-----Recubrimiento acero alto carbon / Coating high carbon steel
Q. buen dia / Good morning
necesito recubrir acero al carbono hardox 500 para cuchillas con niquel tungsteno.
tengo problemas de adhesion
puedo aplicar pretratamiento con granalla de al2o3 o glass bead cual es mejor y es necesario despues sumergir en acido clorhidrico o no es necesario.como seria el procedimiento les agradezco su pronta respuesta
I need to coat Hardox 500 carbon steel for blades with nickel tungsten.
I'm having adhesion issues.
Can I apply pretreatment with Al2O3 shot or glass bead, which is better and is it necessary to soak in hydrochloric acid afterwards or not? What would be the procedure? I appreciate your prompt response.
mil gracias / Thank you very much.
- bogota colombia
October 9, 2025
Ed. note: Dear readers. Please you use Google Translate or equivalent, and submit your postings in English. The e-mail system, conversion to HTML, etc., do not handle non-English keyboards, accent marks & special characters properly, producing gibberish which neither displays properly in its original language nor can be translated to English at this end. (We thank John Vargas for avoiding accent marks).
