DS30000 Specification: Unclear Finish Code Needs Context
Summary for ds30000 specification Discussion
DS30000 specification is the key phrase here, but the thread does not identify what DS30000 actually refers to. Theresa Clements says a document lists a color and then says to see DS30000 for the finish code, and she is looking for the spec or technical information behind it. Ray Kremer replies that the code means nothing to him and asks for more context, such as whether the document is a drawing, which company requires the spec, and whether it relates to paint, anodizing, or another finish. The practical takeaway is that the code cannot be interpreted reliably from the excerpt alone; more source information is needed before anyone can identify the finish specification.
Q. I am looking for a spec or technical information on DS30000. The document lists the color but only notes to see DS30000 for finish code…
Please help!
Theresa Clements
– Holidaysburg, Pennsylvania
June 30, 2025
A. Hi Theresa
Sorry, it means nothing to me. Can you tell us what kind of document you are referring to? A drawing? Do you know what company wants it to this spec? Do we know if it relates to paint or anodizing or whatever?
A. Theresa,
A search of DoD MIL specs shows a few starting with “DS” but none with a number 30000 or anything similar. Outside of DoD and its fairly wide variety of designations, I would expect the “DS” to probably relate to the publisher of the specification. For designations not immediately identifiable as one of the big standard development organizations, it’s usually an internal spec from the end user company.
In any event, in a sane world I should expect the provider of the part drawing to be able to provide copies of all specs referenced on the drawing, or at least be able to tell you where to go to get a copy. If it’s all so old that they don’t know either, that’s a sign of larger problems, I suppose.
Google thinks DS30000 is primarily an Epson printer, but with further digging I found some references to it being either a part number (for a sleeve bearing) or a specification (for aircraft finishes) connected to Lockheed Martin. Assuming that’s plausible given the type of part in question, I don’t particularly know where to go about getting copies of Lockheed Martin specifications, but presumably their suppliers have access, which brings us back to the issue of asking whoever gave you the part drawing.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
thumbs up sign Thank you. We found it is no longer available.
Theresa Clements [returning]
– Hollidaysburg, Pennsylvania
July 14, 2025
