A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 3091
Adhesive Use on Conversion Coated Aluminum Surfaces
(1999)
The Handbook of Aluminum and Aluminum Alloys states that, "Because of their low strength, conversion coatings should not be used on surfaces to which adhesives will be applied". Is there any information that supports or contradicts this statement? We have gone through extensive testing of 3M TS-230 Hot Melt on an Alodined aluminum surface and have seen no problems. I would like to be able to proceed based on our testing, but I don't want to violate proven industry practices. Is bonding to Alodined aluminum acceptable?
Jeff Groce
- Dallas,Texas
(1999)
Adhesive Bonding of Aluminum Alloys
from Abe Books
At one of the companies I worked for, we applied an adhesive primer to a chem-filmed, (chromated) 1100 alloy 5 mil thick aluminum foil surface. We qualified the foils by lap shear testing at cold, ambient and elevated temperatures. The results were as good as FPL etched, adhesive primed lap shear coupons which were bonded as controls.
Ward Barcafer, CEF
aerospace - Wichita, Kansas
(1999)
Dear Jeff Your statement show that DO NOT BELIEVE EVERY BOOK, especially books in surface finishing. The developments and innovation in this area is so fast that from the beginning time of writing the book to the end of period there are changes . This what is making our occupation so fascinating and interesting a branch. You are doing the same as thousands of factories are doing and give step elevation to the quality of your products . Yours
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
Adhesive Bonding
from Abe Books
It sound like we're all saying, "if it works, don't try to fix it." We recently had a "think outside the box" training program in our R & D Dept., where we essentially learned not to assume that many of those "cast in stone" rules can't be broken. One thing I like about this business is that most successful finishers use very little exact "cast in stone" science and a lot of logic and common sense. Considering that there are probably a zillion types of adhesives out there with varying amounts of adhesive strength from Post- its to holding rocket parts together in outer space, making a blanket statement like the one in the handbook is naive and close-minded on the part of whoever made it. The statement may be true for some very high strength adhesives where anodize may be superior over conversion coating, but conversion coatings should work with many adhesives.
As long as your successful tests are representative of the actual real-life application of the product, then you've proven that it works, so why not go for it?
phil johnson
Phil Johnson
- Madison Heights, Michigan
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
