-----:Questions about zinc electroplating specification Fe/Zn8
Many questions on this page ask about "Specs" like "MFZnxx", etc. But those are not specifications -- they are codes within an unidentified specification. Trying to determine the meaning of a code without knowing what spec it is found within is like asking the meaning of 'Type 3' or 'Class 1' without naming the spec. :-(
For one quick example of this problem, consider that the meaning of the "8" in code MFZn8 in certain specs is "8 microns thickness". But the meaning of "2" in code MFZn2 in other specs is most certainly not 2 microns thickness (it also likely means 8 microns). You must name the specification number or at least the OEM before such codes mean anything.
Q. When ASTM B633 specifies SC2 (Fe/Zn8) does this mean a minimum or an exact? Can the supplier send us material with a range of 8-12 microns with the 9-12 microns having a deposit build up which interferes with the functionality of our part?
Janice Tessier- Sealy, Texas
for Shops, Specifiers & Engineers
from eBay, AbeBooks, or Amazon
"Alkaline non-cyanide zinc plating with reuse of recovered chemicals" by Jacqueline M. Peden (1994)
from (U.S. EPA)
from eBay, or AbeBooks
A. To the best of my knowledge, the thickness is the minimum. It would be very difficult to obtain a certain thickness exactly, for example 8 microns. We need to have a range on the thickness.
You could specify also a maximum thickness, and work with your supplier to see if it is possible to work on this range.
I hope this helps.
Enrique Segovia- Monterrey, Mexico
A. Hello Janice,
Is the product that you are having a problem with a fastener? The spec. Fe/Zn 8 calls out a minimum specification (0.00031") for zinc on steel, I believe. However, a standard 2A/2B thread fit only has an allowance for finishing of 0.00025". If the plater is trying to meet the intent of the specification which you have called out, and the fastener is relatively long, it is very possible that there will be enough zinc on the starter thread to cause a thread interference. The same issue can occur on a stamping with a threaded hole.
Hope that this helps.
Best regards,
Brian A. Calver, CEF- Grimsby, Ontario, Canada
A. You could specify the maximum thickness allowed for Fe/Zn 12 classification.
Thiagaraj MaruthiEngineer in conveyor manufacturing - Kluang, Johor, Malaysia
March 31, 2010
A. Hi Janice.
All of these responses are good and answer your stated question. But as a practical matter, I'm not sure if it was totally clear from them that plating thickness, especially on fasteners, will vary quite widely across different places on the part.
In short, if you specify 8 microns minimum, you are virtually sure to get at least 12 or 13 microns in some areas. Commonly a spec will read something like "x microns minimum on any spot which can be touched by a 3/4 inch diameter ball, and no bare spots".
Zn6 with passivate bi-chromatic
Q. We have had a request regarding ZN 6 Passivate Blue. What does the 6 mean?
Why Blue over gold or clear?
Also what is passivate bi-chromatic?
Are there any links to good websites describing the finishes and passivation process?
Product Design - Christchurch, New Zealand
A. David,
ZN6 passivate blue is zinc plating with blue passivation using hexavalent chrome.
Now since hexavalent chrome is being phased out, blue passivation with trivalent chrome process is commercially available which is superior to dichromate type hexavalent chromium process. The neutral salt spay life before white rust as well as the finish is better than the latter.
However, yellow iridescent passivation (what you are referring to as "gold") has better corrosion resistance than blue passivation ("clear.")
- Mumbai, India
A. Zn6 is 6 microns of zinc.
John Martin- Wales
! I have read your question and read the answers. I must admit both could be correct. I think you need to go back to your customer and ask him exactly what he wants. It is a problem in the plating game when a customer gives a "spec" like that (internal spec) that is not clearly understood by the plater.
Gary Joseph
Johannesburg,
South Africa
Absolutely, Gary!
The whole concept of Quality becomes a joke if there is confusion between the customer and supplier over what is being asked for.
