Copper Oxide for Electroplating: Cautious, Practical Answer
Summary for copper oxide for electroplating Discussion
Copper oxide for electroplating is discussed as a possible raw material, but the answer is cautious and depends on the situation. Kaushik Magiawala asks whether copper oxide or a derivative powder can be used to do copper plating and what the process would be. The reply says the question needs more detail, but notes that suppliers of proprietary copper plating solutions could likely use copper oxide in manufacturing if they adapted their process. It also says a determined hobbyist might be able to achieve some kind of copper plating using copper oxide and other chemicals as the plating solution. However, the answer strongly warns that a specification plating shop should not try to replace proper copper anodes with copper oxide in an existing plating bath, calling that likely to be a disaster. The overall message is that copper oxide may be usable in some custom or experimental contexts, but not as a simple substitute for standard plating practice.
Q. Can copper oxide or its derivative powder be used to do copper plating? What is the process?
Kaushik Magiawala
consultant – Gandhinagar India
January 17, 2026
A. Hi Kaushik
Please try to flesh out your question with the full situation. I’m confident that the suppliers of proprietary copper plating solutions could in fact use copper oxide within their manufacturing process if they adapted for it.
I’m also confident that a determined hobbyist could achieve some sort of copper plating onto an object using copper oxide and other chemicals as his plating solution.
But I suspect that it would be a disaster for a specification plating shop to attempt to add copper oxide to their plating solution in lieu of proper copper anodes  🙂
