Q&As since 1989
My cookie cutters are rusted; can I clean them?
Q. Our company produces hand-made tin ornaments & cookie cutters. We have been asked to replicate the old-fashioned tin icicle ornaments that have an iridescent color on each side.
What needs to be applied to the tin in order to achieve these colors . . .or can this type tin be purchased?
- Millersburg, Ohio, USA
A. Several companies make pearlescent pigments that use the principle of thin-film reflectance. It is possible to reproduce that on a metal substrate, but I think it would be vastly cheaper to use the existing pigments themselves in a clear lacquer or urethane base. You can get different effects by using different particle sizes and concentrations. The companies are Englehard and EM Industries. Englehard also makes iridescent plastic films, which can be converted to glitter and used like the mica's (try Meadowbrook or Glitterex) and it may be possible to simply adhere their film to your products.
Good luck,
- Bohemia, New York
A. Moiré metalique for tin:
1.heat your objects to 250 °C
2.immerse it into special pickle:
- 2 parts hydrochloric acid
- 1 part nitric acid
- 3 parts water
- 1/4 part potassium bichromate
3.between crystals you must obtain black colour
4.rinse well
5.immerse to hydrochloric acid
6.without rinsing immerse in: 10 parts sodium thiosulphate [on
Amazon]
/120 parts water solution- after that rinse it and lacquer it!
metals conservator - Zagreb, Croatia
Q. I HAVE A LOT OF COOKIE CUTTERS BUT THEY ARE RUSTED, CAN I CLEAN THEM OR SHOULD I THROW THEM AWAY?
Edda ContrerasCOOKING CLASS TEACHER - San Diego California Usa
A. If they are special to you, Edda, a plating shop can re-tin them for you. But due to the relatively low labor cost of making thousands of new cookie cutters at a time, and the high labor cost of replating a few on a onesy-twosy basis, replating your old ones will cost more than buying new. They are not dangerous (unless you cut yourself deeply with one), but they might stain the cookies I suppose.
A. Clean them with a scotchbrite pad [on eBay or Amazon] and a suspension of baking soda [on eBay or Amazon] and water. Lightly oil after cleaning and after each use.
James Watts- Navarre, Florida
Q. Can you spray paint metal cookie cutters? Is it safe? What kind of paint would you use? Ace Hardware recommended Rustoleum products.
Lisa Franck- Appleton, Wisconsin
December 4, 2019
A. Hi Lisa. Most paints are not designed to be used as food contact surfaces. Rustoleum is not a type of paint but a brand name of lots of different types of paint, so it's probably inaccurate to say that it is or isn't food-safe.
I would suggest you use the search term "food-safe paint" or "food contact paint" or "food grade paint" and you will see very specific suggestions both from the companies that offer them and from regulatory authorities. Good luck!
December 2019
