Conversion coatings on aluminum
1997
Where do I find information about conversion coatings on aluminum. I want to replace the native oxide with a surface alloy or something else that is a better electronic conductor than the initial surface oxide so that I can electroplate onto aluminum foil
Any suggestions ?
Robert A. Huggins Chr. Albrechts University, Kiel, GermanyConductivity may not exactly be the question: it's possible to phosphoric acid anodize and then electroplate.
But the most conventional way of plating onto aluminum is to do a 'zincate' pretreatment, which consists of immersing the article in a highly caustic zinc-rich solution, stripping in nitric acid, and repeating. Look up 'zincate' in the guidebooks for further detail or inquire of Atotech regarding their proprietary alternative 'Alstan', or Canning-Gumm Chemical [now Macdermid] for their proprietary alternative 'Bondal'.
1997
1997
Chemicals solutions to produce chromate conversion coatings on aluminum are sold by a number of companies worldwide. One of these manufacturers is probably your best source for technical information. The US Dept. of Defense maintains a long list of products approved to meet the military specification (QPL-81706 [on DLA]). Two of the most widely recognized are Alodine(R) by Parker Amchem [now Henkel] and Iridite(R) by Macdermid. In fact, these brand names are often used generically when referring to chemical conversion coatings.
Chris Jurey, Past-President IHAALuke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
Conversion coating on aluminum and plating on aluminum are two different things. Ted recommended a process for plating and Chris for conversion. They do not go together, if you apply a chromate film you cannot plate on it only paint it.
Sara Michaeli
Tel-Aviv-Yafo, Israel
1997
