Bluing or blackening brass
Current question and answers:
Do you have any experience with Patinas on brass? We use a patina (blue type solution), it's patinating purple not brown. Would you know why?
Cheers Daniel
- Melbourne NSW
December 31, 2020
A. Hi Daniel. Not knowing what you are trying to patinate, what chemicals you are using for it, what method you're using (dip, spray, brush), and whether you have never succeeded before or you've been doing fine for years and this problem suddenly popped up, it hard to suggest much ...
But the purple color can be one of three things, a contaminant which produces a purple salt (and that sounds unlikely); a very thin patina which lets the Yellowish brass color enter into the equation, producing purple from yellow & blue; or a thin patina that is introducing a diffraction/interference coloration (a color which isn't really there as a pigment of any sort).
Please take your purple item and just patinate it a second time, and tell us what happens. I think it will turn brown. Good luck.
Q. I need to find a recipe for a brass blackening solution.
What I've been trying so far is:
copper nitrate [affil links] in distilled water and equal quantity of ammonia
[on
Amazon] + sodium carbonate / washing soda [affil links] to reduce the acidity.
This solution should take about 1 minute to produce rich "Gun-blue" black on brass, but it doesn't work properly. Thanks for your help.
Australian National University, Canberra, ACT-AUSTRALIA
A. There is a plating process which requires copper plating followed by blackening in a solution called Ebonal. I cannot remember the particular supplier. Good luck.
Jeff Millsmetal finishing shop - Gorham, Maine
? Have you tried Electroblack?
It's available in Australia from Macdermid.
- Australia
Q. I am trying to reproduce a blued finish on the brass boilers of a collection of antique model steam engines, most made in Nuremburg, Germany between 1870 and 1930. The finish on these engines range from purple to brown to dark blue. These can be seen at: http://John_o.myiglou.com/steammain.html
So far, commercial firearms bluing solutions have gone almost straight from brown to blue. I have heard that the old builders used a salt solution heated to the 80-90 degree (c) range to achieve this finish, but can find no documentation on this method, or the materials used. Can anyone point me to good reference material on this, or shed some light on the solutions used to achieve this finish?
John O'Rear- Versailles, Kentucky, USA
A. Lustre colours solution:
lead acetate.......25 gm
sodium thiosulphate [on
Amazon]
...240 gm
cream of tartar [on
Amazon]
....25 gm
H2O..........1 lit
/ for copper and its alloys,iron(only blue), silver, gold, platinum, nickel plate/ Solution produces a series of lustre colours in following sequence(on brass): golden yellow-orange-purple-blue-pale blue-pale grey(cca 10 min.for sequence,40 °C temp.)!
Q. I am the head of Quality Dept. co project cum customer service in my company. The line of business of the company I'm with is in Metal Surface Treatment. Currently we are doing a type of surface treatment called bluing on brass parts. And the parts and components are for microscopic surgery use. My company uses Ammonium Nitrate and copper carbonate for the bluing process.
My question is how do we strip or rework brass parts (already blue but not cosmetic accepted) or re - blue them again. Knowing the brass is a sensitive material. We have tried some test of stripping it with acids (nitric, sulfuric) but instead it oxidizes or corrodes the brass components. Have any suggestions that we can try out?
metal surface treatment - Johor Bahru, Johor, Malaysia
A. Sanding, both dry and wet is the only way I've heard to strip brass w/o oxidation. start w/ 1000 grit and work up to 1500/2000. very labor intensive.
Thomas Wheeler- Dallas, Texas
Bluing or blackening miniature cannons
Q. I would like to find out a way to black or blue miniature cannons. These cannons are part of a model ship that I am building. The cannons are made of brass, and I would like to make them look more realistic.
Oscar Allen Englishhobbyist - Lakemont, Georgia, USA
A. Pre Civil War, many cannons were made of brass as that metallurgy was fairly well known, Cast iron cannons had problems, mostly from casting problems. So, black cannons did not really come into mass production until steel was made around 1860. Parks paint theirs black, so they do not have to polish them. That said, spray paint of a desirable gloss would be the quickest and cheapest. Hold the can about 2 feet away from the cannons and do not attempt to get complete coverage at one time. think two coats on the top and two coats on the bottom side.
James Watts- Navarre, Florida
A. Black patina for brass:
200 grams copper carbonate
1 lit ammonia (25%)
Cold immersion! Very bad smelling but very effective solution!
"The Colouring, Bronzing & Patination of Metals"
by Hughes & Rowe
on
AbeBooks
I need tips on readily available solutions/gels, etc. for browning/blacking/bluing brass details please (from light brown to dark brown, black and gun blue)? Must provide reliable predictable and durable results. Or if there is a collection of well tried "recipes" available (a book, etc.) -- info on that would be most welcome? We are building fine mechanical designs.
Any help is gracefully received - thanks.
Manufacturer - Stockholm, Sweden
A. What are the parts which you are asking for?
are they too large?
are they stored in the place were their is moisture?
is Oxidation the problem?
Brownish discoloration or a bluish patina which is coming over a period of time?
I feel if it so I have the answer for that.
Please confirm my above questions first!
Cheers,
- Vasco-da-gama, Goa, India
