Copper stripping from steels: a safer alternative needed
Summary for copper stripping from steels Discussion
Copper stripping from steels is the problem Mark Lees raises after using copper as a nitriding mask on steel parts: he wants a non-cyanide, non-chromate remover that will take off copper without attacking the steel. He reports that 50 g/l ammonium persulphate acidified with sulphuric acid began dissolving the copper, but then likely exposed iron under the copper, triggered a thermal runaway, produced nitrous oxide fumes, and consumed both the copper and the steel test pieces. He says he will not use that chemistry again and asks for another non-proprietary system that avoids the same kind of reaction. The excerpt provided contains only the question and no answers, so no alternative process is recommended in the thread text shown.
Q. Hello Ted and the world wide gang.
I am on a quest to find a non-cyanide, non-chromate alternative from stripping of copper from steel parts. This is a post nitriding operation after the coppers use as a mask during nitriding. One attempt using 50g/l ammonium persulphate, with acidification with sulphuric acid, did not turn out so well, to use British understatement. It started off OK with the copper slowly dissolving into the solution from the test pieces. However, Mr Jekyll quickly turned into Mr Hyde, as, when I suspect, some iron under the copper dissolved into the solution and sent the solution into a thermal runaway effervescing nitrous oxide fumes and consuming the steel test pieces as well as the copper. I’ll not be using that solution again!
So does anyone know of another system, hopefully, not proprietary, that can meet the above requirements, without the ammonium persulphate type reaction?
Thanks in advance for any help that anyone can give.
Mark Lees
Mark Lees
– A dull grey rock in the Irish Sea
March 14, 2025
