Introduction to electrocoating, CED, ED, electropainting.
Q&A's, Problems & Solutions
Electrocoating is a painting method where components are dipped into a tank containing a paint-like material (a paint 'precursor') which becomes actual paint only when electricity is applied to it, forming a thin layer of paint on the article.
    The layer of paint which forms on the article is an electrical insulator; this 'steers' the electricity away from coated areas to uncoated areas. The advantages of the method are very good & level coverage even on complicated shapes, and very thin coatings of paint not achievable by other methods. Electrocoating can be decorative and used as a final finish, but it is more often used as a primer.
    'Electropainting', 'CED', and electrophoretic' are synonyms. "CED" means cathodic electrodeposition, i.e., that the articles are negatively charged rather than positively charged for the coating process.
Acronyms:
MNC = Multinational Corporation
Q. I am working in a German MNC as supplier Quality head. we are facing issues in the coating quality specifically on the surface of the weld material used to join two parts. The area is not getting covered during CED coating.
Dinesh Pethe
supplier Quality Head - Pune
November 9, 2024
A. Hi Dinesh.
I think it's most likely that the welded area is not spotlessly clean. If you can attach pics in email to mooney@finishing.com for posting here it would probably b helpful.
Q. Anyone:
I am an estimator for a metal stamping operation in Illinois. Some of the cost I have to quote are those of plating. I understand there are several different types of finishes. I don't know what e-coating is. Can you please tell me about it, or refer to me a place/book where I can get more information about it?
Carlos G [last name deleted for privacy by Editor]
- Elk Grove Village, Illinois
SUGGESTED E-COATING, CED, E-PAINTING BOOKS
for Shops, Specifiers, & Engineers
../abwd/ced3_electrocoats2020
"Electrocoat: Formulation & Technology" by Bruggemann & Rach (2020)
ced4_electrophoretic_deposition2017
"Electrophoretic Deposition (EPD)" by Nathan Bass (2017)
ced1_electrocoating2010
"Electrocoating: a Guidebook for Finishers" by Electrocoat Association (2010)
ced5_epainting1980
"Electropainting: A survey of principles and practice" by Reginald Leslie Yeates (1980)
ced2_electropainting1970
"Handbook of Electropainting Technology" by W. Machu (1978)
A. Hi, Carlos.
E-coating is another name for electrocoating, electropainting, or electrophoretic lacquering. It is used to deposit a paint or lacquer coating (rather than metal, as is deposited by electroplating). It's more of an "application method" for paint or lacquer than a type of coating per se.
Parts are dipped into a vat of the lacquer or paint and are electrified in order to promote a reaction at the surface which deposits the paint. Depending on the chemistry, the workpiece can be anodic or cathodic, but these days it's usually cathodic, which has given the process still another common name "CED coating" (cathodic electrodeposition). It is used on very large parts, such as automobile bodies, to apply a primer coat that doesn't miss any spots, and it's also used on smaller parts such as lamps and jewelry to deposit a thin and durable lacquer (electrophoretic lacquer) as a decorative finish.
A. Yes, and no. E-coating is a process of using electricity to apply paint or lacquer, however, it is primarily used for smaller parts as a primer. I manage an e-coat facility that works parts from the size of a quarter to a rear axle on an 18 wheeler. E-coat is also a better choice over powder coat if thickness is a concern, the paint is distributed more evenly without fluctuation.
John C [last name deleted for privacy by Editor]
- Sterling Heights, Michigan
Q. I am working with two wheeler manufacturing MNC. Basically I am a mechanical engineer but I am looking after PAINT SHOP's equipment maintenance and painting jig maintenance, likely to be engaged in production in near future. So I want detail information about ACED, CED, pretreatment, etc., surface coating processes.
