A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 4121
Removing polymer release agent
(1999)
We are using structural high density foam to pour in Epoxy mold.
But prior of Pouring we spray the mold with Polymer base release agent and then applying the Polyester Gel coat by means of spray, then we pour the material into the mold in order we can have a post finished molded part.
The problem we are having is getting rid of the release agent which was applied in the mold prior of the pouring. We solved a problem but we are stuck with another one, which we are having hard time in getting adhesion between the material and the paint.
I am looking to use a type of a release agent which will not create problems in painting the produced parts.
B.J. Najarian
furniture - Lps Angeles, California
Dear Sirs,
We are looking for Green Case Outside Paint( Outside Release agent) in Tire making processing like Goodyear,Michelin,Yokohama Tire Factory. Can you help us find this product ? Please let us know manufacturers of Tire outside release agent. Composition : Green Case Outside Paint( Release agent ) Blend of Binder and Fillers Modified Special Additives. Application: During the curing of green case,it enhances air permeability, decreases bare of tire. Because of water-based type, no more danger of fire exist, different from solvent-based type
Yours very truly,
Kyu Ho C [last name deleted for privacy by Editor]
- Gwangju, South Korea
(2004)
Although Green Outside tire paints, to avoid tires adhesion to the mold, promote slip between green tire and mold during bladder expansion allowing air bleeding, and then, release after curing cycle, are proprietary formulations, several leading companies produce them I will mention a few names, it is up to you to trace them to contact them:
- Chem Trend (US)
- Rhein Chemie (Germany)
- Yongjin (Korea)
- Darmex (Argentina)
Good luck. I understand that all of them offer product in South East Asia.
Austin W [last name deleted for privacy by Editor]
- Buenos Aires, Argentina
April 2, 2008
The best mold release agent for different rubber compounds is Dupont TraSys Release Agent, based on product evaluation and field trials.
Russ Cano
- Manila, Philippines
April , 2008
Hi, Russ. Thanks. Please tell B.J. what kind of paint you applied to your rubber compounds, and what process you used to remove the mold release, when your shop determined that the Dupont product solved the paint adhesion problem; it's not immediately clear to me how this product fixes his problem. Thanks again.
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
