Q&As since 1989
Stripping gold from silver dollars to restore them
Q. Disclaimer: I am not in the business. I am a person who stumbled upon this website while doing a search regarding gold plate stripping. Today, I purchased a genuine Eisenhower (silver clad) silver dollar at an antique show for a great price. Trouble is: it was plated with gold. Is there any way I can remove the plating without harming the coin?
Chris Arthurpostal worker - Columbus, Ohio
A. You can use 1 gm gold chloride + 5 to 10 gm water etching solution! Object must be immersed in solution (connected to + of 9V battery, piece of stainless steel to -)!
Remove Gold from plated silver dollar
Q. I have a 1900 silver dollar that I had gold plated many years ago to use on a necklace. I would now prefer to remove all the plating. What can I do that's reasonably simple.
Elaine Michelson- Tamarac, FL, USA
February 8, 2009
A. Elaine,
There are ways to strip the gold or to employ reverse current stripping. The chemicals and equipment needed could be dangerous to you. A good old fashioned Jeweler in your area could use a mild abrasive on a buffing wheel to get the gold off and then polish the silver so you have a great looking coin! It should not cost that much.
Fellow Plater - Syracuse, New York, USA
Q. How can you remove gold plating from a 1923 Silver dollar. It has turned very dark. Thank you in advance for any assistance.
Marsha Simpson- McKinney Texas USA
July 17, 2015
1923 Silver Dollars on eBay
A. Hi Marsha. Your inquiry sounds very similar to previous ones. The best way to remove the plating is to polish it off -- especially because it your case i sounds like he gold and silver diffused. But if this is your first attempt at jewelry polishing you'll be putting your memorabilia at risk. Taking it to a jeweler is an option, but maybe not an affordable one. Good luck.
I will check with a professional.