SANJAY PANDEY
paint shop executive - GURGAON, Haryana, INDIA
A. Dear friend, question needs to be elaborated and then answered.
Gurvin Singh
Mohali, Punjab, India
Usually available on eBay; sometimes on AbeBooks or Amazon
(affil links) mfg_online
A. Hi, Sanjay. Indeed that is very broad :-) I'd suggest starting with the Metal Finishing Guidebook -->
for an overview, and then looking into stuff more specific to CED, phosphating, etc. There are also firms & institutions who can offer you introductory courses in metal finishing.
Is e-coating paint flammable?
Q. E-coating...is the paint a flammable or combustible?
Powder coating...is the powder actually a plastic?
Chris B [last name deleted for privacy by Editor]
- Oxford, Michigan
A. E-coating is done with the parts immersed in a water-based solution. While you would need to get any relevant hazard information from the actual supplier, I've not heard of it being flammable or combustible and certainly wouldn't expect it to be.
Yes, powder coating is done with powders of thermoplastics or thermoset plastics.
Comparison of e-coating and powder coating
Q. Which process is more expensive, E-Coat or Powder Coat?
Scott L [last name deleted for privacy by Editor]
- Evanston, Illinois
A. That is a little difficult to answer, Scott, because there are different types of e-coats and powder coats, and some e-coats are intended only for use as a primer, and most powder coating requires some sort of pretreatment. But powder coating is generally far thicker than e-coating, involving the deposition of significantly more material, so it is probably reasonable to say that after discounting the capital costs, powder coating is more expensive. Perhaps a shop that offers both will confirm or refute this for us.
Q. How is monitoring of PT & CED done?
SUGGESTED PHOSPHATING BOOKS
(many of these are rare; the links will only sometimes work)
phos_sharma22
"Optimization of Phosphating Process" by Vinod Prasad Sharma (2022)
phos_rausch1991
"Phosphating of Metals" by Werner Rausch (1991)
phos_freeman1991
"Phosphating & Metal Pretreatment" by D.B. Freeman (1986)
phos_lorin1974
"Phosphating of Metals" by Guy Lorin (1974)
biestek
"Electrolytic and Chemical Conversion Coatings" by Biestek & Weber (1972)
"A Study of Manganese Phosphating Reactions" by Joseph Menke (1971)
phos_spring1966_rare
"Preparation of Metals for Painting" by Samuel Spring (1966)
"Continuous Automated Analysis and Control of phosphatizing Baths" by Edward P. Parry (1972)
Sureshkumar.N
tafe - Madurai, Tamilnadu
A. PT CED MEANS PRETREATMENT LINE & CED MEANS CATHODE ELECTRODE DEPOSITION LINE IN PAINT SHOP.
Ramakant Kumbhar
var - Aurangabad, India
September 3, 2010
A. Hi Sureshkumar
All questions are welcome, but some can't be answered in the paragraph or two of a public forum. You would need to read an extensive article on PT such as phosphatizing and another one on CED (if not whole books on the subject) because, although they are easier questions than "how is an airline built", they are still multi-faceted and complex questions requiring many pages of exposition.
Q. Which one is better, e-coating or powder coating? Do they perform the same aside from powder coating being thicker? What are the advantages and disadvantages?
Leonardo Antonio
- Winnipeg, MB, Canada
January 14, 2008
A. Hi Leonardo. We've mentioned some general advantages of e-coating -- complete coverage and very thin coatings being the principal ones. Higher capital cost for e-coating and generally not as decorative are disadvantages. But "better" is only meaningful in terms of compliance with a detailed list of desired properties. If you tell us what application you have in mind and in detail, people will be able to list advantages/disadvantages for that situation/ circumstance, and help you make an informed choice between the two, or whether to use the two coatings sequentially, which is also often done.
thumbs up sign Attempting to suggest which is "better", independent of the actual situation, is misleading ... it's a bit like trying to explain the advantages & disadvantages of travel by ship vs. by rail before you've told us whether the planned trip from Los Angeles is to Las Vegas, or to Hawaii.
