Copper Table Finishing: Smart, Simple Shine Options
Summary for copper table finishing Discussion
copper table finishing is mostly a matter of taste, according to the answer. Becca Grace Weaver asked whether a copper tabletop made from an old etched printing plate should be left bare, cleaned periodically, or protected with lacquer or glass to prevent oxidation and scratches. The reply says it is hard to advise on appearance preferences, but if the goal is to keep the copper looking bright, Ted Mooney recommends applying brass lacquer. If the owners are comfortable with the metal aging naturally, he says he would simply clean it periodically with Brasso or another copper polish. The answer does not recommend glass as necessary, and it does not discuss polyurethane in detail; instead, it frames the choice as shine retention versus natural patina and routine maintenance.
Q. My friends and I are redoing our basement this summer and we want to make a table with a copper top. We found an old copper plate that was used to print a map (it’s a large flat rectangle of copper with etchings that used to hold ink for the map). We want to use this plate for the top of a table that we’re building. However, as copper is an active metal and will oxidize easily (especially with use), we were wondering if there was a good way to finish the table so that it will keep its shiny glow.
Another concern we have is if the copper will be easily scratched by use as a table- should we cover it with glass or will a laquer be enough?
We are also concerned with using harmful chemicals and would tend to shy away from substances such as polyurethane, but we’re not completely against using it. It also seems that it may be better to leave the copper unfinished and periodically clean it with lemon juice, or some other cleaning agent.
What lacquers and/or cleaning solutions would you recommend for our copper table?
Becca Grace Weaver
Cooperative House – Saint Louis, Missouri
A. It’s hard to advise on matters of taste such as whether you will be happier retaining the shine or allowing the tabletop to age. If I had the item I think I’d just periodically clean it with Brasso
on
Amazon [affil link] or other copper polish, but that’s me. To retain the shine instead, apply brass lacquer.
Q. If I have a copper table that has little to no shine what can I use to give it a lasting glow? Is there anything that will last for an extended period of time like a polyurethane or not? Thanks for your thoughts, Adam
Adam proud
– Cincinnati, Ohio
October 2, 2014
Mothers Polish
mothers_polish
Mothers Polishing Tool
mothers_powercone
Hi Adam. When metal loses its shine there may be two factors involved: a tarnish layer, which is a metal oxide, and doesn’t have the brightness of the bare metal, and roughness of the surface so that it doesn’t offer specularity (it’s no longer mirror-like).
The best way to attack both problems at the same time is with a fine buffing compound on a powered buffing wheel. Powerful buffing wheels are dangerous for the untrained if something gets away from you, but you can probably hold on to a 14.4 volt battery operated drill. Probably the easiest to use and most available combo would be Mothers Aluminum & Magnesium Polish (it works well on copper) and their buffing attachment.
After you have it the way you want it, brass lacquer can keep it that way for a reasonable period, especially indoors. Best of luck.
nikolasbanner
“Clearcoats/Lacquers for Brass from G.J. Nikolas”
