Delayed Gold Yellowing: Quick Troubleshooting Tips for Zinc
Summary for delayed gold yellowing Discussion
Delayed gold/yellowing on non chromated zinc plated test panels is discussed as a troubleshooting issue for zinc plating. Boris suggests first using a zinc-coated steel panel and stripping the zinc in concentrated hydrochloric acid before rinsing and running the Hull cell, so the panel starts from a known condition. He also recommends making up a new alkaline zinc solution and testing again. If the fresh solution does not produce yellow color after a few minutes, he says the likely source of contamination is the rinse tank or the zinc bath rather than the panel itself. The thread is brief and focused on isolating whether the delayed yellowing comes from the process chemistry or from contamination introduced during rinsing or handling.
Hull Cells
hull_cell
on Amazon or
“The Hull Cell”
by Walter Nohse
hull_cell_nohse
AbeBooks
Q. Good day
Alkaline Non Cyanide Zinc plating.
Recently while running Hull Cell ⇦ huh?
tests I’m finding that some sample hull cells are developing a uniform yellow/gold layer after a day.
This does not happen after the panels are fully dried. They are not chromated.
No other unusual defects are seen at the time the parts are finished.
Any ideas on what this could be are appreciated.
Boris Siljanoski
– Perth, Western Australia
April 8, 2025
A. Hi Boris,
Are you using brass panels or steel ones? If using brass panels. and the zinc is quite thin, it could just be a matter of seeing the brass due to diffusion.
Boris,
1. Try to use zinc coated steel panel then run hull cell panel.
Before you put in hull cell strip zinc in conc. HC; follow up rinse and put into hull cell to plate.
2. make a new alkaline zinc solution, run panel
3. If #2 test results no yellow color after few minutes means contamination your rinse tank or zinc bath.
popat patel
Popatbhai B. Patel
electroplating consultant – Roseville, Michigan