Q. Hello everybody! What is the best method for treatment of a new replacement vehicle frame for a 59 Chevy. E-coating, powder coating - or a combination? What would You suggest? Thank You! Al
Alfons Wolff
- Haimhausen, Bavaria, Germany
February 14, 2008
A. Hello Alfons. Powder coating will not be able to cover all areas of the frame, whereas e-coating will -- and it is done by all OEMs. But both in sequence would actually be best. Good luck.
! Mine is not a question but a comment about powder coating. I run a small job shop specialty coating service and use a Gema gun. The commercial guns have KV's ranging from 10-100 with the normal application amp set at 45 for powder attraction. I use a batch method with carts to handle large parts and racks for small parts. I think the application thickness would depend on the application KV's applied to the part for powder attraction, don't you?
Say for instance a tank holding 50 lbs of powder using an air mix and low KV's, I think with air blowing the powder around the tank as the parts passed through would flock the powder very proportionally and with low KV's the thickness could be adjusted.
Permits for E-coat and chemicals are very costly and a start up operation could start around $ 500,000.00 so I am told by suppliers.
Jimmy Cherry
owner of coating shop - Washington, North Carolina
A. Hi Jimmy. Yes, there are clearly advantages to powder coating over e-coating, usually including lower capital cost as you mentioned, and also thicker coatings, the versatility to easily go from one color to another, and one type to another, apply multiple coats, etc.
But although you can vary the thickness of powder coating, no matter how thinly you apply it, you can't get it to melt and flow and cover at anything approaching the thinness and consistency of a e-coating with no missed spots in crimped areas, under spot welds, etc. 1 to 2 mils would be a common powder coating thickness and might still miss spots due to Faraday cage effects, whereas 2 tenths of a mil would be a common e-coating thickness and there would be no missed spots. Again, neither is "better" until we know what the application is. And I personally think they comprise an excellent relay team, with an epoxy e-coat under a powder coating topcoat.
Advantages of electrodeposition over conventional powder coating
Q. We are in the business of light manufacturing for the shipping industries. Currently enclosures are coated with Epoxy (conventional powder coating). May I look for any alternative method to this electrodeposition (Typical Process offered by PPG- UK)? Are there any advantages or disadvantages? Are these two comparable with each on the performance?
Ramachandra Bhat
Manufacturer-Lights - Mumbai, Maharastra, India
December 22, 2008
A. Hi, Ramachandra. Electrocoating can compete against powder coating, but it is often a complimentary process to powder coating rather than a competitive process. Electrocoating has the advantage of full coverage of the tiniest recesses and it is very thin. So electrocoating will often be a "prime coat" before powder coating. To the limit of my knowledge all automotive bodies are electrocoat primed.
A. Ramachandra: Have you come across repeated cases where customers have complained of powder coating peeling off? If this has happened, then Electrocoating will go a long way in improving the quality. The epoxy primer coat gives the corrosion protection while a top coat of PU or PP powder coating will provide UV protection.
Gurvin Singh
A. Although Ted is correct in that it is a complementary process to PC you have to be very careful that any recesses do not retain air. As EC is partially a dipping process with electrics... deep wells, unless facing up at an angle, will result in areas of no coating as the entrapped air will prevent this.
Terry Hickling
Birmingham, United Kingdom
A. Thank you, Terry.
We can also note that, excellent as electrocoating is for good thickness distribution, it's doesn't do miracles -- people have observed lack of coating deep inside the hollow tubing of automobile frames.
Q. Hi, I am purchasing a bumper for my Jeep Wrangler and I see most manufacturers use powdercoating and a few use the e-coating? Can you tell me which would be more durable and which would be more resistant to rust? Thank you.
Jerry Megs
- Nassau, New York
April 24, 2012
Bumpers for Wranglers
on eBay or Amazon
A. Hi, Jerry.
Regrettably, a manufacturer's sales spiel almost never reveals anything important about the finish because it is not intended to educate you, but to induce you to buy. But my guess is that you're actually looking at two different types of product --
I think that if a bumper is only electrocoated, the intention is for it to be repainted by the buyer, with the electrocoating intended as only a primer. If it's powder coated, it probably has its final intended finish on it.
