A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 950
Cleaning TUNGSTEN-CARBIDE before Electroless Nickel plating
An ongoing discussion from 1997 through 2015 . . .
(1997)
What chemical cleaning methods could be used to clean tungsten-carbide for an electroless nickel deposit?
Chip Zacchino
(1997)
A. I cannot recommend the proper process for cleaning tungsten carbide, but I can offer one caution. That is to be very cautious with electrolytic alkaline cleaning with this material. If not properly controlled electrolytic alkaline cleaning can cause selective attack of the cobalt binder, leaving a porous layer of carbide particles at the cleaned surface.
larry hanke
Larry Hanke
materials testing laboratory
Minneapolis, Minnesota
(1997)
A. Have you tried wet abrasive blasting to clean before plating. This gives you an excellent surface key which provides a uniform plating effect without using environmentally harmful chemicals. Please let me know if you would like further info.
Steve Eyton-Jones
abrasive developments - Berkshire, U.K.
sidebar (1997)
? What 'environmentally harmful' chemicals are you alluding to, Steve?
Ted Mooney, finishing.com Teds signature
finishing.com
Pine Beach, New Jersey
(1998) A. Re: alkaline electrocleaning
We use alkaline electrocleaning for tungsten carbide and have patented the process 1. We use it very successfully for preparing the surface for brazing. Part of our testing was to use electroless plating techniques to assess surface condition. We typically see a surface effect to about nine microns.
tom walz
- Carbide Processors
Ed. note: In response to our inquiry, Mr. Walz supplied the following info about the patent:
1 --Patent Number 5,624,626
Date of Patent Apr. 2---
Walz et al.
METHOD OF TREATING A CERAMIC BODY TO FORM A WETTABLE SURFACE
(1998)
Q. How can I do the electroless nickel plating on the PR!
How to clean the PR and let it be hydrophilic? Please help me!
Thanks very much!
*^_^*
Ping-Ching Sun
- Soochow University - Taiwan
Ed. note: We don't know what 'PR' stands for in this context; I hope some other reader does.
(1999)
Q. What detergents/cleaners are used that cleans the tungsten carbide surface without leaching the cobalt binder. If anyone knows a company that has a cleaning product out that is specifically formulated for cleaning carbide substrates, I would be most thankful to hear about them. Thanks in Advance, Mark
Mark Eastep
(2001)
A. Cleaning carbides is precarious situation. Cobalt leaching is typically caused by an acid attacking the cobalt binder, or a reverse electrolytic process removing the cobalt (again leaching). I have worked with 3 PVD coating companies and the only process I have found that has worked is an ultra-sonic cleaning in an alkaline solution, rinsed in deionized water, and hot air dried immediately after rinsing. I have seen ultra-sonic in trichlorethylene used but you have to make sure the pH is not acidic.
Lou Lechner
- West Chicago, Illinois, USA
Electroless nickel on tungsten titanium (adhesion problem)
(2002)
Q. Dear all,
We are recently given a silicon wafer onto which a tungsten/titanium coating had been sputtered with a request that it be electroless nickel plated. The W/Ti has 10% Ti composition. I am able to plate Ni on W/Ti. But the adhesion is a big problem. The plated Ni can be easily peeled off. If anyone of you have experience plating Ni on W/Ti, please give me some suggestions how I can improve the adhesion. I would be grateful for any thoughts you may have.
Many thanks,
Bin Zou
- Colorado Springs, Colorado
(2002)
A. See Durney's Electroplating Engineering Handbook for plating cycles for tungsten.
pooky
tom pullizi signature
A. It is a common practice to deposit a very thin layer of Ti for adhesion followed by W as a barrier layer and then Ni for solderability as three separate layers in electronic circuits. This is all done typically using sputtering. Are you sure it is a W-Ti alloy and not pure W on the surface?
Mandar Sunthankar
- Fort Collins, Colorado
May 24, 2011
Q. Hello guys, it seems like I am encountering related situation.
I am figuring why are there delayed-stains after post treatment washing of my tungsten alloy after nickel plating. These delayed stains takes a few days to appear. Are these stains related to the cobalt leaching? or other reason.
These stains can be taken out by rubbing blue-tach on the parts.
Please help me. Thank you
Kenneth Choo
To minimize searching and offer multiple viewpoints, we've combined multiple threads into the dialog you're viewing. Please forgive any resultant repetition or failures of chronological order.
How to electroless plate Ni onto Tungsten
June 3, 2015
I am new to this forum and this is my first post.
I'm trying to electroless plate nickel on Tungsten but there doesn't appear to be too much literature on how to do this. Specifically, I am having a hard time locating a procedure for activating the Tungsten surface without the use of current. This is important - no current.
Electroless Plating
Mallory & Hajdu
Does such a process exist?
I found a procedure in the "Electroless Plating -- Fundamentals and Applications (1990)" book as follows =>
1. Alkaline potassium ferrocyanide soak, 215 g/L in 75 g/L potassium hydroxide, room temperature, for one min.
2. Rinse.
3. Boil in 10 percent potassium hydroxide for 10 min.
4. Rinse.
5. Dip in 10 percent hydrochloric acid for 30 sec.
6. Rinse.
7. Activate with palladium chloride (0.1-0.5 g/L in 1-3 mL/L hydrochloric acid).*
8. Rinse.
9. Electroless nickel plate.
The problem with this process is it uses palladium and I cannot afford palladium since I'm just working out of my parents' garage. Basically...how can I activate the surface of Tungsten for electroless Ni plating without current or the use of expensive chemicals?
Thanks - I apologize if these conditions seem ridiculous or unfeasible. I'm still new at this and learning.
Glenn Dukat
Hobbyist - Los Angeles, California USA
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
