Letter 27083
Problem with Cyanide Mixture waste
treatment [Arizona]
Subject: Problem with Cyanide Mixture treatment
Importance: High
I have several waste streams of cyanide bearing waste water coming
to a common treatment tank. I have the following waste streams:
Copper cyanide rinse water = 300 gallons per day
Bright Alloy Rinse = (Copper Cyanide + Zinc Cyanide mixture) = 300
gallons per week
Acid Gold Rinse = 300 gallons per day.
My problem is I batch treat this waste in a 4500 gallon tank. I
use Sodium Hypochlorite solution (Bleach 12%).
I add bleach to an ORP reading of 750 mv. In the past, a lower ORP
level would result in incomplete cyanide destruction. Our goal is to
reduce the cyanide to cyanate, adjust the pH and discharge to the
POTW.
Normally we have no problem with the cyanide rinse water above
treatment to cyanate. The problem arises when a Bright alloy bath is
dumped into this mix. The bright Alloy bath is:
NaCN = 3.2 oz/gal
Zn = 0.13 oz/gal
Cu = 0.28 oz/gal
Sn = 0.08 oz/gal
pH = 10.5
This is a complex cyanide bath. When it mixes with the gold rinse
we get a tank(4500 gals) of the following
AU - 4.77 mg/l
Cu - 29.3 mg/l
Zn - 2.57 mg/l
CN - 9.13 mg/l after 870mv contact for 5 days.
When no Gold is in the mix the batch treats in 24 hours with Total
cyanide = non-detect. This is verified by outside Lab. We use the EPA
method of cook down to test total cyanide. Any suggestion on how to
proceed to break this cyanide complex?
Daniel M. Reeves
Waste Water Treatment Supervisor - Glendale, AZ, USA
Gold, nickel, and iron cyanide complexes are a lot more difficult
to treat, and may not be destroyed by simple chlorination.
By my calculations, there are over 2.5 troy ounces of gold in your
4500 gallon batch. Perhaps it is possible to isloate the gold cyanide
flow and treat it with ion exchange before it gets to the batch.
Anion resins remove gold cyanide complexes very efficiently, and can
hold up to several pounds of gold per cubic foot of resin. They are
burned to recover the gold, which destroys the cyanide.
Alternatively, you could add some zinc dust to the batch before
the chlorination step. The gold will immersion plate on the zinc and
be replaced in solution with the more easily treated zinc cyanide.
Good luck, and I hope you can recover the gold!
Lyle Kirman
Kinetico Incorporated - Newbury, OH
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