To the extent possible, please investigate customer satisfaction with the various brands and make your decision based on that.
E-coating vs. powder coating vs. both in sequence
Q. My company currently powder coats the components of the bike racks it manufactures. These bike racks go on the back of vehicles. Is E-Coat a replacement for powder coating. Is it as durable as a powder coat finish for exterior applications.
What are the advantages and disadvantages of E-Coat vs. Powder Coat.
Richard Noddin
manufacturer - Alna, Maine
February 3, 2010
A. Hi, Richard. The vehicles you mention would be first e-coated, then powder coated or wet spray painted. Obviously, the vehicle manufacturers do not think of e-coating as a replacement technology, but as a supplementary technology.
If your bike racks have tight interior corners or a bit of weld splatter, etc., e-coating can get you complete coverage whereas powder will not. But powder is thicker and probably more corrosion resistant and attractive. I think the powder coating is more durable. To do it best, apply e-coat and powder coat in sequence.
Step by step e-coating process with pictures
Q. I want to know the process flow & the entire time for the process completion?. Time for each process & what happens after the completion of each process. I will be happy if you explain me with pictures.
Sandeep [last name deleted for privacy by Editor]
- Chennai, Tamilnadu & India
A. Hello, Sandeep. This public forum is a good place to ask for a quick one-paragraph introduction to a technology you are unfamiliar with, and it's also a good place for answers to a highly specific question. But as you get into wanting detailed sequences for processes, with pictures, theories, etc., your needs will probably have to be met by books on the subject. We've suggested on this page the e-coating books that we are aware of.
But maybe one of the vendors of the process has a free brochure or CD that will help you. Good luck.
E-coating of silencers
Q. Can e-coating process be carried out on the outer surfaces of silencers. What are the characteristics of e-coating. Is it corrosion resistant?
Srikanth m.r
production supervisor - Bangalore, Karnataka, India
A. Hi, Srikanth. Here in America, a "silencer" is a device fitted on the barrel of a pistol to reduce the noise, and yes they can be e-coated. But I think what you call a "silencer" is what we call a "muffler" -- a device to reduce exhaust noise on motorcycles and automobiles?
As mentioned, the coating is thin but it is corrosion resistant. The biggest question I would immediately have would concern the operational and maximum temperature of the application. For high temperatures you usually need metals or ceramics rather than paint or organic coatings. Good luck.
Q. What type of e-coating should I request so that I can spray epoxy primer over top of it with no adhesion or reaction problems?
Shawn G Lavene
- Dayton, Ohio
October 12, 2008
Q. I'm working on a stamping part for Caterpillar. They ask E-coating with 600 hours salt spray test.
Which kind of E-coating do I need to use?
Frank Wang
die & mold making - Shanghai, China
August 17, 2009
Metallic colors and e-coating
Q. We have been e-coating a small magnesium (AZ-91D) part in a black e-coat with minor issues (some occasional small chipping).
I am now proposing a larger part (AZ-91D front housing for a handheld computer with scanner) that would be e-coated in a metallic finish.
Are the metallic finishes as/more/less durable than the solid coats and is there a secondary process that improves durability without sacrificing wall consistency?
Bob Bruffey
- Norcross, Georgia
April 12, 2010
A. Hi, Bob. The metallic colors to my knowledge are just post-treat dyes. Although I suppose it would be possible to do an aluminum vacuum metallizing before the e-coat, I haven't seen it. Finishing.com just completed a major study of corrosion resistant coatings for zinc die-castings for the International Zinc Association, and we found the metallic colors about equal to the solid colors in corrosion resistance. Polyurethane top-coating does significantly improve the corrosion resistance, but it adds significant thickness.
I have a product which is polyurethane E-coated.
It is clear and it will give good exterior resistance.
