Need sulfuric Acid
"Sulfuric Acid Use and Handling"
on
AbeBooks
Q. Where would one go about finding approx. 5-gal containers of sulfuric acid? Everywhere I call people seem to think I'm crazy for wanting that much. Local parts stores here have 6 qt containers for ~$12. I would rather try and find a local shop nearby where I can pick it up rather than trying to have it shipped to my work. Any ideas?
Michael Spillers- Buford, Georgia
September 16, 2008
A. Hi, Michael. sulfuric acid is readily available in 12 gallon carboys and 55 gallon drums (I'm not sure about 5 gallon containers). Plating, anodizing, and metal finishing shops use large quantities of this, so look up 'chemicals' or 'plating distributors' in the yellow pages of a nearby large city if you can't easily find it online.
However, I suspect that part of the problem may be in your wanting to pick it up rather than having it shipped. This is a hazardous material with D.O.T. shipping restrictions. While there my be an exemption for small quantities of dilute acid for sale to consumers as battery acid [affil links], the suppliers may be prohibited, either by law or a good stewardship pledge, from allowing you to drive off with a larger container or a less dilute solution. Good luck.
September 17, 2008
Student needs Sulfuric Acid
March 12, 2012Q. WHERE CAN I FIND SULFURIC ACID IN SAN DIEGO CALIFORNIA? I'M IN 6TH GRADE.
ALBERTO J. [last name deleted for privacy by Editor]- SAN DIEGO, CALIFORNIA, UNITED STATES
March 14, 2012
A. Hi, Alberto. The only place a 6th grader should get sulfuric acid is from his science teacher for use while under his/her direct supervision :-)
Q. My science teacher doesn't have any; my email is [deleted by editor]
alberto j [returning]- san diego, California, usa
April 18, 2012
Sulfuric Acid for Drain Clogs
on
A. Hi, Alberto. sulfuric acid
[affil links] is easily available.
But the point is that it is extremely hazardous for any adults who have not been trained in its use. It's out of the question for 6th graders except under the direct supervision of their science teacher. 6th graders probably shouldn't post their e-mail address on the internet either :-)
Please explain what it is that you want it for; maybe we can then suggest a safer way to do your experiment? Good luck.
April 19, 2012
Q. For a science project on chemical reactions. I really need this for an A+.
April 19, 2012
A. Hi again. Even a graduate chemist would want goggles [on eBay or Amazon] and rubber gloves [on eBay or Amazon], and maybe a chemical apron [on eBay or Amazon] or other personal protection equipment before using this ... hopefully you are all set in that area. If you are going to do this repeated warnings, have your parents get battery acid [affil links] from a local auto parts store and supervise you; this diluted sulfuric acid is at least somewhat less dangerous than concentrated acid.
April 21, 2012
A. If my 6th grade child was using Sulfuric Acid (even battery acid) for a school project, I'd be having a word with the teacher, if it was indeed required for a school project.
Am I the only one that thinks this is a bit much for a child to be handling this young of an age?
Times sure have changed.
Marc Green
anodizer - Boise, Idaho
May 5, 2012
May 7, 2012
A. Hi, Mark. If Alberto is a real 6th grader, I'm almost sure that there is no teacher in the country who would suggest that he buy sulfuric acid for an experiment.
