Summary for copper anti tarnish Discussion
Anti tarnish for copper coating is the core issue in this thread about imitation rose gold jewelry made from a Cu-Ag alloy. Panjala Mukesh Goud says he needs a non-E-coat anti-tarnish treatment that will preserve the glitter/sheen of the stone and still survive a 1% polysulphide test, which he explains is essentially a sulfurated potash or liver of sulfur test for copper/silver top layers. Jon Barrows replies that he is not familiar with the exact standard or how the test is interpreted, but notes that sodium benzotriazole and related compounds are commonly used to help prevent copper tarnish. In a follow-up, Panjala says benzotriazole-treated pieces still turned black in the polysulphide test, and that other anti-tarnish solutions also failed. The thread therefore suggests that standard benzotriazole protection may not be enough for this specific test, and no proven alternative is identified in the excerpt.
Q. I do imitation Rose gold ( which is an alloy of Cu-Ag). I WANT A GOOD Anti tarnish, not E-coat which has to withstand 1% polysulphide test, so that glitter/sheen of the jewellery stone should not diminish.
Panjala Mukesh Goud
Employee – Hyderabad, India
September 4, 2025
A. Hi Panjala
Is there an ASTM, ISO. or other standard governing this 1% polysulphide test you are speaking of? I understand what polysulphide is, and that it can blacken and otherwise corrode copper, but I’m not understanding how you conduct this test or interpret the results.
The best copper preservatives to forestall tarnishing of copper are sodium benzotriazole and related compounds, and they are quite routinely applied to copper surfaces, but I don’t know whether they will get you past the requirements of a test that I’m not familiar with.
A. The test is supposed to be for silver plating on top of copper wire. After the procedure, the surface turns black from reaction with the copper base metal when the silver plating is not fully protecting the copper. Since you are plating a copper-silver alloy instead of unalloyed silver, the ASTM B298 test may not work no matter what you do. Perhaps I am wrong and the alloy plate layer does not discolor in the test procedure. If that is the case, your best bet is to plate a thicker coating.
Jon Barrows, MSF, EHSSC
Independence MO
Q. Thank you! This Poly Sulphide is Nothing but Sulphurated Potassh (Liver of Sulphur). This is one way of testing Copper/Silver top layers for Tarnish test. When copper-coated piece is dipped in benzoTriAzole solution, piece dried, and subjected to 1% Polysulphide test, it has tarnished to black. Tried other Anti Tarnish solutions … not withstanding polysulphide test.
Panjala Mukesh Goud [returning]
– Hyderabad, Telangana
September 19, 2025
A. Hi Panjala,
As a jeweler, I’ve had success protecting from tarnish using clear ceramic coatings such as Cerakote (or the abundance of similar alternatives available on the market).
I’ve had pieces coated with this material completely resist darkening when exposed to liver of sulfur, and similarly been able to use it as a sealant to prevent the patina from spreading even when the pieces were submerged in water for weeks at a time, and these products don’t interfere much with the brilliance of the gemstones.
Morgan Harding
C.E.F/Bench Jeweler – Woodstock, IL
November 25, 2025
