Q&As since 1989
Chrome In Cleaners
Hi Can we add sodium hydrosulfite [on eBay or Amazon] in our electro cleaners to reduce hexavalent chrome. Currently we are at 2000 ppm of Chrome in cleaners.
If so, then what would be the by products and would they affect the cleaning process or the life index of the bath.
Also what else can we do to reduce any chrome in cleaners. Thanks
Hemant Kumar
- Florida, USA
Hi Hermant.
You can use dextrose to reduce the hexavalent chrome to trivalent chrome.
Regard
Anders S
Anders Sundman
Consultant - Arvika,
Sweden
Hemant,
We use sodium hydrosulfite all the time in our cleaners without any residual effects. The by products I'm not sure, but to reduce if you have coated racks that are cracked or have holes they should be fixed they hold a lot of solution. Unfortunately it is usually the solution that causes problems.
KH
Ken Hutchinson- Minneapolis, Minnesota, USA
Steve Rudy in his Finishers Think Tank column in the February, 2000 issue of Plating and Surface Finishing gives a nice recap on the handling of hexavalent chromium in an electrocleaner (page 47).
Ken Lemke
Burlington, Ontario, Canada
Thanks Mr. Lemke.
you already gave me some good piece of advice on this topic during our meeting at the AESF/CAMF branch gathering.
I will try to get that paper which you indicated here.
regards
hemant bansal
Hemant Kumar
- Florida, USA
