-----Making quick setting epoxy to fix spalled wood
Q. I am currently using a couple of brands of quick set epoxy glue
Amazon [affil link] in some woodworking that I do. I work with partially rotten (spalled) wood to make small, thin walled boxes. Since the wood is soft I strengthen it with epoxy. To do this I take equal amounts of the resin and hardener and dilute them 5 to 1 with acetone
[affil link] Flammable!
. I then take equal portions of the diluted mixtures, mix them together and apply that to the wood. The acetone allows the epoxy to be absorbed into the spalled wood rapidly and into the sound wood more slowly. This process can be repeated several times to get a harder but yet flexible piece of wood. The final finish is also attractive -- it looks similar to a lacquer. This procedure also allows for a final sanding that does not clog sandpaper. All in all a very good technique.
The epoxies that I can purchase locally is very expensive. I need a supplier of larger amounts of the quick set epoxy or maybe this is not original with me and someone sells quarts or gallons of product that does this. Any help would be appreciated.
NCDA
1996
A. You might try calling on some of the larger finishing suppliers like Lilly Ind. or Sherwin Williams. They should be able to help you or tell you where you can get it.
Michael McColleyfreeport finishing
1997
A. Hi Dwight. Boating stores offer an epoxy I've used to fix rotten wood on boats. I believe it was filled with fumed silica to make it lighter. But I like your idea of diluting it with acetone ⇦ on eBay or Amazon [affil link] Flammable! in hopes of preferentially filling the rotted part of the wood.
