A website for Serious Education, promoting Aloha,
& the most FUN smiley you can have in metal finishing
HomeFAQsSuggested
Wanteds
Advertise
on this site
FORUM
current topics
topic 853
Type 416 stainless steel shafts are rusting
(1998)
We are facing a very serious problem. We are using Carpenter Steels Grade T 416 Stainless Steel at our India Plant. We have finished screw machining of 3" long shafts and have done centerless grinding on them. After that we did the following for cleaning them :
1. Cleaned in Mild Soap Solution
2. Ultrasonic Cleaned in solution of soap , IPA (Isopropyl Alcohol), and Water
3. Water Rinsed
4. Water Rinsed
5. IPA Dip again
6. Hot Air Drying
After some time we found rust spotting on the parts. Now did we go anywhere wrong and did we not follow the correct procedure. What kind of passivation should we do here, and what is the concentration of the passivating solution to be used. The material here is SS 416 Grade T (tempered).
Sanjeev Malhotra
(1997)
Dear Sir:
We do not see any reference to the method of passivation in your letter. The procedure you described will remove moisture temporarily, but will not provide any corrosion resistance.
There are a number of methods commonly used for passivation. The latest specification we have seen is ASTM A967 [link by ed. to spec at TechStreet] .
For 400-series alloys, we would recommend electropolishing as the preferred method. In India, we would suggest that you contact Mr. Kumar Shah of Progressive Chemical Co., 28-29 Agrawal Industrial Estate, Bombay, India, 400068. Mr. Shah produces electropolishing chemicals under license and should be able to prescribe a local product for your application.
Ed Bayha
Metal Coating Process Corporation - Charlotte, North Carolina
(1998)
YOU CAN USE NATURAL LEMON OR NITRIC ACID OR citric acid [linked by editor to product info at Amazon] FOR REMOVAL OF RUST
RAFAEL BECERRIL
This public forum has 60,000 threads. If you have a question in mind which seems off topic to this thread, you might prefer to Search the Site
ADD a Q or A to THIS thread START a NEW THREADView CURRENT TOPICS
Disclaimer: It's not possible to diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations may be deliberately harmful.
  If you need a product/service, please check these Directories:
JobshopsCapital Equip. & Install'nChemicals & Consumables Consult'g, Train'g, SoftwareEnvironmental ComplianceTesting Svcs. & Devices
©1995-2018 finishing.com, Inc., Pine Beach, NJ   -   About finishing.com   -  Privacy Policy
How Google uses data when you visit this site.
