gold jewelry. The problem is that this finish has to be a deep black and as thin as possible. I have tried car paint and black nickel plating, but as the areas are small (20 x 20 mm) it proved to be very difficult to apply paint evenly, and I found the nickel not dark enough in color. I am not in the finishing industry and have found it very frustrating to find people that have experience with this type of problem. Thanks,
Robert van Mil
- Toronto Ontario Canada
1996
A. Hi,
Use Duco black paint and Duco thinner. Mix it properly then soak pieces that gold plating is on. Just keep one minute. Remove by the help of cloth; this is called "black antique gold".
Sreenivas.V
- Hyderabad, A.P., India
Environmentally safe antiquing of gold
Q. Does anyone have any information on an environmentally safe/friendly solution to antique and/or blacken gold for an antique appearance? Would like to relieve and polish the gold after antiquing.
Bill Christiansen
A. Bill,
As gold is very inert to oxidation the only method I know is to plate a thin coat of black nickel or "Electroblack", an Enequist (from NY) product, then relieve. Hope this helps.
bob lynch
Bob Lynch
plating company - Sydney, Australia
Q. Bob:
Thanks for the response. We used to use Electroblack but removed it from our plant because of the hazardous chemicals.
The latest Gesswein catalog has a product called "Oxaul Salts" which says it blackens gold. Has anyone out there ever tried it? Is it safe to use? What about disposal? Thanks for your help.
Bill Christiansen
Q. We are a class ring manufacturer. We use the Enequist Electroblack in our gold rings. Suddenly it started peeling off the finished (already blackened) rings. After blackening we polish the high reliefs with polishing compound and wash in alkaline ultrasonic solution, after cleaning we buff and again wash, then dry with air. It is after the buffing that the blackening peels off.
Raul Mendez
manager - Panama
A. This is a proprietary product which comes with technical assistance--that's one of the main reasons for using a more expensive proprietary product instead of a home brew. Please make the supplier aware that are are suffering a problem -- I'm confident they will help you solve this. Good luck.
[editor appended this entry to this existing thread in lieu of spawning a duplicative one]
Q. Can anyone tell me what "Blackened Gold" is, and how do I do it?
John L [last name deleted for privacy by Editor]
- Boston, Massachusetts
thumbs up sign Hi, Jack. "Blackened gold" would be gold where the surface has been blackened in some fashion. But as a warning, if you have an order to supply "blackened gold" and you and your customer do not have a firm agreement as to precisely what that means, the only people who will be happy are the lawyers who will be billing you both by the hour when the customer refuses to pay you :-)
You need agreed-upon samples before any contracts ensue. But read on for some people's explanations of what blackened gold means to them and how they do it. Good luck.
General technique for blackening gold
Q. I would like to antique a gold plated part. Any suggestions on proper technique or chemical?
Robert Baxter
Buyer - Chester, New York
A. Hi Robert. As for techniques, I don't claim much aesthetic sense, but I do know that a key to natural-looking aesthetics as well as durability is that you want only the recesses dark, not the high spots. This can be done by darkening or plating the the whole item with a dark metal and then relieving (buffing the darkening off of the high spots).
Some answers are above, and others will be below, but one approach is to selectively silver plate some areas and blacken the silver or perhaps plate the object with a low karat gold which can be easily chemically blackened because of its high copper content. (High purity gold is very inert, so it's hard to chemically blacken it). Good luck.
If you apply a plating of a dark metal like black rhodium [adv: black rhodium plating solution on eBay or Amazon] or black nickel, it may be more practical to mask the areas that you don't want darkened than to buff the black nickel plating off of the gold plating. It will depend. Good luck.
Liver of sulfur won't blacken gold
I am trying to re-blacken the keltic knot-work design on my gold wedding band. Could any of you offer advice? I tried "liver of sulfur" liver of sulfur [on eBay or Amazon] but the rose gold ring didn't have enough copper I guess to blacken at all. Now it's been suggested that I try Jax silver/gold blackener, but I have to buy a whole pint! Any suggestions are welcome, especially with respect to what tool to use to apply (dipping, plastic bristle paint brush etc). Thanks for any replies!
PS - I did have a jeweler blacken the ring, but the blackener wore off within 2 weeks. This person was the one who set the stone in the ring and took off the original blackening in the process. Now it looks just like it did after she set the stone. :(
Coleen Harman
- Edmonton, Alberta, Canada
Ed. note: Hi Coleen. There is a Jax silver blackener [affil links], but I don't think there is a "silver/gold blackener" nor any claim that the silver blackener will blacken gold. The only robust way to blacken gold is probably to electroplate it with black nickel or [adv: black rhodium plating solution on eBay or Amazon] or other black metal.
A. Try to use 10 per cent borax [affil links] solution, containing a few drops of alcohol. I hope it will solve your problem. Use the solution with Q-tip [affil links].
