A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing.
    no popups, no spam
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4576
What is Emissivity?
(2000)
I am looking for any information on "emissivity" or heat radiation properties of anodized aluminum. What is it and how can it be kept constant from load to load. A potential customer has told me that a difference of 0.2 can occur from load to load and this is to much of a difference. She needs assurance that this will not happen, but I can't do this if I'm not even familiar with the term.
Erin Lewis
anodizing - Calgary, Alberta, Canada
(2000)
Emissivity, generally indicated by Greek letter epsilon, and ranging from 0 to 1, is the ability of a body to receive or transmit heat power as infrared radiant energy.
The radiant power emitted by a body is proportional to its temperature to the fourth. An ideal "black" body has an emissivity = 1. For the real bodies the emissivity depends to a large extent on the surface finishing. For specular surfaces, emissivity can be as low as 0.03, for rough surfaces over 0.8.
Typically, emissivity of black anodised aluminum is 0.85.
Emissivity can be measured by means of suitable instrumentation.
Basics on the topic of power radiation can be found in every book of heat transmission; a lot of data can be found in many handbooks, e.g.edited from NASA or ESA.
pasquale cirese
- campi bisenzio - Italy
Infrared Thermometer
(2000)
Just a correction in the term "transmit" used by Pasquale. Transmit means a wave, e.g., IR, passing through without absorption, like in light transmitting through a glass. Then there is reflectivity. Most relatively smooth metal surfaces tend to reflect a substantial portion of the IR radiation. The ideal Black Body with emissivity of 1 absorbs all heat received and emits all of it. No transmission and no reflection (unless my fundamentals are questionable).
Mandar Sunthankar
- Fort Collins, Colorado
(2005)
Given a blackbody radiant cure zone for a paint finishing oven, if there is an area with clear metal (i.e., high "e" coating has been removed) will the (heated) surface / skin temperature be greater than surrounding area?
Cindy Dilworth
industrial / process air handling - Detroit, Michigan
January 22, 2010
You can measure emissivity to a fairly high level of accuracy with an infrared camera such as those manufactured by FLIR. Search for the term "emissivity" on Youtube to learn more.
David Brown
infrared training - Billerica, Massachusetts
Practical Temperature Measurement
from Abe Books
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Comment to THIS thread START a NEW threadView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