Q. We are quoting a electroplate spec and want to better understand the "breakdown" of the spec. Ep-Fe/Zn8/CM2.
Kim HewittMetal Stamper - Fraser Michigan
A. Ep : electroplate
Fe : substrate to be plated
Zn : kind of plating
8 : thickness (8 mic)
CM1 : blue chromate
CM2 : yellow chromate
- Bekasi, West Java, Indonesia
May 11, 2009
A. Hi Kim. Hopefully Joko's reply answered your question satisfactorily. But I would warn that different plating specs include similar codes like Fe, Zn8, and CM2, while also having additional requirements about testing, lot size, etc. So you should be careful to call it out as "ASTM spec. no xxxx type Fe/Zn8/CM2" or "ISO spec. xxxx type Fe/Zn8/CM2" or "Nissan spec. xxxx type Fe/Zn8/CM2" or whatever is the case :-)
What is Fe/Zn 5 c 2C F-010
Q. I have a customer drawing that states on the finishing field the following:
ZINC PLATE Fe/Zn 5 c 2C F-010.
As far as I know this is a Zinc Plating over steel, 5 microns, chromate; however I don't know what the rest of the spec. means "2C F-010".
Could somebody help me with this?
Plexus Electronic Assembly - El Paso, Texas
A. Can't you go back to your customer and ask what body issued the standard?
It has the look of a European standard but is not written in the manner which the relevant standard, BS EN12329 demands. [ed. note: that spec has been superceded by BSEN ISO2081]
- Wales
A. That is part of ASTM F1941
FE/ZN = Zinc, 5 = .0002" Min thick, C = Yellow
- Wheeling, Illinois, USA
June 1, 2012
Q. According to my customer's drawing, it requires surface treatment: Fe/Zn 8 C5. I don't know what "Fe/Zn 8 C5" means. Please inform me if somebody knows, thanks.
Claire Hsiehexporter of fasteners - Taipei, Taiwan
March 25, 2008
A. Fe/zn 8 c5 :
means zinc coated iron with 8 micron thickness
- TEHRAN, IRAN
Spec: Ep-Fe/Zn 8B free from Hexavalent Chromium (White)
Q. I have a print with this plate spec, and just want to make sure that I understand it correctly. As far as I know it is a .00031 min plate thickness, ROHS.
Is there a specific salt spray for this?
Any words of advise would be appreciated.
plate shop internal - Wyandotte, Michigan, USA
May 20, 2009
A. Hi Amy,
Yes the thickness is 0.00031 inch. This spec means white rust should not appear in 48H, and red rust in 96H more (total 144H).
A. We follow the detail FEZN8B.
Components require salt spray life up to 240 hours as per drawing of Honda components.
metal finisher - Gurgaon, Haryana, India
Hi Amy,
That is not a spec, it is a code within an unspecified specification number.
Joko and A.S.'s contradictory answers should serve as a warning not to proceed without knowing what spec number you are supposed to be following :-)
What is EP-FE/ZN10 BK Plating?
We have a customer from Japan that requires plating I have never heard. They are specifying Ep-Fe/Zn10 bk. I have contacted our plating shop and they have never heard of this type. It seems it is Zinc plating 10 microns thick, but what does the bk stand for? Please help.
OEM supplier - Hutto, Texas
July 27, 2009
A. bk = black
GR Johnson- Taiwan
November 2, 2022
Q. What is the meaning in the electrolytic coating spec "Fe/Zn8/F1" Pc:black passivation Cr+3 Fe/Zn8/F1 - FTR 00025 for an electrolytic coating of zinc on steel, with a minimal thickness of 8µ, is having a black layer of Chrome III passivation? ⇦ Answer?
Ozgur Usluerplating shop employee - Izmir, Turkiye
October 13, 2009
What type of plating is Ep-Fe/Zn 5/HB, CM2 C?
Q. We are quoting a job that has this requirement. ⇦ Answer?
Renee RiderQuality Manager - Columbus, Ohio, USA
April 12, 2011
What does "TLP" mean in spec Fe/Zn8/TLP?
Q. What is the TLP meaning in the electroplate spec Fe/Zn8/TLP
- Johor Bahru, Johor, Malaysia
June 24, 2012
A. Hi. Google tells me that TLP stands for 'thick layer passivated'.
SK Cheah- Penang, Malaysia
Q. What is HB in 'Ep-Fe/Zn[2]/HB CM2'?
Yan Biau Chow- Singapore
July 2, 2012
A. Hi.
HB indicates a post treatment of Baking for Hydrogen removal.
