-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 4302
Blistering/Flaking Plate on High Carbon Steel
I work for a custom metal stamping house and we have a long running problem with a part made from high carbon steel. The part is plated with the following specs:
Sometimes the plate looks great, other times it comes back showing poor adhesion and blistering. The plate will flake off leaving the steel exposed. This has occurred from several of my platers. Can anyone shed some light on this? Do I need to change my plate specs?
Adam Rubin
- Brockton, Massachusetts
Hi Adam.
What type of zinc process are you using? Sulfuric acid zinc is to prefer to plate high carbon steel. It's help to treatment the parts in sulfuric/hydrofluoric acid. You can also try to bake the parts in a oven before plating in 302 F in 1,5 hours.
Which temperature are you use and how long time did you bake after plating. Regard Anders S
anders sundman
Anders Sundman
3rd Generation in Plating
Consultant - Arvika, Sweden
High carbon steel suffers from undercleaning and from overcleaning. The alkaline cleaner and the etch solutions need to be controlled a lot better than on a low carbon steel. The exact "dirt" has a lot to do with the length of cleaning. The amount of heat scale may require special processing tanks like alkaline permanganate.
I would recommend starting out looking the cycles and options listed in "Electroplating Engineering Handbook " edited by Durney.
You may have to hire a qualified consultant. Unfortunately, if he/she is not local, that can get expensive, as your problem is random. To solve this problem, you almost have to see the parts, the processing and the results for the good and the bad ones.
Dear Mr Adam Rubin,
Most of the embrittlement occurs during pickling and during the first few minutes of plating. As no two batches of parts are possibly made or plated alike, the variations you experience are quite common.
Cyanide Zinc doesn't get as bad in de-embrittlement on account of a vertical grain structure whereas the Chloride Zinc plating gets ugly on account of the escaping hydrogen rupturing the horizontal grain pattern badly. However the Cyanide process may embrittle your heat treated high carbon parts faster on account of the lower bath efficiency.
The way out of this catch 22 situation would be to plate again for about 10 - 20 minutes after de-embrittlement to repair the damaged Zinc coating using a Chloride Zinc plating process both times. There is little fear of embrittlement again during the second plating since you will be using a chloride process which doesn't embrittle the substrate especially after you already have a thick Zinc plating and then complete the process with passivation as the final step.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind supporting advertiser
Bangalore, Karnataka, India
saify logo
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
