-- The Home Page of the Finishing Industry
A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
on this site
current topics
topic 3125
High temperature zinc plating application
Q I am looking forward for zinc plating treatment for a component made up of mild steel my application asks for temperature resistance of 250° C to 30° C in a cyclic mode cycle time is approximate 1/2 an hour. which type of zinc plating and process can suit these requirements so that the chipping off of the metal does not happen in the service life of 3 years.
rajesh sampat
ate - ahmedabad,gujarat , india
I would't try to use zinc for such an application especially in humid environments in India. It will likely fail within a few months.
Mandar Sunthankar
- Fort Collins, Colorado
Zinc melts at 420 degrees C., and softens very appreciably by 150 degrees C., so there may be some issues of applicability based on the temperature. But you need not worry about properly plated zinc of any type "chipping off".
I don't think I agree with you, Mandar. If this is, as it sounds, an application where the coating is subjected to the possibility of "chipping off", it sounds like there may be a good possibility of scratches. And if scratches sound likely, what better way to protect a steel component than coat it with zinc?
Ted Mooney, Teds signature
Pine Beach, New Jersey
Ted, my concern is more of corrosion in high (80 to 100%) humidity plus polluted air in India rather than wear or chipping. On top of that, scratches could make it worse. And again, with 250 to 30° C cyclic mode, no use of chromate either. Maybe galvanizing will be better compared to plating. To me, chrome or nickel plating sounds better for a three year life.
Mandar Sunthankar
Mandar, I understand your reasoning and don't disagree with it to a point. Nickel-chromium is a barrier layer plating and ideal as long as the application is such that it won't get scratched through; once scratched through, it is useless. Zinc is a sacrificial plating that does indeed corrode, and perhaps pretty rapidly; but it protects the substrate even if compromised all the way to the point where steel is exposed.
Ted Mooney,
Teds signature
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018, Inc., Pine Beach, NJ   -   About   -  Privacy Policy
How Google uses data when you visit this site.
