Color won't stick when anodizing
Aluminum How-To
by Robert Probert
Also available in Spanish
You'll love this book. Finishing.com has sold almost a thousand copies without a single return request :-)
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
on eBay or Amazon
I was wondering if anyone can figure out why the color won't stick on my parts. I'm new to this, but maybe this info will help. I'm using sulfuric acid/water mix (70/30 respectively). The instructions said to keep the part in the acid bath for 10-15 min. after the fizzing started. Then soak in a warm color bath. I'm using red dye but I end up with a Gold-ish color all over with some red lines. Sorry so long!
Chris [last name deleted for privacy by Editor]- Hampton, Virginia
Hi, Chris. Were the parts properly cleaned before anodizing? Typical anodizing solution is 10 percent H2SO4 by volume, not 70 percent -- something is drastically wrong with your instructions! What temperature are you holding (should be 68 - 70 °F). How many ASF are you applying? Sounds like you have virtually no anodizing layer due to current too low and acid too high. Good luck!
