3-D Printed Aluminum Anodize Black: Important Limits
Summary for 3-d printed aluminum anodize black Discussion
3-D printed aluminum won’t anodize black is the core issue in this thread, but the excerpt provided is too incomplete to capture the full discussion. The visible text only shows a fragment about 3-D printers on Amazon or eBay, with no substantive question, troubleshooting details, or named answers to summarize. Because the source excerpt does not include the actual technical discussion, any detailed summary would risk inventing facts. If the full thread is available, it would be possible to identify whether the problem involved alloy composition, porosity, surface finish, or anodizing process limits, and to attribute advice to the named contributors.
3-D Printers
3d_printer
Books on 3-D Printing
3d_printing
AbeBooks
Q. I am developing an anodizing process for 3-D printed aluminum. So far, I have experimented with different material preparations (blasting), anodizing times, voltages and dye bath concentration . However, the parts are not turning out truly black — they appear either flat or gray. What other parameters should I be focusing on to achieve a deeper black finish?
Jokim Baskaran
Chemist – Reading, Pennsylvania
September 8, 2025
A. Hi Jokim,
Interesting question. Apparently either the anodizing is not thick enough, or is distorted in some way which is preventing proper absorption of the black dye. Can you tell us the thickness of the anodizing … because it is difficult to get a good black without 0.005″ thickness or more.
I suppose another possibility is that the topology of the surface of the 3-D generated aluminum is weird in some fashion, which make the part look gray instead of black, but I personally haven’t heard of such a thing. Can you tell us anything about the surface finish?
Finally, have you attempted to dye these 3-D parts any other color. And. if so, can you report on any ideosyncrocies noted in the anodizing, dyeing, or sealing which might give us additional hints?
