Copper electrowinning: practical, smart way to recover smooth sheets
Summary for copper electrowinning Discussion
Thin sheets of copper from recycled scrap are discussed under the focus keyphrase "copper electrowinning." Joseph Opeodu asked how to get a very clean, smooth thin copper sheet from recycled copper using electrolysis. The reply from A. explained that the practical route is usually to dissolve the copper first in an acidic solution, either with mild acids plus electricity or stronger acids without electricity, and then electroplate the copper onto a passivated stainless steel sheet until the deposit is thick enough to strip off. A. noted that plating can form dendrites rather than a perfectly smooth layer, so organic additives are often used to reduce roughness. He also suggested that, in industry, copper is commonly electrowon onto cathode sheets, sometimes on a slowly moving stainless strip. In a follow-up, A. said the dissolution and plating steps are usually kept separate because impurity control is easier that way.
Q. Hello experts,
I am highly pleased to be in the midst of vast experienced people in the metal processing niche.
Please, how can I get a very clean, not rough thin sheet of copper from recycled copper? I would want the use of electrolysis. However, I still need it to be smooth.
Joseph Opeodu
Student – Toronto, Canada
November 6, 2025
A. Hi Joseph.
I’m not sure yet if this is just theoretical for a report, or if you are actually trying to build a prototype for a processing plant. And I’m not sure if a couple of small parts in a beaker will suffice for the proof of concept or you need something more substantial. If on the other hand you are a home-based scrapper intending to do this, you are welcome to try but we need to warn you that you’ll probably find the undertaking impractical.
But in general you dissolve the copper into an acidic solution either with mild acids and electricity, or with stronger acids and no electricity.
Then you electroplate the copper onto a stainless steel sheet (passivated, to limit how tightly the plating adheres) until it is thick enough to be removed.
In actual practice, rather than plating onto stainless steel sheets immersed into the copper plating solution you created, an option would be to plate a thin stripe of copper onto a very slowly advancing stainless sheet, maybe in endless belt form.
Plating tends to form dendrites rather than plating smoothly, and organic addition agents are used in the plating solution to limit that problem.
You can probably learn more by searching this site for “copper electrowinning”, or trying a search engine or AI agent for that term.
Electrowinning of copper is a big industry, with major installations of copper electrowinning onto cathode sheets.
thumbs up sign Thanks so much. I did not know I can actually dissolve the copper and electroplate it later.
Joseph Abayomi [returning]
– Ontario, Canada
November 12, 2025
A. Hi again, Joseph.
Yes, the dissolving and plating out are generally done as two separate operations, the main reason probably being that removing impurities from a batch is far simpler than trying to remove unpredictable types & quantities of contaminants on the fly in the few seconds between dissolution and plate out.
But I know of a copper electroplating shop which uses scrap copper as their source of the needed copper.
