Zinc Plating for Garment Hangers: Smart, Glossy Choice
Summary for zinc plating for garment hangers Discussion
zinc plating for garment hangers is the main practical recommendation in this thread. Ismail Godhrawala asked what thickness would suit 2.00 mm hanger wire for a glossy silver finish and a 5–6 month use cycle, and whether zinc plating can be organic, lead-free, and cyanide-free. The answerer said 5 microns is the lowest thickness they know of for mild exposure, but it should still be more than adequate for the application. They also advised that plain zinc plating with trivalent chromating would be cheaper than tin/zinc and would give a glossier finish. On the chemistry question, the answerer noted that the plating would be lead-free, but that most tin-zinc processes are plated from a cyanide solution, which is another reason to choose plain zinc instead.
Q. Need info for garment hanger zinc electroplating lines of 5 wires for 2.00mm wire glossy silver clean finish. How much microns is best for 5 to 6 months use cycle.?
Is zinc plating organically lead free n without cyanide?
ISMAIL GODHRAWALA
Potential Market Consumption – MUMBAI
May 6, 2025
A. Hi Ismail,
5 microns (mild exposure) is the lowest thickness in any specs that I’m aware of, but it should be more than adequate.
Plain zinc plating plus trivalent chromating would be significantly cheaper than tin/zinc, as well as glossier.
The plating would be lead-free, but most tin-zinc is plated from a cyanide solution –one more reason to go with plain zinc  🙂
