Q&As since 1989
Salt spray test for anodized aluminum
Current question and answers:
Q. White Rust and red rust on anodising finish.
HAVE A PROBLEM WITH WHITE CORROSION AFTER SALT SPRAY TEST IN ANODISED JOB. THIS IS AN ON GOING PROBLEM.
HAS ANYONE ELSE HAD THIS AND SOLVED IT PLEASE?
- Chennai Tamilnadu
February 25, 2021
Aluminum How-To
by Robert Probert
You'll love this book. Finishing.com has sold 880 copies over the years without ever a single return request :-)
A. Hi cousin Prakkash. In short, your parts or panels failed the salt spray test :-(
The many reasons they may have is the subject of dozens of long highly detailed threads here :-)
The only way to start is either to retain an anodizing consultant or to investigate with full particulars. Are you testing parts or test panels, what spec are you anodizing to and to what thickness, how many hours of salt spray, what is the alloy, what is the cleaning, etching, de-smutting, anodizing, dyeing, and sealing process, etc?
February 2021
Q. How much salt spray are recommended for Aluminium 6063-T6 grade with black anodizing done having 15 micron thickness radially.
Ajeet AmbadeQuality head - Nagpur Maharashtra
June 4, 2022
A. Hi Ajeet. A better way to answer your question may be to say that you should be anodizing to some specification, and that specification will tell you how many salt spray hours are required. For example if you are anodizing to MIL-A-8625 it requires 336 hours.
June 2022
Q. Dear Sirs:
I am searching for standards requirements of aluminum anodized parts on salt spray fog testing.
Thanks in advance,
Leonardo Della MeaInstituto de Ensayo de Materiales - Facultad de Ingenieria - Universidad de la Republica - Montevideo,Uruguay
A. Leonardo,
MIL-A-8625 / MIL-PRF-8625 [on DLA] specifications refer to ASTM B117 for the salt spray requirements. The test is specified at 336 hrs with the 3"x10" test specimens. This is a very standard testing application.
Best of Luck.
Ira Donovan, M.S.F.Kansas City, Missouri
"The Surface
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
on
AbeBooks
Q. We are anodizing 6063 aluminum section up to 15 microns now our customer want us to inform how many hours of salt spray will this section withstand. We want to know how many hours of salt spray test this kind of section (6063) with 15 micron can withstand in normal conditions or what is the hours of salt spray test that anodized aluminum can withstand.
Satish Shahchemicals - Anand, Gujarat, India
A. Anodizing and its thickness is only part of the equation. The largest determinant in corrosion resistance of an anodic coating, regardless of electrolyte type, thickness, etc. is the SEAL. While HEXAVALENT CHROMIUM historically has performed best for this purpose, the EU is legislating this practice out of existence! Hot DI or nickel acetate seals can meet the standard requirement of 336 hours of salt spray BUT the quality of the seal, temperature and time are CRITICAL.
Milt Stevenson, Jr.
Syracuse, New York
Q. We have a cast aluminum assembly that is currently powder coated (phosphated first). The coating is failing particularly gravel tests. It is an automotive part. Is anodizing an option and how well does it stand up to salt spray tests (1000 hours). These parts need to be black. I think the anodizing will survive but will the color?
Peter ElfordPangeo - Windsor, Ontario, Canada
A. Hello Sir
It all depends on the cast-alloy you're dealing with. High silicon content will result in thin anodizing layer, and poor coloring.
- Eindhoven, Netherlands
"Corrosion of aluminum and Aluminum Alloys"
on
AbeBooks
A. Hi Peter E.
In addition to what Peter M. advised, anodizing probably is more gravel-resistant than powder coating. But anodizing (and most inorganic coatings) will not pass a 1000-hour salt spray test designed for organic coatings. One third of that, 336 hours, is a fairly standard test for anodized coatings on test coupons. This is not a statement that anodizing is less corrosion resistant, but about the fact that salt spray test results are not a prediction of real life beyond their use as an early warning that a process is getting out of control. Good luck!
