A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4436
Adhesion Test for precious metal plating
(2000)
Q. Dear Reader,
I am interested in a non destructive adhesion test for electroplated stainless steel parts with a precious metal. I would be grateful for any suggestions with regard to this test as it is proving quite difficult to find any company / literature which can offer a solution.
Sean O Reilly
- Republic of Ireland
simultaneous (2000)
A. Adhesion tests are destructive to at least the plating. the chisel test is the only test that I am aware of that is only minorly damaging to the parent metal.
Most shops will run test panels or scrap parts that are absolutely identically processed and those are destroyed.
A. Hey Sean,
I have used a high tach (very sticky) cellophane tape (I think is was Scotch tape #602). All you do is press the tape in place and run your finger over it to get out the air and make good contact with the surface. A quick pull of the tape should tell if you have adhesion. As I remember, the tape represents about 5 to 10 pounds per square inch. A little bit of alcohol on a soft rag (we used a lint-free paper product) will clean off the residue.
Fred Mueller, CEF
- Royersford, Pennsylvania
simultaneous (2000)
A. I conduct testing of plated and coated automotive parts. You might want to get a copy of ASTM B571 [link by ed. to spec at TechStreet]. This is a specification from the American Society for Testing and Materials and is titled "Standard Practice for Qualitative Adhesion Testing of Metallic Coatings." It is a few adhesion tests that may or may not be applicable to your situation. I have found that adhesion testing usually is destructive, even some of the tape tests.
I have done some adhesion testing in the past. The tests I have done consist of a corrosion test (salt spray or CASS), scribing the part (which is destructive) before or after the corrosion test, then using pressure-sensitive tape. The tape is applied then peeled away quickly to see if any coating or plating peels away with the tape.
I hope this helps!
tim neveau
Tim Neveau
Rochester Hills, Michigan
(2000)
A. You might also try glass bead peening. It is used on IVD aluminum coatings all of the time with little damage to the substrate. If the coating comes off, the adhesion is bad. The peening also densifies the coating, important for IVD aluminum. Any IVD aluminum facility will have a glass bead capability if they do work for the military -- it's part of the MIL spec.
jim treglio portrait
Jim Treglio
PVD Consultant - San Diego, California
(2000)
A. The tape test is a formal test for a couple of things in metal finishing. I do not think it is appropriate for a precious metal finish. I would not want to buy a watch or a pin or a pen that I paid gold, silver, or etc. price for to only pass a tape test. I doubt if your customers will buy off on it either.
A. Sean,
Have you tried a bake test? We have used bake testing to not only enhance adhesion, but to check for blisters and lifting plating. (250 Degrees C for 1.0 hour, 400 degrees C for 5-20 min. pending on the grade of your Au deposit.)
Good Luck,
Mark Kruzel
- El Cajon, California
(2000)
A. Dear Mr Sean,
There is this test prescribed for Silver Plating in Indian Standards :
that is to take a round tipped Mild steel rod and rub it back and forth five six times on the Silver/precious Metal plating . The Heat caused by the vigourous rubbing and pressure applied causes an improperly adhered plating to come off and fail the test.
Haven't tried it myself and I am quoting from a Sunday morning hangover memory. If you want a copy of the Indian Standards, write again with your mailing address to enable me send it to you.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind supporting advertiser
Bangalore, Karnataka, India
saify logo
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Comment to THIS thread START a NEW threadView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
