Anti-reflective process for 416 stainless
I have an optical assembly made of 416 stainless steel that is giving me reflecivity problems. I'm looking for a means of giving it a low-reflectance surface. Paint is not a good option, because lenses must be epozied to the surface and masking these areas of the surface is extremely difficult. Also, cleaning of the lens with acetone on eBay or Amazon [affil link] Flammable! is likely to mess up the paint and possibly smear it onto the lens.
I prefer a chemical process which alters the color/ reflectivity of the metal's surface, will allow epoxy adhesion similar to that of the untreated surface, and will cause minimal out-gassing in a vacuum environment.
That's a tall order, but does anybody have any suggestions. . . please?
Andy Chouinard
Conway, Arkansas
I'd look at a thin PVD coating, maybe 0.2-0.3 microns thick. If it's a Zone 1 coating it will have an open columnar structure, making it a poor optical reflector. As the coating is applied in a vacuum, it is certainly vacuum compatible -- more so than any chemical coating. Most job shop houses won't do the job, but you should be able to find a bell jar e-beam or sputter system at a university or on the used equipment market. Colorado School of Mines in Golden, CO, has a couple of units that could be used, as well as students to do the work, assuming that the assembly is not too large.
jim treglio portrait
PVD Consultant & Wine Lover
San Diego, California
I feel that a black coating would do a good enough job. The possibilities are black oxide type coating or passivation, or back chrome plating.
Mandar Sunthankar
- Fort Collins, Colorado
