Shot Peening: Powerful Guide to Fatigue Resistance
Summary for shot peening Discussion
Shot peening is a surface treatment that, as Ted Mooney explains, is similar to bead blasting in that tiny hard balls repeatedly strike the part, but the goal is different. Instead of cleaning or roughening, it intentionally indents and compresses the surface. Ted says this can help a component better withstand the stresses of later plating and, more importantly, reduce sensitivity to fatigue failure. Under repeated loading, surface stresses can cause cracks or stress risers to grow until the part fails; shot peening leaves a permanent compressive stress in the surface so it stays from going tensile, or only mildly tensile, during service. He notes that airliner landing gear is a well-known example of shot-peened parts. The thread is brief and contains no disagreement, just a clear definition and practical purpose.
Q. What is Shot peening?
Ed. note: Co. name deleted. Corporations aren’t people, please use person’s name next time
Owner – Canada
July 30, 2025
A. Hi.
Shot Peening Books
shot_peening
AbeBooks
In a way, shot peening is similar to bead blasting — the surface is repeatedly impacted with thousands of tiny, hard, balls — but the purpose, and therefore the operating parameters, are different.
The purpose is to indent and compress the surface, and a couple of common reasons for that would be to make it more compatible with the stresses of subsequent plating, and to make the component less sensitive to fatigue failure.
What happens with “fatigue” loading is that the stresses on the component vary, sometimes even all the way from tensile to compressive and back. This repetitive sequence, if the loading stresses are rather severe, can cause a high stress point on the surface to fail, or a very tiny existing crack, a stress riser, to get worse with every cycle until failure.
What shot peening does in this case is put a permanent compressive stress into the surface, such that even under tensile load the surface of the component never goes tensile, or at the least, stays only very mildly tensile, so that fatigue failure is not initiated. One of the best known examples of shot peened components are the landing gear on airliners.
You can search the site with additional search terms of your choice to see several dozen threads about specific aspects of shot peening.
Q. I found your website for some copper questions and I’m just amazed that it is still being used to this day. This is spectacular and awesome. Since 1989. Incredible.
You can learn something new every day and I was just looking around here … have not heard of shot peening but I wonder what its benefits are. I may go Google it but if people get into the conversation I will follow the thread when I can. Thanks again for keeping this website up, like you said the good old days where people can just comment and chat without ads- wow pretty amazing!!
Laur Hair
Education – Seattle, Wa
August 2, 2025
thumbs up sign Thanks for the kind thoughts. Yes, we were a dial-up electronic BBS before the internet.
We’re not ad free (servers & domain names cost money), but pop up ads and sticky ads drive us bananas, so we don’t inflict them on anyone else. We remember the ‘surfing the web’ days, so we remain no registration / no ‘premium content’  🙂
A. Critical components that are under severe stress like landing gear are in danger of suffering ‘fatigue failure’ whereby one tiny point on the surface of the component suffers a tensile load that is a little too high, causing a tiny rip or failure at the very surface. As the loads on the component keeps shifting back and forth, that initial failure point just keeps slowly growing.
But if you properly shot peen the component, repeatedly slamming those tiny balls into its surface, you’ve smooshed the steel on the surface in, compressing it. Now as you apply tensile (pulling) loads on the component, its innards, its middle may be under tensile stress but all that compressive stress on the surface has to be removed before the stress at the surface can even become tensile. The intention and overall effect is that if the outer surface never suffers high tensile stress, so potential stress tears don’t get a chance to start and propagate.
You can search the site with the term “shot peen” to see more than a dozen discussions about it.
Regards and thanks again,