- Penang/Malaysia
Q. What about CM(iii)3? ⇦ Answer?
TF NG- Seremban, NS, Malaysia
April 16, 2013
Q. What does EP-Fe/Zn-Ni8/CM2C mean? Could you help me to understand this specification? ⇦ Answer?
Armando Diaz- Metepec, Mexico
I remain a bit shocked by this thread, cousins. The specs say what their codes mean. Are people actually plating then issuing certs based on internet rumors?
Bone joor 🙂
Q. We have some steel fasteners in our older drawings with a description of "GRADE 5, 2C". Our internal part number corresponds to, for example, McMaster 90126A031. I assume that the 2C designation is meant to suggest the zinc-plated finish but I haven't been able to find a standard that it would be associated with. The only references I've found are ASTM A193 (appears to refer to a heat treat for SST) and BS1706, where it doesn't mean much without additional context. Our customer is now asking for clarification so I need to come up with an answer. Can anyone give me a hint? Thanks!
Mark Treadwellengineer - Baltimore, Maryland
July 16, 2013
A. Hi Mark. My guess is that the fasteners are stainless steel based on the spec you referenced, and that "2C" refers to the thread fit rather than having anything to do with zinc plating or chromating ... but this doesn't sound like a job to be guessed at, it sounds like a situation where a qualified engineer should study the drawing and issue an appropriate revision.
What is SEZn-CM finishing?
Q. Hi, I'd like to find out what is SEZn-CM finishing. This is stated in my customer drawing under surface treatment so I'm checking what finishing is this.
Best regards
Ivan Teo- Singapore
May 14, 2014
A. Hi Ivan,
If this is on your customer drawing your best bet is to ask your customer what it means.
Never ceases to amaze me, how were you ever able to quote for the job if you didn't understand what it entailed?
Q. Hi Team,
Anybody able to advise me whether DIN 50691 Fe/Zn8b is equal to ASTM B633?
- penang malaysia
December 10, 2014
A. Hi Sugumaran. I am not able to find a "DIN 50691" spec. and suspect a typo, and that you actually meant DIN 50961, which is superceded by DIN50962. That spec and ASTM B633 are different specs, so they are not "equal" ... but I do believe it will be possible for your plating to comply with both of them. Good luck.
What is Ep-Fe/Zn8/C? Same as ISO 2081?
Q. I'm finding global specification callout comply with PFZn8-C. I'm not sure where this callout comes from. I guess it's the same as Fe/Zn8/CM2. Am I correct? Then can I use ISO callout ISO2081 Fe/Zn8/C?
One more thing: Is there any expression which regulates trivalent passive chromate? ⇦ Answer?
Sorry for many ugly questions ...
- Daejeon, Rep of Korea
August 28, 2015
Please try to ENGAGE
• If they ignore other readers' postings, it becomes a dull string of unanswered questions 🙂
Q. Hi team, please help!
What does "Cr 3" mean in "Ep-Fe/Zn 5/CM2 Cr 3"? ⇦ Answer?
Thanks so much!
- Hanoi, Vietnam
January 7, 2016
What color is EP-Fe/Zn5 C3 plating?
I received a Salt Spray Corrosion Test Tracking. The treatment for the product is Ep-Fe/Zn5 C3 which I know coating thickness is over 5 µm. What coating requirement color should it be? It says "BLUE" but I thought it was green finish. Do they make a mistake or is that correct? ⇦ Answer?
Thanks in advance!
Supplier Quality Assurance - Reynosa, Mexico.
January 25, 2016
UNI ISO 2081
Q. I just received some parts with this specification UNI ISO 2081, Fe/Zn 12c 2C. I have copy of specification but I don't understand the 2 in front of the C. I understand that the C is or iridescent coating but I'm wondering if the 2 has something to do with trivalent/hexavalent type. Also the 12 I am assuming is for 12 micrometers, but what is the little c for?
Thanks in advance for all the responses. ⇦ Answer?