One thing I want to discuss: solid coats are more powerful than the metal coat because of their physical structure? Or the solid coat arranges in plate-like structure so it helps to inhibit the corrosion.
chandresh varsani
- Rajkot, Gujarat, India
December 2, 2010
A. Hi Chandresh. As mentioned immediately above, finishing.com's testing for IZA did not show evidence of your hypothesis leaning either way, although I can't rule them out since the amount of data we collected on that particular subset is scant, and really only had to do with metallic appearance, not actual metal particles. I am not familiar with e-coats containing metal particles.
E-coating of molds
Q. Hi.
I want to know about the material used and process used in E coating, I want to do this coating on molds which are used to produce ABS plastic products which are injected at very high temperature about 150-200 °C, which would be better option for non-sticky coating.
Thanks in advance.
DEV SHARMA
- New Delhi, India
August 17, 2011
A. Hi, Dev.
Sorry, I've never heard of using e-coating on molds. I've only heard of using chrome, electroless nickel, and other hard metal or ceramic coatings, not paint. It's not that I claim to have heard of everything, just that I can't help.
Q. I am considering a process where I e-coat a cast iron ring then mold rubber to the ID..
My question is if the e-coated ring is exposed to a 150 °C/300 second heat cycle (rubber molding cycle) will it damage the performance of the e-coat??
Thanks for your help in advance..
Dave Ford
- canton, Michigan
October 5, 2011
Low curing temperature e-coating?
Q. Hi. I work for product development at Ford. We were asked to "glue" a stamped steel bracket to a piece of aluminum and then E-Coat it. I need to know what the highest temperatures these parts go through so I can find a suitable epoxy to use. Can you answer this question?
Tracey Mills
- Dearborn, Michigan, USA
March 26, 2012
A. Hi Tracey.
To my limited knowledge the e-coat tank itself operates at about ambient temperature. But curing is usually required. The normal temperature for this is about 375° F, but there are low-temperature curing paints available that can be cured at 180 °F. It is also my understanding that there are UV curable e-coats.
thumbs up signThank you, that'll help tremendously!
Tracey Mills [returning]
Are plastic auto bumpers e-coated?
Q. I have a question in regards to e-coating and how it relates to automotive body repair and refinish of plastic parts. It's recently been suggested to me that if the e-coat on a plastic painted component (such as moldings, bumpers, finish panels, etc.) has been disrupted by collision damage or as a result of repairs, subsequent sanding, priming and refinish will be rendered null and void as the base coat will merely blister and peel as a result of the damage to the e-coat. This would essentially require part replacement. Can you provide thoughts on this?
Wayne Hunt
- Greensboro, North Carolina
March 30, 2012
A. Hi, Wayne.
That one is probably better directed to auto body shops, who will be much more familiar and knowledgeable than we are with what is required to effect a robust repair. But I do note that I've never heard of e-coating being applied to a plastic component because it is an electrolytic process that can only be performed on a conductive surface, so the story sounds fishy to me.
Q. What factors affect the choice of an e-coating for gray iron pipe fittings?
morris_key
Morris Key
Chemical consulting - Van Alstyne, Texas, US
August 13, 2012
Q. This question is related to aluminum die cast parts that are used on fencing, primarily the die cast components are decorative (finials and post caps ) the biggest problem is the industry typically powder coats the parts, yet within the year we see several parts peeling and corroding. Clients are now requesting to have the parts e-coated and then powder coated. My question is will we see an improvement or is this just a problem due to adhesion.
Your help would be extremely helpful.
Henry Mercieca
- Richmond Hill, Ontario, Canada
October 24, 2012
A. Hi Henry. While each extra layer of a coating has the potential to reduce corrosion, lack of e-coating is probably not the key issue here. Although it's not possible to do a failure analysis based on such limited verbal information, my bet is that the aluminum components used to be properly chromate conversion coated and no longer are chromated.
