Summary for ni-cr plating on diecastings Discussion
Ni-Cr plating on diecastings is often troublesome because the substrate itself may be the root cause. The thread’s quickstart note says porous castings or those with cold shuts will usually blister, and unless diecasting quality is tightly controlled, the plater may need 100% inspection before plating. It also notes that diecastings generally need vibratory or other mechanical finishing before the chemical steps, and usually require copper plating before any other plating. In the specific question, a zinc cast part with copper and bright nickel showed blisters after four months. The reply attributed the problem mainly to cleaning: do a water-break test after the acid dip and rinse, and check whether water sheets properly; if a white paper towel leaves black residue, the part was not cleaned correctly. The overall message is that blistering can come from both poor casting quality and inadequate surface preparation.
“Finishing and Electroplating Die Cast and Wrought Zinc”
by Safranek & Brooman
(only rarely avail.)
Plating on diecastings is troublesome because the substrate is often of insufficient quality. Porous castings or those with cold shuts ⇦ huh? will usually exhibit blistering. Unless the diecasting process is under very good control the plater may need to do 100% inspection before plating.
Diecastings generally need vibratory or other mechanical finishing before the chemical steps, and usually require copper plating before any other plating.
Q. Ni Cr Plating on Zinc Casting Part – Blister Observed in the part after 4 months
Coating – Copper Coating + Bright Nickel on Zinc casted part
vee
– tamilnadu
September 17, 2025
This is a meeting place for camaraderie & sharing, not a free consultancy. So some readers don’t engage with anonymous posters.
The blister problem after Ni/Chrome plate because of cleaning problem; do the water break test; after acid dip, rinse the part watch if the water drips down like oil. Or white paper towel wipe the part: if there is black residue on paper towel, the part is not cleaned right,
Popatbhai B. Patel
electroplating consultant – Roseville, Michigan
