Summary for 304 stainless steel heat coloring Discussion
304 stainless steel heat coloring is discussed as a process that can produce very different results depending on surface condition and heating uniformity. Thomas Erwin described a thin 304 disc that turned chocolate brown on the polished, cleaned side but purple with blue splotches on the unpolished side after heating on an electric burner coil, even though the coil was red hot. He also asked whether a consistent dark blue finish is possible, noting that kiln heating, a butane torch, and the burner coil all produced splotchy color. Goran Budija replied that heat tinting stainless steel is simple in principle but very hard to make consistent in practice, especially on anything more complex than small flat sheet. He suggested electrochemical coloring instead, mentioning molybdate-based solutions as a less toxic alternative to the old INCO hex-chromate process. The thread’s practical takeaway is that even heating and surface prep matter, but uniform blue heat tint on 304 is difficult.
Q. I have a .4mm thick and 29mm diameter piece of 304 stainless steel. One side was polished to 8k and had a protective film on it. The other side did not.
I removed the protective film and cleaned with acetone and hot soapy water.
I place my steel on an electric burner. The coil on it was red hot indicating it was well beyond the 1,000 °F-ish temp needed to turn the steel blue.
I laid my steel on the coil and let it set. When I quenced it the polished side I had cleaned was kind of a chocolatey brown color. The unpolished side which I didn’t really bother to clean became purple with splotches of blue.
Why would I get 2 different colors on the thin steel? 1 side is 1 color, 1 side is a different color?
I know since I didn’t get blue it tells me I didn’t get my disc hot enough.
Thomas Erwin
hobbyist – Houston. Texas
September 29, 2025
Q. I should add too, is it possible to get an even consistent color on 304 stainless steel? I am wanting a dark blue. As I tinker more I get the colors but they are splotchy. I have used a kiln set to 1,100 °F, I tried a butane torch with the piece resting on a thin piece of steel with copper shavings, and the electric burner coil.
Thomas Erwin [returning]
hobbyist – Houston TX
September 30, 2025
A. Heat tinting of stainless steel is very simple process but it is very hard to get consistent results. It is easy to do it on piece of small flat pieces of sheet but complex shapes are very problematic.Try electrochemical coloring — you can use molybdate based solution; it is much less toxic than old INCO process (hex chromate based ). Hope it helps and good luck!
– Cerovski vrh Croatia
October 1, 2025
Thanks so much for the tip. Is there a good resource to read up on to learn how to do this?
Thomas Erwin
hobbyist – Houston
October 1, 2025
Ed. note: You can search the site for ‘coloring of stainless steel’ for a good start.
A. Try wikipedia articles on chemical ,electrochemical and heat coloring of metals.In my download free booklet is small chapter on coloring stainless steel too (finishing.com/library/budija/kembojen2025.pdf ). Hope it helps and good luck!
October 1, 2025
