Summary for protecting copper work Discussion
Protecting copper work for a gallery exhibition is the main concern here: Tony asks how to preserve burnished copper while keeping it visually striking. The first answer recommends benzotriazole and similar compounds as excellent copper preservatives, but notes that longer-lasting protection usually comes from a brass lacquer, or from using a brass lacquer that already contains benzotriazole, such as Incralac. A later reply from Goran Budija says to try Incralac, either on its own or paired with Renaissance Wax, suggesting a base coat of Incralac followed by a wax top coat. The discussion is practical rather than theoretical, and both answers point toward Incralac as the most direct solution for exhibition display, with wax as an optional added layer.
Q. Any suggestions as to how to protect burnished copper to protect it and to make the metal zing when viewed in a gallery.
I have created a large copper pipe sculpture for an exhibition in Oxfordshire that starts in September. I have patinated the copper to take away the fresh look from the pipe maker but now I want to protect the finish.
Any suggestions?
Tony Wyer
Artist – Oxford UK
August 20, 2025
A. Hi Tony.
Benzotriazole and similar compounds are excellent preservatives for copper. But greater durability will come from following it with a brass lacquer … or simply using a brass lacquer which contains benzotriazole, like Incralac ⇨
A. Try Incralac, you can use it alone or in combination with Renaissance Wax ⇨
(base coat Incralac + top coat wax). Hope it helps and good luck!
– Cerovski vrh Croatia
August 25, 2025
