Summary for 9 kt gold solder composition Discussion
9 kt gold solder composition is the question here: the poster asks for the composition of 9 kt extra easy solder for yellow gold, noting that jewelry solder often must match karat labeling laws and that cadmium-free solder is desired. The thread excerpt does not include a technical answer giving an alloy formula. Instead, the only visible response is a brief suggestion from Ted Mooney, P.E. RET, pointing the reader toward "10k Gold Solder" on Amazon or eBay, which implies looking for a commercially available karat-matching solder rather than mixing one from scratch. Because no composition is actually stated in the excerpt, the practical takeaway is limited: use a suitable gold solder sold for the needed karat and verify it meets local labeling and cadmium-free requirements.
Pure gold is rarely used in jewelry due to both cost and softness; rather, lower purity gold is usually used, and its purity rated by “karat”. Pure gold is 24 kt, 12 kt gold is 12/24 gold, 9 kt gold is 9/24 gold, etc.
Jewelry and other precious metal objects must occasionally be soldered, and due to labeling laws in most countries, we are often not free to simply use any solder, but must use karat gold solders to maintain the purity.
⇦ Tip: Readers like to learn from others’ situations;
Q. Composition of 9 kt extra easy solder for yellow gold with no cadmium
kirtikumar devjee
Employee – Laudium, Centurion, South Africa
May 4, 2026
A. Hi kirtikumar,
If you already have some, please ask the supplier for its composition. Ganoskin lists 9 kt as having 18% cadmium. They say 9 kt cadmium-free is available, but they don’t offer the composition.
Their cadmium-free chart starts at “10 kt easy” with:
41.67% gold, 27.10% silver, 20.90% copper, 5.33% zinc, 2.50% tin, 2.50% indium
Please pique readers’ interest by explaining what motivates this question.