Riaz Haider
- Lahore, Pakistan
A. I use iodine [affil links], like you buy for cuts, to blacken gold.
John Legere
- Lake Worth, Florida
Q. How? How do you do this without the iodine wearing off? Thanks.
Trudy Smith
- Missouri
June 17, 2023
A. Hi Trudy. Googling doesn't tell me much about this, but I'm confident that we're talking about a mild etch and a stain, which is probably okay for recessed areas not highlights, and which can probably be somewhat protected with a clear coat like Protectaclear from Everbrite [a finishing.com supporting advertiser]. But it is probably not deep black nor truly robust.
I have seen ratios of 4:1 to 10:1 for potassium iodide:iodine ratio reported to make an optimum gold etch. You can search the site with "iodine gold etch", and read a number of comments about it.
pic of Ted Mooney
Antiquing white gold
Q. I have an 18K white gold ring that has an engraved wheat pattern and tiny beading on the edges. It is too shiny for me and I would like to make it more matte. Is that possible without damaging the integrity of the ring? The diamond has not been set. Thanks!!
Angela Hudson
- Seattle, Washington USA
May 24, 2013
A. Hi Angela. If the ring is rhodium plated, that probably has to be buffed away first. Then the white gold, if still too shiny, can probably be darkened/antiqued with techniques listed on this page. Good luck.
Q. Hello All, I purchased an Italian antique lantern some years ago. In its original condition it was nickel plated bronze and very heavy. Picture an orb about 7" in diameter, with two connecting "wings" facing up, with two long chains connecting the wings to a cupola . It is now wired for electric. The original frosted globe in a flame shape was stolen from me by an antique shop in Alexandria so now I have to spend money to have a globe custom made for it. I took it in for the lighting guy to patina it for me.
I wanted a warmer color so I took it to my gilder. She said it would cost a fortune to gild it, so to have it gold plated first then she would patina it.
Unfortunately, they closed their business and could only finish up projects that were submitted before mine. So I am now stuck with a 24 kt plated fixture which looks horrible -- this fixture should be toned way down.
Actually, I should have done more research because only parts of it should have been gold, the other should have been the traditional brown/black bronze.
I was considering taking it apart and painting certain pieces and leaving smaller areas in gold.
The questions are:
What type of primer and what type of paint is best to use? I have used flat spray and then buffed it up, or used paste wax for a nice sheen, at least on wood and it turned out beautifully.
What should I use to patina the remaining gold, that won't rub off?
Should I paint the entire fixture and using wet/dry extra fine 400 grit sand paper, rub until the desired effect is achieved?
Sprayed or brushed? I am thinking sprayed is best. I am good with painting and have refinished many furnishings, and other objects.
Should I take it back to the plating shop and ask them for some guidance?
Would this answer from Ted Mooney apply to my situation?
"Some answers are above, and others will be below, but one approach is to selectively silver plate some areas and blacken the silver or -- perhaps better -- plate the object with a low karat gold which can be easily chemically blackened because of its high copper content (high purity gold is very inert, so it's hard to chemically blacken it). If you apply a plating of a dark metal like black nickel instead, it may be more practical to mask the areas that you don't want darkened than to buff the black nickel plating off of the gold plating. Good luck."
I have photos. Thank you in advance!
Ronald Dean
- Washington DC
August 17, 2018
A. Hi Ronald. You don't find iron or most other metals in metallic form in nature, but only as ores (compounds), because over time such metals react with oxygen, sulfur [affil links] and water to form compounds instead of staying metallic. In contrast, you do find gold in nature, even after tens of millions of years, because it is so resistant to reacting with anything. So when you are looking for a blackening/darkening chemical that will actually react with pure 24 kt gold, not just be a coating that can rub off, that's a tough requirement.
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
If you just want it less shiny, I think what I'd do if I were you is see if a brass lacquer company can offer you a tinted lacquer to tone down the color. You could probably apply 2 coats here, and 3 coats there, and a blotch of a a 4th coat elsewhere to give some gradation if that's important to you. Gold plating is really thin; trying to paint and then rub or sand to thin the paint without removing the gold may prove impossible.
If you actually want black areas, please consider the suggestions in the previous postings, especially electroplating it with a black metal.
pic of Ted Mooney
thumbs up sign Hi Ted, I have an update. Before I took my automobile in for service yesterday, I remembered that the plating shop is on the same street. It has a new owner, and we had a great conversation and leads to a solution. First, I am going to determine how to balance the look (the lantern is in several pieces supported by a long central screw)then they are going to strip off the gold and nickel plate leaving behind the bronze. The long chain will most likely become all bronze. Then I will work on the finish I want. I have a file of referenced French Empire fixtures that will guide me. It will end up somewhere and I will post the finished result at some point.
Thanks again for your help on this.
Ronald
Ronald Dean
- Washington DC
August 30, 2018
Consult'g, Train'g
