Acid Zinc Bath Contamination: Serious White Float Issue
Summary for acid zinc bath contamination Discussion
Acid zinc bath contamination is the issue here: the questioner reports white material floating on the surface of a chloride-based barrel zinc bath and being carried into nitric and passivation steps. The problem has been occurring for about two months, and the source is not yet traced. The process sequence given is degreasing, two water rinses, acid pickling, another rinse, acid activation, and barrel plating. No answer text is included in the excerpt, so the thread source only establishes the symptom and process context, not a diagnosis. The key practical takeaway is that the contamination is visible in the plating solution and is affecting downstream finishing, so the source likely needs to be traced through the pretreatment and plating line before the bath can be stabilized.
Q. We have acid zinc plating barrels (chloride based). Since last 2 months we are facing issue of white contamination floating on the solution surface in the morning before starting the bath. Kindly refer the attached photo. Also along with this i see a lot of white substance floating inside the solution, which is also carried to next steps of nitric and Passivation.
61846-1a
61846-1b
I am not able to trace the source and cause; kindly help.
Our process is –
1.Degreasing
2. 2 nos of Water Rinse
3. Acid Pickling
4. Water rinse
5. Acid Activation
6. Barrel plating.
aniket_k
Aniket K
CEO – Maharashtra, India
May 16, 2025
A. Hi Aniket
My initial thought is that this is an extreme example of “oiling out” ⇦ huh?. While awaiting further input here and from your plating process supplier, please see the “Brown sticky slime on surface of chloride zinc plating tank” subheading of thread 400/95.
