Advertise
Here
Search 🔍
the Site
World's #1 on-line resource since 1989
Weight of hex chromate
Many of our customers are asking for the "weight" of a hexavalent clear or yellow chromate. Is there a formula to calculate this?
Ed Farrer
- Lombard, Illinois, USA
Ed,
If you are talking about an aluminum chromate coating, then yes there is a method of checking it. I really need more specifics on the product that you are using, but for an aluminum chromate coating, take test panels and run them through the bath at 3 different times, then weigh them, strip them in a 50% Nitric/Water solution and then weigh them again. Take your difference in weight and multiply it by 8000 and that will give you the coating weight in milligrams/foot squared, the units that most customers look for.
Good Luck.
Tony Schmaltz
- Kent, Washington
Q, A, or Comment on THIS thread SEARCH for Threads about ... My Topic Not Found: Start NEW Thread
Consult'g, Train'g
About/Contact    -    Privacy Policy    -    ©1995-2021 finishing.com, Pine Beach, New Jersey, USA