Q. What are some of the failure modes relating to the anodizing in relationship to sealing with nickel acetate?
Cal RonaldQuality - Detroit
April 30, 2008
May 1, 2008
A. "Aluminum How-To" lists the following impurity levels in ppm's: Phosphates 5, Silicates 10, Heavy Metal (Cu,Zn,Fe) 10, sulphates 100. Chlorides 50, Fluorides 5. Look out for galvanic voltage between titanium and stainless steel tank.
Keep pH as high as possible but under 6.0 where the nickel flocks out. Zero on Calcium and Magnesium. Understand that the seal is the weakest solution in your line THEREFORE it is the easiest to contaminate. One ounce of junk in the anodizing tank is 1/22 contamination. One ounce of junk in the seal is 1/1 contamination. Anything that makes the pore large interferes with complete sealing: high anodizing temp, high anodizing acid, low anodizing current density.
A. Cal
1] Too low of nickel (acetate) content
2] Too low of temperature
3] Too short of immersion time
I am sure there are more.
- Colorado Springs, Colorado
May 1, 2008
Q. How long should black anodized (Type II, Class II) last in a medical environment, where the product could come into contact with Saline solution on a daily basis. If the product was tested and approved to ASTM B117 standards how long should the product last, i.e., days, months, years?
- Oceanside, California, USA
April 25, 2013
A. The chloride in the saline solution will attack the seal, then the oxide, then the aluminum. The time to noticeable attack is a function of the strength of the saline, the temperature, and the pH -- but days, not weeks. The aluminum people have been trying for years to sell aluminum anodized trays for autoclaving and sterilizing medical instruments but, again, the temperature and high pH destroys the anodic coating. Robert H Probert Robert H Probert Technical Services Garner, North Carolina April 29, 2013 A. Hi Kevin, Aerospace - Yeovil, Somerset, UK April 30, 2013 |
We are doing Anodizing on aluminium extrusion, material is 6063-t6, used as exterior panel. I would like to know about SST life (white rust).
Nitin
R V Components - Mumbai, Maharashtra, India
March 31, 2018
"Anodizing and Coloring of Aluminum Alloys"
by S. Kawai
on
AbeBooks
Sorry, this book was not available from any of these sources in Oct. 2023, but we'll maintain the links in case a copy turns up :-)
A. Hi Nitin. We appended your inquiry to a thread which notes that 336 hours is a widely accepted standard.
However, industries like architecture often have specific standards. For example, "architectural anodizing" is usually 0.007" thick rather than the lesser thicknesses often used in other applications, and some sort of inorganic dyeing (two-step, integral color, or overdyeing) rather than the common organic dyeing is usually required. Whether architectural standards would apply to RV exterior panels, or whether there are other standards expected in your industry, sorry, I don't know.
March 2018
Salt spray test failed on anodized 6061-T6
Q. I have done sulfuric acid anodizing with TCP sealing process the part material is 6061-T6 and Panel material is 2024-T3.
Two different types of material process have been completed.
After the process has completed we have kept both panel and part in salt spray chamber. Since 48 hours pit marks observed on the parts, but panels are good -- salt spray passed 336 hours.
Before we started the process I had checked bath concentration and sealing concentration within limit. And water quality is good.
Kindly advise how to proceed further process?
- Bangalore, India
June 7, 2019
A. Hi Karthick. To me the abbreviation 'TCP' means Navair's 'Trivalent Chromium Process' as a replacement for MIL-DTL-5541 [on DLA] Chromate Conversion Coating. I don't know quite what TCP means to you ... some proprietary sealing process for anodized aluminum based on trivalent chromate? Sorry, not being familiar with it, I don't know whether you should expect 336 hours of salt spray resistance or not.
I am not highly experienced in salt spray testing, but why are you using 2024-T3 panels if the parts are 6061-T6? It is a surprise to me that 2024-T3 panels can survive 336 hours while 6061-T6 parts last only 48 hours, especially when you anodized the two different alloys simultaneously -- but it does seem like something is defective in your 6061-T6 material. Are you sure the panels stayed with your work pieces through cleaning, etching, de-smutting, anodizing, and sealing?
June 2019
