"Valence"
Valence describes how many outer shell electrons an element presents for chemical reactions. A valence can theoretically range from -7 to zero to +7, and is notated in chemical equations with superscripted '+' or '-' signs. This can be helpful in understanding and predicting reactions and balancing chemicals equations because the elements comprising a compound will be in ratios such that the combined valences equal zero.
If this was too big a leap, please review our FAQ on Faraday's Law first, which starts with the very basics. Otherwise, examples will clarify ...
Hydrogen and Chlorine can be combined to form hydrochloric acid:
H+ + Cl- = HCl
Nickel and two parts of Chlorine can be combined to form nickel chloride:
Ni++ + 2Cl- = NiCl2
Radicals are combinations of atoms so strongly bonded together that we treat them as a single unit in most chemical reactions, and radicals have a valence. For example :
OH- is the hydroxide radical, SO4- - is the sulfate radical
Sodium and hydroxide can be combined to form caustic soda
Na+ + OH- = NaOH
Copper and sulfate can be combined to form copper sulfate
Cu++ + SO4- - = CuSO4
