Q&As since 1989
Problems in hard chrome plating on electroformed nickel sugar screens
Q. I am a manufacturer of hard chrome plated Nickel Screens. I need 8 to 10 microns of hard chrome plating on finished jobs. At present our CHROME BATH chemical analytical report is as follows:
SULPHATE 2.5 g/l,
DENSITY 22 ,
Chromic Acid 250 g/l
My problem is after hard chrome plating the finished job is poor/dull finish. I want decorative finish for my finished product.
Manufacturer - Pune, India
A. If you buy or borrow a good book on chrome plating, you will see that there is a bright range for a given tank temperature vs. amperage. Both control plate rate also. Amperage is also going to depend on anode to cathode spacing. - Navarre, Florida Are you using any proprietary brighteners? If not then talk to a local hard chrome supplier and see what they can offer in brightened hard chrome technology. Aerospace - Yeovil, Somerset, UK |
Q. I want to know which chemistry can be used in hard chrome plating on nickel screen.
We are using organic catalyst base hard chrome process, but we are facing a problem like dull finish on perforated area. If you know which chemistry is used by M/s Stork Veco, Netherlands, please inform me about my problem and increased hardness.
Thanks, with regards.
job shop employee - Ahmedabad, Gujarat, INDIA
August 2, 2010
(to provide context, hopefully helping readers more quickly understand the Q&A's)
Please search the site for info on Hull Cell but, briefly, it's a tiny plating tank for plating test panels wherein the test panel is close to the anode at one end and far at the other so that the effect of current density on the plating can be easily seen.
A. Hi, Bhavin
Veco has a good white paper about electroforming which you can download, but I don't believe it discusses hard chrome plating. We must respect trade secrets so we cannot post any information about their processes.
I doubt that any organic catalyst hard chrome plating process is unsatisfactory, and believe that the lack of brightness may be due to insufficient current density. A Hull Cell test panel may reveal that your plating solution is delivering a limited bright range. If possible, send us a photo of the Hull Cell panel, and a well focused pic of the dull plated area on your screen. Good luck.
Q. We are a manufacturer of electroformed nickel base sugar screens. At present we are facing problems in hard chrome plating like dull deposition on perforated areas and not getting enough hardness. As well as we do not achieve enough brightness on perforated areas.
Please suggest to us which steps will improve brightness and hardness.
At present we are using organic base additive chrome process of M/s Stork Veco, Netherlands. .Kindly suggest what we can use for getting more hardness.
Please do the needful. Thanks. With Regards
industrialist - Ahmedabad, Gujarat, India
August 9, 2010
"Hard Chromium plating" A. How can people help if you tell us nothing of your process? - Navarre, Florida A. Maksud, Aerospace - Yeovil, Somerset, UK |
A. The people of StorkVeco are world recognized experts and you are buying from them. They are the ones to ask, not us.
G. Marrufo
Monterrey, NL, Mexico