Electroplating Job Shop - Orange, California USA
June 21, 2016
Q. Hi, I work for a valve manufacturing company. One of our customers gave us a plating specification saying:
Surface protection "FeZn 8 Cr III Y SS:8451 S2"
Now, although I have been reading these threads and have found out that FeZn8 probably means Zinc plating with 8 microns thickness, I am not able to find Cr III anywhere. It probably means Chrome passivation but what does III mean.
Also, does SS 7451^8451 S2 mean salt spray test for moderate conditions (S2)? ⇦ Answer?
Please help.
Triton Valves Ltd. - Mysore India
March 23, 2017
Q. Can you please advise what Honda Spec MIC Black is? ⇦ Answer?
S Zuroweste- St Louis, Missouri USA
October 18, 2017
Q. A question related to: electroplated coating Fe // Zn-Fe8 // Fn //T2
Fn means black - but what exactly does BLACK mean?
is the BLACK specified somehow?
- Czestochowa, Poland
December 4, 2017
A. Hi Marek!
That specification is explained in DIN 50962.
Fe // Zn-Fe8 // Fn // T2
(Iron substrate // Zinc-Iron Layer, 8 microns // Black passivation // Sealed)
Black is specified as it is: Black passivation. There are many vendors of proprietary products to get this black color and achieve the required salt spray performance.
I suggest you to get this standard and read if this coating has any other requirements, or if your client has any expectation about this finish that is not in this spec.
Best of luck!
TEL - N FERRARIS - Cañuelas, Buenos Aires, Argentina
Q. Have a print that calls for FE/ZN Cz plating Can you tell me what the Cz stands for? ⇦ Answer?
Dennis CarterTube bending - Bay Port, Michigan USA
August 14, 2018
Q. We have inquiry for zinc plating electrodeposited coating ISO 2081 -Fe/Zn8/T4-trivalent clear passivate and torque and tension top coat TnT 15 to meet NSS hours of 120 hours white/384 Red corrosion. What does T4 mean? Thank you.
Dallas Sitinjak- Batam, Indonesia
November 29, 2018
A. Hi Dallas,
It means "Application of grease, oil or other lubricants". There is a list from T1 to T5 of supplementary coatings over zinc in ISO 2081.
Best of luck!
Q. Dear Sir May I know the breakdown of plating Fe/Zn 8-CB? Sometimes we receive the color always different. Any matrix color for this plating type? Thanks. ⇦ Answer?
M ThohirSUN PRECISION - BATAM ,INDONESIA
March 19, 2019
Q. We are quoting a electroplate spec and want to better understand the "breakdown" of the spec. Ep-Fe/Zn5/CM2C
5 : thickness 8
CM1 : blue chromate
C: ? Does anyone know what the C means?
Electroplating - Cd. Juárez Chihauhua, Mex
June 13, 2019
from (U.S. EPA)
A. Hi Omar. When we receive postings from other countries, we often must start by fixing symbols which come across wrong because of keyboards differences, letters that don't exist in English, accent marks, etc. Your name and town came across as:
On postings from some countries we must change " ı " to " I ", etc. Yet people quote abbreviations without saying what specification they are from, and ask what was meant. Spec writers don't swear an oath what their terms will mean. It's dangerous -- we have several threads where people misinterpreted what was intended by "Type 3" in regard to aluminum processing :-(
You say the "5" means "8 microns" -- it's possible, but says who? I think it 'ought' to mean 5 microns. Please tell us what specification you are referring to, then all can be revealed. Thanks!
Q. Sorry!
Is correct.
Spec ISO 2081 Ep-Fe/Zn5/CM2C
5 : thickness (5 mic)
CM1 : blue chromate
Micro Procesos Industriales S.A de C.V - Juarez, Mex
Q. Looking for a breakdown of this finishing spec.:
STD3947, Fe/Zn-Fe8c4 ⇦ Answer?
- Gardena, California
February 5, 2021
Ed. note: Sorry, we are unfamiliar with any such spec as STD3947 and believe it may be a typo.
Please see thread 26629 for another long list of similar sounding Q&A's about plating specs.