Step 1 is to find out if the parts are still chromate conversion coated, and to fix it if they're not.
opinion!   It is unfortunately common these days for inexperienced government regulators and wet-behind-the-ears environmental engineers in swivel chairs to steer industry toward implementing well-intentioned but foolish & wasteful substitutes for time-proven finishes in the erroneous belief that we "help the environment" by saving an ounce of chromate ... while consequently sending a ton of fabricated product to the junkyard. It's an environmental travesty and an assault on sustainability for manufacturers to supply products that last 2 or 3 years when we've known for decades how to easily & inexpensively make them last 15 years and a lot more.
"No good decision was ever made from a swivel chair" -- General George S. Patton.
A. I suspect the chromate was too heavy, in which case the powder coat will peel off. Under powdercoat (or any organic finish) the chromate must be very thin, slightly iridescent, not bright gold.
robert probert
probertbanner
Q. What pH should be maintained in the 7 tank process for rinse water?
What is ED process?
What should be recommended DFT of ED paint?
Praveen Khairnar
- Pune, Maharastra, India
January 30, 2013
A. Hi Praveen. In my opinion rinse tanks are for rinsing, they are not process tanks. Therefore, you should not add anything to them to control pH but should merely run an optimal amount of water through them, i.e., enough to guarantee quality without wasting water. Anything you add constitutes something that you are not rinsing off.
It is risky to take a tiny 2-letter acronym like ED and try to insist on what it means -- most of the world thinks it means 'erectile dysfunction' :-)
But in this context it presumably means "electrodeposition", and it additionally probably implies electrodeposition of paint rather than electrodeposition of metal (electroplating). Thus ED probably probably means the same thing as e-coating, electrocoating, electropainting, electrophoretic lacquering, etc.
Typical e-coating thicknesses are probably a couple to a few ten-thousandths of an inch. Good luck.
Can steel and aluminum parts be processed on the same ED line?
Q. I have an ED coating plant for General Motor India. One metro train manufacturing wants to make ED coating and PT on aluminum cast parts. Is it possible to use steel ED coating line for aluminium cast parts? Or what do I need to put in additional in same line.
Pravin Chaudhary
Development manager - Baroda, Gujarat, India
March 24, 2013
A. Yes, you can process Aluminium parts in the same line. You have to be careful with the degreasing and phosphating baths. They will require additional controls.
Gurvin Singh
Q. What is the cost difference between Powder Coating & CED (E-coating)? What is the running cost for CED process (Rs/Sq ft)?
Vijay Sharma
- Jaipur
August 15, 2013
Q. I want to achieve C5-M corrosion protection as per ISO 12944-5 which could last long, i.e., more than 20 years. How much coating thickness should it have with CED coating on mild steel? What are the tests which should be specified?
Ashvin Ambaliya
- Pune, Maharashtra, India
December 5, 2013
A. Hi Ashvin. I doubt that e-coating without an additional layer of powder coating will survive 20 years of outdoor exposure, but there is unfortunately no good way to prove or disprove it in a short time. And, of course, you also have to make the assumption that the coating will not be scratched in 20 years of service.
Although it is possible to somewhat adjust the thickness of CED coatings, they are insulating, which inherently slows down the process at a rather low thickness (maybe 35 microns or so). I think CED coating is an ideal BASE for a 20-year coating system, but not an ideal topmost layer.
Q. Hi. Great forum.
We import aluminum components from a source in China. Most have chrome/nickel plating, but some have a new e-coating. Can an e-coating be expected to have the same adhesion strength as the metal coatings? What are some possible causes of blistering/peeling of the e-coat?
Bob Kasberger
- Sheboygan Falls, Wisconsin
September 12, 2014
A. Hi Bob. E-coating is paint, not metal. It is soft and certainly does not have the adhesion, hardness, or scratch resistance of metal. Poor pretreatment is the cause of most adhesion issues, i.e., the aluminum was probably not properly cleaned and chromated before e-coating.
